REST API reference
Create a Vscan configuration
POST /protocols/vscan
Introduced In: 9.6
Creates a Vscan configuration, which includes a list of scanner-pools, Vscan On-Access policies and Vscan On-Demand policies. Defines whether the Vscan configuration you create is enabled or disabled for a specified SVM.
Important notes:
  • You can enable only one Vscan configuration at a time for an SVM.
  • There needs to be at least one active scanner-pool and one enabled On-Access policy to enable Vscan successfully.
  • By default, a Vscan is enabled when it's created.
  • By default, the Vscan On-Access policies created from this endpoint are in the disabled state. You can use the On-Access policy PATCH endpoint to enable a particular On-Access policy. In ONTAP 9.6, only one Vscan On-Access policy can be enabled and only one Vscan On-Demand policy can be scheduled on an SVM.
  • Vscan is not supported on continuous availability (CA) shares.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the Vscan configuration.
  • scanner_pools - There must be at least one active scanner-pool for Vscan configuration. Created either through Vscan POST operation or scanner-pools POST operation.
Default property values
If not specified in POST, the following default property value is assigned:
  • enabled - true
  • vserver vscan enable
  • vserver vscan scanner-pool create
  • vserver vscan scanner-pool apply-policy
  • vserver vscan scanner-pool servers add
  • vserver vscan scanner-pool privileged-users add
  • vserver vscan on-access-policy create
  • vserver vscan on-access-policy file-ext-to-exclude add
  • vserver vscan on-access-policy file-ext-to-include add
  • vserver vscan on-access-policy paths-to-exclude add
  • vserver vscan on-demand-task create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
cache_clear
boolean
Discards the cached information of the files that have been successfully scanned. Once the cache is cleared, files are scanned again when they are accessed. PATCH only
enabled
boolean
Specifies whether or not Vscan is enabled on the SVM.
on_access_policies
array[vscan_on_access_policy]
on_demand_policies
array[vscan_on_demand_policy]
scanner_pools
array[scanner_pool]
svm
svm
Example request
  "on_access_policies": [
      "name": "on-access-test",
      "protocol": "string",
      "scope": {
        "exclude_extensions": [
          "mp*",
          "txt"
        "exclude_paths": [
          "\\dir1\\dir2\\name",
          "\\vol\\a b",
          "\\vol\\a,b\\"
        "include_extensions": [
          "mp*",
          "txt"
        "max_file_size": 2147483648
  "on_demand_policies": [
      "log_path": "/vol0/report_dir",
      "name": "task-1",
      "scan_paths": [
        "/vol1/",
        "/vol2/cifs/"
      "schedule": {
        "name": "weekly",
      "scope": {
          "mp3",
          "mp4"
        "exclude_paths": [
          "/vol1/cold-files/",
          "/vol1/cifs/names"
          "vmdk",
          "mp*"
        "max_file_size": 10737418240
  "scanner_pools": [
      "cluster": {
        "name": "cluster1",
      "name": "scanner-1",
      "privileged_users": [
        "cifs\\u1",
        "cifs\\u2"
      "role": "string",
      "servers": [
        "1.1.1.1",
        "10.72.204.27",
        "vmwin204-27.fsct.nb"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[vscan]
  "num_records": 1,
  "records": [
          "scope": {
              "mp*",
              "txt"
            "exclude_paths": [
              "\\vol\\a b",
              "\\vol\\a,b\\"
              "mp*",
              "txt"
          "name": "task-1",
          "scan_paths": [
            "/vol1/",
            "/vol2/cifs/"
          "schedule": {
            "name": "weekly",
          "scope": {
              "mp3",
              "mp4"
            "exclude_paths": [
              "/vol1/cifs/names"
              "vmdk",
              "mp*"
      "scanner_pools": [
          "cluster": {
            "name": "cluster1",
            "cifs\\u1",
            "cifs\\u2"
          "role": "string",
          "servers": [
            "1.1.1.1",
            "10.72.204.27",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
10027259
A scanner-pool, an On-Access policy, or an On-Demand policy might fail to get created due to either a systematic error or some hardware failure. The error code returned details the failure along with the reason for the failure. For example, if a scanner-pool fails due to an incorrect cluster name, then the error might read: "Failed to create scanner-pool "scanner-1". Reason: "Cluster uuid points to different cluster name instead of the cluster-name supplied.". Retry the operation."
10027260
If a scanner-pool, an On-Access policy or an On-Demand policy specified in the input already exists, then a duplicate error is returned. For example, if a scanner-pool "scanner-1" already exists for an SVM and is again specified in the input, the error message will read: " Failed to create scanner-pool "scanner-1" as the specified entry already exists. Delete the entry and retry the POST operation."
2621462
The specified SVM name is invalid
2621706
The specified svm.uuid is either invalid or belongs to a different SVM
10027015
Attempting to enable a Vscan but no active scanner-pool exists for the specified SVM
10027011
Attempting to enable a Vscan for an SVM for which no CIFS server exists
10027023
Attempting to enable a Vscan for an SVM for which no active Vscan On-Access policy exist
10027086
DNS resolution failed for one or more hostnames
10027012
Cannot enable Vscan on an administrative SVM.
string
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
only_execute_access
boolean
Scan only files opened with execute-access.
scan_readonly_volumes
boolean
Specifies whether or not read-only volume can be scanned.
scan_without_extension
boolean
Specifies whether or not files without any extension can be scanned.
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled
boolean
Status of the On-Access Vscan policy
mandatory
boolean
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.
name
string
protocol
string
Specifies the file access protocol for the on-access policy. The following lists the possible protocols. CIFS - SMB protocol
scope
scope
schedule
Schedule of the task.
name
string
Job schedule name
uuid
string
Job schedule UUID
scope
exclude_extensions
array[string]
exclude_paths
array[string]
include_extensions
array[string]
max_file_size
integer
boolean
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path
string
The path from the Vserver root where the task report is created.
name
string
On-Demand task name
scan_paths
array[string]
List of paths that need to be scanned.
schedule
schedule
scope
scope
cluster_reference
name
string
uuid
string
scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster
cluster_reference
name
string
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".".
privileged_users
array[string]
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
  • example: ["cifs\u1", "cifs\u2"]
  • Introduced in: 9.10
role
string
Specifies the role of the scanner pool. The possible values are:
  • primary - Always active.
  • secondary - Active only when none of the primary external virus-scanning servers are connected.
  • idle - Always inactive.
servers
array[string]
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
  • example: ["1.1.1.1", "10.72.204.27", "vmwin204-27.fsct.nb"]
svm
name
string
uuid
string
vscan
Vscan can be used to protect data from being compromised by viruses or other malicious code. This combines best-in-class third-party antivirus software with ONTAP features that give you the flexibility you need to control which files get scanned and when. Storage systems offload scanning operations to external servers hosting antivirus software from third-party vendors. An Antivirus Connector on the external server handles communications between the storage system and the antivirus software.
cache_clear
boolean
enabled
boolean
on_access_policies
on_demand_policies
scanner_pools
array[scanner_pool]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
