REST API reference
Create a SnapMirror relationship
POST /snapmirror/relationships
Introduced In: 9.6
Creates a SnapMirror relationship. This API can optionally provision the destination endpoint when it does not exist. This API must be executed on the cluster containing the destination endpoint unless the destination endpoint is being provisioned. When the destination endpoint is being provisioned, this API can also be executed from the cluster containing the source endpoint. Provisioning of the destination endpoint from the source cluster is supported for the FlexVol volume, FlexGroup volume and Application Consistency Group endpoints.
For SVM endpoints, provisioning the destination SVM endpoint is not supported from the source cluster. When the destination endpoint exists, the source SVM and the destination SVM must be in an SVM peer relationship. When provisioning the destination endpoint, the SVM peer relationship between the source SVM and the destination SVM is established as part of the destination provision, provided that the source SVM has SVM peering permissions for the destination cluster.
Required properties
  • source.path - Path to the source endpoint of the SnapMirror relationship.
  • destination.path - Path to the destination endpoint of the SnapMirror relationship.
  • source.consistency_group_volumes - List of FlexVol volumes of type "RW" that are constituents of an Application Consistency Group.
  • destination.consistency_group_volumes - List of FlexVol volumes of type "DP" that are constituents of an Application Consistency Group.
  • policy.name or policy.uuid - Policy governing the SnapMirror relationship.
  • state - Set the state to "snapmirrored" to automatically initialize the relationship.
  • create_destination.enabled - Enable this property to provision the destination endpoint.
Default property values
If not specified in POST, the following default property values are assigned:
  • policy.name - Asynchronous
  • restore - false
  • create_destination.tiering.policy - snapshot_only (when create_destination.tiering.supported is true for FlexVol volume)
  • create_destination.tiering.policy - none (when create_destination.tiering.supported is true for FlexGroup volume)
  • create_destination.storage_service.enforce_performance - false
  • destination.ipspace - Default
  • throttle - 0
  • backoff_level - high
  • restore - false
  • throttle - 0
  • snapmirror create
  • snapmirror protect
Important notes
  • The property "transfer_schedule" if set on a SnapMirror relationship overrides the "transfer_schedule" set on the policy being used with the SnapMirror relationship.
  • The property "throttle" if set on a SnapMirror relationship overrides the "throttle" set on the policy being used with the SnapMirror relationship.
  • The properties "transfer_schedule" and "throttle" are not supported when "restore" is set to "true".
  • The property "transfer_schedule" cannot be set to null (no-quotes) during SnapMirror relationship POST.
  • The property "throttle" is not supported when "create_destination.enabled" is set to "true".
  • The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
  • The property "backoff_level" is not supported when "create_destination.enabled" is set to "true".
  • The property "backoff_level" is only applicable for FlexVol SnapMirror relationships.
The following examples show how to create FlexVol volumes, FlexGroup volumes, SVM and Application Consistency Group SnapMirror relationships. Note that the source SVM name must be the local name of the peer SVM.
Creating a FlexVol SnapMirror relationship of type XDP.
 POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:src_vol"}, "destination": { "path": "dst_svm:dst_vol"}}'
Creating a FlexGroup SnapMirror relationship of type XDP.
 POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:source_flexgroup"}, "destination": { "path": "dst_svm:dest_flexgroup"}}'
Creating a SVM SnapMirror relationship of type XDP.
 POST "/api/snapmirror/relationships/" '{"source": { "path": "src_svm:"}, "destination": { "path": "dst_svm:"}}'
Creating a SnapMirror relationship in order to restore from a destination.
 POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:src_vol"}, "destination": { "path": "dst_svm:dst_vol"}, "restore": "true"}'
Provision the destination FlexVol volume endpoint and create a SnapMirror relationship of type XDP.
 POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:src_vol"}, "destination": { "path": "dst_svm:dst_vol"}, "create_destination": { "enabled": "true" }}'
Provision the destination FlexVol volume endpoint on a Fabricpool with a tiering policy and create a SnapMirror relationship of type XDP.
 POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:src_vol"}, "destination": { "path": "dst_svm:dst_vol"}, "create_destination": { "enabled": "true", "tiering": { "supported": "true", "policy": "auto" } } }'
Provision the destination FlexVol volume endpoint using storage service and create a SnapMirror relationship of type XDP.
 POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:src_vol"}, "destination": { "path": "dst_svm:dst_vol"}, "create_destination": { "enabled": "true", "storage_service": { "enabled": "true", "name": "extreme", "enforce_performance": "true" } } }'
Provision the destination SVM endpoint and create a SnapMirror relationship of type XDP.
 POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:", "cluster": { "name": "cluster_src" }}, "destination": { "path": "dst_svm:"}, "create_destination": { "enabled: "true" }}'
Create an asynchronous SnapMirror relationship with Application Consistency Group endpoint.
 POST "/api/snapmirror/relationships/" '{"source": { "path": "src_svm:/cg/cg_src_vol", "consistency_group_volumes": [{ "name": "src_vol_1" }, { "name": "src_vol_2" }] }, "destination": { "path": "dst_svm:/cg/cg_dst_vol", "consistency_group_volumes": [{ "name": "dst_vol_1" }, { "name": "dst_vol_2" }] }, "policy": "Asynchronous" }'
Create an asynchronous SnapMirror relationship with a child Application Consistency Group endpoint.
 POST "/api/snapmirror/relationships/" '{"source": { "path": "src_svm:/cg/parent_src_cg/sub_child_cg" }, "destination": { "path": "dst_svm:/cg/cg_dst_vol" }, "policy": "MirrorAndVault" }'
POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:/cg/cg_src_vol", "consistency_group_volumes": [{ "name": "src_vol_1" }, { "name": "src_vol_2" }] }, "destination": { "path": "dst_svm:/cg/cg_dst_vol", "consistency_group_volumes": [{ "name": "dst_vol_1" }, { "name": "dst_vol_2" }] }, "create_destination": { "enabled": "true", "tiering": { "supported": "true" } }, "policy": "Asynchronous", "state": "snapmirrored" }'
 Create a SnapMirror active sync relationship with the Application Consistency Group endpoint.
POST "/api/snapmirror/relationships/" '{"source": { "path": "src_svm:/cg/cg_src_vol", "consistency_group_volumes": [{ "name": "src_vol_1" }, { "name": "src_vol_2" }] }, "destination": { "path": "dst_svm:/cg/cg_dst_vol", "consistency_group_volumes": [{ "name": "dst_vol_1" }, { "name": "dst_vol_2" }] }, "policy": "AutomatedFailOver" }'
 Provision the destination Application Consistency Group endpoint on a Fabricpool with a tiering policy, create a SnapMirror active sync relationship with a SnapMirror policy of type "sync" and sync_type of "automated_failover", and initialize the SnapMirror relationship with state as "in_sync".
POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:/cg/cg_src_vol", "consistency_group_volumes": [{ "name": "src_vol_1" }, { "name": "src_vol_2" }] }, "destination": { "path": "dst_svm:/cg/cg_dst_vol", "consistency_group_volumes": [{ "name": "dst_vol_1" }, { "name": "dst_vol_2" }] }, "create_destination": { "enabled": "true", "tiering": { "supported": "true" } }, "policy": "AutomatedFailOver", "state": "in_sync" }'
 Provision the destination Application Consistency Group endpoint with storage service, create a SnapMirror active sync relationship with a SnapMirror policy of type "sync" and sync_type of "automated_failover", and initialize the SnapMirror relationship with state as "in_sync".
POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:/cg/cg_src_vol", "consistency_group_volumes": [{ "name": "src_vol_1" }, { "name": "src_vol_2" }] }, "destination": { "path": "dst_svm:/cg/cg_dst_vol", "consistency_group_volumes": [{ "name": "dst_vol_1" }, { "name": "dst_vol_2" }] }, "create_destination": { "enabled": "true", "storage_service": { "enabled": "true", "name": "extreme", "enforce_performance": "true" } }, "policy": "AutomatedFailOver", "state": "in_sync" }'
Provision the destination Application Consistency Group endpoint with storage service, create an asynchronous application consistency group relationship with a SnapMirror policy of type "async" and an async_type of "XDPDefault", and initialize the SnapMirror relationship with state as "SnapMirrored".
POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:/cg/cg_src_vol", "consistency_group_volumes": [{ "name": "src_vol_1" }, { "name": "src_vol_2" }] }, "destination": { "path": "dst_svm:/cg/cg_dst_vol", "consistency_group_volumes": [{ "name": "dst_vol_1" }, { "name": "dst_vol_2" }] }, "create_destination": { "enabled": "true", "storage_service": { "enabled": "true", "name": "extreme", "enforce_performance": "true" } }, "policy": "XDPDefault", "state": "snapmirrored" }'
 Creating a FlexVol volume SnapMirror relationship of type XDP with transfer_schedule and throttle.
POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:src_vol"}, "destination": { "path": "dst_svm:dst_vol"}, "transfer_schedule":{"uuid":"817500fa-092d-44c5-9c10-7b54f7b2f20a", "name":"5min"}, "throttle":100}'
 Creating an asynchronous SnapMirror relationship with backoff_level set to medium.
POST "/api/snapmirror/relationships/" '{"source": {"path": "src_svm:src_vol"}, "destination": { "path": "dst_svm:dst_vol"}, "backoff_level": "medium"}' `
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
validate_only
boolean
query
False
Validate the operation and its parameters, without actually performing the operation.
  • Introduced in: 9.7
Request Body
Name Type Description
backoff_level
string
Specifies the SnapMirror backoff level due to Client Ops for FlexVol SnapMirror relationships.
create_destination
snapmirror_destination_creation
Use this object to provision the destination endpoint when establishing a SnapMirror relationship for a FlexVol volume, FlexGroup volume, SVM, Consistency Group or ONTAP S3 Bucket. Given a source endpoint, the destination endpoint is provisioned in the SVM specified in the "destination.path" property. While protecting an SVM, the SVM destination endpoint can only be provisioned on the local cluster. To provision the SVM destination endpoint use the optional "source.cluster.name" property to specify the remote cluster name or use the optional "source.cluster.uuid" property to specify the remote cluster UUID. When "create_destination.enabled" option is specified while making a POST for a SnapMirror relationship, the relationship can be automatically initialized by setting the "state" either to "snapmirrored" when the policy is of type "async" or to "in_sync" when the policy is of type "sync". The "destination.path" property must specify the destination endpoint path. For example, for FlexVol volume and FlexGroup volume, the "destination.path" can be specified as , for SVM data protection, the "destination.path" must be specified as <destination-SVM-name:>, and for Consistency Group, the "destination.path" must be specified as <destination-SVM-name:/cg/consistency-group-name> along with the "destination.consistency_group_volumes" or "destination.luns" property to indicate the list of destination volumes or LUNs of type "DP" in the Consistency Group. For a FlexVol volume, a FlexGroup volume, Consistency Group or a Bucket destination endpoint, the properties in this object can be specified either from the source or the destination cluster. For an SVM destination endpoint, the properties in this object can be specified from the destination cluster only. This object is not supported for non ONTAP endpoints. While protecting a S3 Bucket, the optional "size" property can be used to create ONTAP S3 Bucket destination endpoint of the specified size.
  • x-ntap-createOnly: true
destination
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
  • Introduced in: 9.6
exported_snapshot
string
Snapshot exported to clients on destination.
group_type
string
Specifies the group type of the top level SnapMirror relationship. The volume relationships are shown as none, the SVMDR relationships are shown as svm_dr, the Consistency Group relationships are shown as consistency_group, and the FlexGroup volume relationships are shown as flexgroup.
healthy
boolean
Is the relationship healthy?
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type. This "identity_preservation" overrides the "identity_preservation" set on the SnapMirror relationship's policy.
io_serving_copy
string
Specifies the sites serving I/O for the SnapMirror active sync relationship.
lag_time
string
Time since the exported snapshot was created.
last_transfer_network_compression_ratio
string
Specifies the compression ratio achieved for the data sent over the wire with network compression enabled for the last successful transfer.
last_transfer_type
string
Specifies the operation type of the last transfer that occurred on the relationship. The initialize transfer occurs when the relationship state changes from uninitialized to snapmirrored or in_sync. The update transfer occurs when the snapshots are transferred from the source endpoint to the destination endpoint as part of scheduled or manual update. The resync transfer occurs when the relationship state changes from broken_off to snapmirrored or in_sync. The restore transfer occurs when the snapshot is restored from a destination endpoint to another endpoint.
master_bias_activated_site
string
Specifies the Master Bias Activated Site for the SnapMirror active sync relationship.
policy
policy
Basic policy information of the relationship.
preferred_site
string
Specifies the Primary Site of the SnapMirror active sync relationship.
preserve
boolean
Set to true on resync to preserve snapshots on the destination that are newer than the latest common snapshot. This property is applicable only for relationships with FlexVol volume or FlexGroup volume endpoints and when the PATCH state is being changed to "snapmirrored".
quick_resync
boolean
Set to true to reduce resync time by not preserving storage efficiency. This property is applicable only for relationships with FlexVol volume endpoints and SVMDR relationships when the PATCH state is being changed to "snapmirrored".
recover_after_break
boolean
Set to true to recover from a failed SnapMirror break operation on a FlexGroup volume relationship. This restores all destination FlexGroup constituent volumes to the latest snapshot, and any writes to the read-write constituents are lost. This property is applicable only for SnapMirror relationships with FlexGroup volume endpoints and when the PATCH state is being changed to "broken_off".
restore
boolean
Set to true to create a relationship for restore. To trigger restore-transfer, use transfers POST on the restore relationship. SnapMirror relationships with the policy type "async" can be restored. SnapMirror relationships with the policy type "sync" cannot be restored.
restore_to_snapshot
string
Specifies the snapshot to restore to on the destination during the break operation. This property is applicable only for SnapMirror relationships with FlexVol volume endpoints and when the PATCH state is being changed to "broken_off".
source
snapmirror_source_endpoint
Source endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
state
string
State of the relationship. To initialize the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". To break the relationship, PATCH the state to "broken_off" for relationships with a policy of type "async" or "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" cannot be "broken_off". To resync the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" can be in "broken_off" state due to a failed attempt of SnapMirror failover. To pause the relationship, suspending further transfers, PATCH the state to "paused" for relationships with a policy of type "async" or "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" cannot be "paused". To resume transfers for a paused relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". The entries "in_sync", "out_of_sync", "synchronizing", "expanding", and "shrinking" are only applicable to relationships with a policy of type "sync". A PATCH call on the state change only triggers the transition to the specified state. You must poll on the "state", "healthy" and "unhealthy_reason" properties using a GET request to determine if the transition is successful. To automatically initialize the relationship when specifying "create_destination" property, set the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync".
svmdr_volumes
array[svmdr_volumes]
Specifies the list of constituent FlexVol volumes and FlexGroup volumes for an SVM DR SnapMirror relationship. FlexGroup constituents are not considered.
throttle
integer
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited.
total_transfer_bytes
integer
Cumulative bytes transferred for the relationship.
total_transfer_duration
string
Indicates the cumulative duration of all transfers since the last aggregate relocation, takeover/giveback, or metrocluster switchover/switchback involving the node that hosts the relationship.
transfer
transfer
Basic information on the current transfer or the last transfer if there is no active transfer at the time of the request.
transfer_schedule
transfer_schedule
Schedule used to update asynchronous relationships. This "transfer_schedule" overrides the "transfer_schedule" set on the SnapMirror relationship's policy. To remove the "transfer_schedule", set its value to null (no-quotes). Only cron schedules are supported for SnapMirror.
unhealthy_reason
array[snapmirror_error]
Reason the relationship is not healthy. It is a concatenation of up to four levels of error messages.
uuid
string
Unique identifier of the SnapMirror relationship.
Example request
  "backoff_level": "medium",
    "bucket_retention": {
      "default_period": "P10Y",
      "mode": "governance"
      "name": "string"
    "tiering": {
      "policy": "string"
  "destination": {
    "cluster": {
      "name": "cluster1",
        "name": "volume1",
    "ipspace": "Default",
    "luns": {
      "name": "/vol/volume1/lun1",
    "path": "svm1:volume1",
    "svm": {
      "name": "svm1",
  "exported_snapshot": "string",
  "group_type": "consistency_group",
  "identity_preservation": "string",
  "io_serving_copy": "C1_sti85-vsim-ucs209a_cluster, C1_sti85-vsim-ucs209c_cluster",
  "lag_time": "PT8H35M42S",
  "last_transfer_network_compression_ratio": 61,
  "last_transfer_type": "initialize",
  "master_bias_activated_site": "C1_sti85-vsim-ucs209a_cluster",
  "policy": {
    "name": "Asynchronous",
    "type": "string",
  "preferred_site": "C1_sti85-vsim-ucs209a_cluster",
  "restore_to_snapshot": "string",
  "source": {
    "cluster": {
      "name": "cluster1",
        "name": "volume1",
    "luns": {
    "svm": {
      "name": "svm1",
  "state": "snapmirrored",
  "svmdr_volumes": [
      "name": "volume1"
  "throttle": 0,
  "total_transfer_bytes": 1098210312,
  "total_transfer_duration": "PT3M21S",
  "transfer": {
    "end_time": "2020-12-02 18:36:19 -0800",
    "last_updated_time": "2023-09-14 15:39:19 -0700",
    "state": "string",
    "total_duration": "PT28M41S",
    "type": "initialize",
  "transfer_schedule": {
    "name": "weekly",
  "unhealthy_reason": [
      "arguments": [],
      "code": "6621444",
      "message": "Failed to complete update operation on one or more item relationships."
      "arguments": [],
      "code": "6621445",
      "message": "Group Update failed"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
918657
Invalid duration value for the "retention_period" field.
1115542
Invalid value given for the field.
6619441
The source volume cannot be the same as the destination volume.
6619599
Only the "none" tiering policy is supported when creating a destination volume with "snapshot_locking_enabled" set to true or if "snapshot_locking_enabled" is set to true on the source volume.
6619637
Relationship with specified destination volume already exists.
6619699
Schedule not found.
6620374
Internal error. Failed to get SVM information.
6620478
Internal error. Failed to check SnapMirror capability.
6620608
Child consistency group cannot be a destination endpoint for SnapMirror relationship creation.
6620654
Invalid SnapMirror Consistency Group name.
6621125
The policy is not valid for relationships with FlexGroup volume endpoints. Only policies without snapshot creation schedules are supported for these relationships.
6621128
Policy is not valid because it has snapshot creation schedules associated with it. Such policies cannot be used for relationships with Consistency Group endpoints.
6621458
The destination Consistency Group is the source of a SnapMirror Synchronous (SM-S) relationship. Sources of SM-S relationships cannot be the destination of any other SnapMirror relationship.
6621782
A property of the policy is not valid for relationships between these endpoints.
6621834
Object store configuration does not exist for the specified SVM.
6622088
SnapMirror Asynchronous relationship is not supported on a Consistency Group volume that has snapshot locking enabled.
13303819
Could not retrieve SnapMirror policy information.
13303821
Invalid SnapMirror policy UUID.
13303841
This operation is not supported for SnapMirror relationships between these endpoints.
13303852
destination.path provided does not contain ":".
13303853
Restore relationships are not supported for SVM-DR endpoints.
13303866
Associating the specified SnapMirror policy with this SnapMirror relationship is not supported.
13303868
Create of destination endpoint and SnapMirror relationship failed.
13303869
Creating a destination endpoint is not supported for restore relationships.
13303870
A tiering policy cannot be specified if tiering is not being set to supported.
13303871
Storage service properties cannot be specified if the storage service is not being enabled.
13303872
Specified property requires a later effective cluster version.
13303873
Specifying a state when creating a relationship is only supported when creating a destination endpoint.
13303874
Specified state is not supported when creating this relationship.
13303875
Destination aggregates do not have sufficient space for hosting copies of source volumes.
13303876
Destination cluster does not have composite aggregates.
13303877
Source or destination cluster must be specified.
13303878
The specified fields do not match.
13303879
Source cluster name or UUID is needed to provision a destination SVM on the local cluster.
13303880
Source cluster must be remote for provisioning a destination SVM on the local cluster.
13303881
Network validation failed.
13303882
SVM validation failed.
13303883
Encryption is not enabled on the destination cluster.
13303886
SVM peer permission not found.
13303887
Synchronous SnapMirror relationships between FlexGroup volumes are not supported.
13303888
Synchronous SnapMirror relationships require an effective cluster version of 9.5 or later on both the source and destination clusters.
13303889
Asynchronous SnapMirror relationships between FlexGroup volumes require an effective cluster version of 9.5 or later on both the source and destination clusters.
13303890
Asynchronous SnapMirror relationships between FlexVol volumes require an effective cluster version of 9.3, 9.5, or later on both the source and destination clusters.
13303891
Creating a destination endpoint with storage service requires an effective cluster version of 9.7 or later.
13303892
Fetching remote information from the destination cluster failed.
13303893
Updating job description failed.
13303894
Destination volume name is invalid. It must contain the source volume name and have a suffix when creating a destination endpoint on a cluster with an effective cluster version of 9.6 or earlier.
13303895
Operation on the remote destination cluster is not supported.
13303916
FlexGroup volumes are not supported on SnapLock aggregates.
13303918
No suitable destination aggregate type is available.
13303919
Only FabricPool enabled aggregates are available on the destination.
13303920
Only SnapLock aggregates are available on the destination. FlexGroup volumes are not supported on SnapLock aggregates.
13303921
Unable to retrieve the SnapMirror capabilities of the destination cluster.
13303922
Specified source SVM is not a data SVM.
13303923
Specified destination SVM is not a data SVM.
13303924
Source SVM has an invalid snapshot policy.
13303925
SnapMirror validation has failed.
13303930
The specified tiering policy is not supported for destination volumes of Synchronous relationships.
13303938
Fetching information from the local cluster failed.
13303939
Could not create an SVM peer relationship.
13303944
An SVM-DR relationship is not supported because the source SVM has CIFS configured and the associated SnapMirror policy has either the "identity_preservation" property not set or set to "exclude_network_and_protocol_config".
13303949
This SnapMirror policy is only supported for relationships with object store destination endpoints.
13303966
Consistency Group relationships require a policy of type "sync" with a sync_type of "automated_failover".
13303967
Consistency Group volume is not a FlexVol volume.
13303968
Unsupported volume type for the Consistency Group.
13303969
SnapMirror relationships between SVM endpoints and object store endpoints are not supported.
13303970
Unsupported policy type for the Consistency Group.
13303971
SnapMirror relationships between Consistency Group endpoints and object store endpoints are not supported.
13303976
Source or destination SVM is already part of an SVM-DR relation.
13303977
Destination Consistency Group volume UUIDs are not expected while provisioning the destination volumes.
13303978
Number of Consistency Group volume names and UUIDs does not match.
13303979
Number of Consistency Group volumes exceeds the allowed limit.
13303980
Number of source and destination Consistency Group volumes do not match.
13303981
ISCSI or FCP protocol is not configured.
13303982
SAN data interface is not configured on the SVM.
13304021
No suitable storage can be found meeting the specified requirements. No FabricPool enabled aggregates are available on the destination.
13304022
No suitable storage can be found meeting the specified requirements. No non-root, non-taken-over, non-SnapLock, non-composite aggregates are available on the destination.
13304032
In an "All SAN Array", an SVM-DR relationship is not supported when the associated SnapMirror policy does not have the "identity_preservation" property set to "exclude_network_and_protocol_config".
13304080
Specified UUID and name do not match.
13304082
Specified properties are mutually exclusive.
13304083
The specified property is not supported because all nodes in the cluster are not capable of supporting the property.
13304093
The property specified is not supported for the specified relationships.
13304098
This SnapMirror policy is not supported for SnapMirror relationships with SnapLock volumes.
13304099
SnapLock Compliance Clock is not running on all nodes in the destination cluster.
13304108
Schedule not found in the Administrative SVM or the SVM for the relationship.
13304112
File restore from a Consistency Group asynchronous SnapMirror relationship endpoint is not supported.
13304132
Creating a destination endpoint is not supported with the "backoff_level" property.
13304144
SnapLock is not licensed on the destination cluster.
13304155
Invalid SnapMirror consistency group name. The name must be from 1 to 30 characters in length. The first letter must be one of A-Z, a-z or "". The remaining characters must be A-Z, a-z, 0-9 or "".
13304160
A relationship with the specified object store endpoint exists and a restore relationship cannot be created with the same object store source endpoint name as the destination of a backup relationship except when restoring to the source volume of the existing relationship. The "source.uuid", not the source endpoint name, establishes what object is restored from the cloud.</private>
53411897
The specified source volumes do not match the volumes contained in the source consistency group.
string
code
string
Argument code
message
string
Message argument
error
SnapMirror Consistency Group failover error message.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
status
code
string
Status code
message
string
SnapMirror Consistency Group failover status.
snapmirror_consistency_group_failover
SnapMirror Consistency Group failover information. The SnapMirror Consistency Group failover can be a planned or an unplanned operation. Only active SnapMirror Consistency Group failover operation progress can be monitored using this object. In case of an error during the failover operation, the property "consistency_group_failover.error" holds the reason for the error. ONTAP automatically retries any failed SnapMirror Consistency Group failover operation.
state
string
SnapMirror Consistency Group failover state.
status
status
type
string
SnapMirror Consistency Group failover type.
bucket_retention
Specifies the retention-mode and default retention period configured on the destination bucket.
default_period
string
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "PY" and "PD" respectively, for example "P10Y" represents a duration of 10 years. The period string must contain only a single time element that is, either years, or days. A duration which combines different periods is not supported, for example "P1Y10D" is not supported.
mode
string
The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking.
storage_service
enabled
boolean
This property indicates whether to create the destination endpoint using storage service. This property is supported for Unified ONTAP destination endpoints only.
  • x-nullable: true
enforce_performance
boolean
Optional property to enforce storage service performance on the destination endpoint. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. This property is supported for Unified ONTAP destination endpoints only.
  • Default value: 1
  • x-nullable: true
name
string
Optional property to specify the storage service name for the destination endpoint. This property is considered when the property "create_destination.storage_service.enabled" is set to "true". When the property "create_destination.storage_service.enabled" is set to "true" and the "create_destination.storage_service.name" for the endpoint is not specified, then ONTAP selects the highest storage service available on the cluster to provision the destination endpoint. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. This property is supported for Unified ONTAP destination endpoints only.
  • enum: ["extreme", "performance", "value"]
  • x-nullable: true
tiering
policy
string
Optional property to specify the destination endpoint's tiering policy when "create_destination.tiering.supported" is set to "true". This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. This property determines whether the user data blocks of the destination endpoint in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of the destination endpoint volume blocks increases if they are accessed frequently and decreases when they are not. all ‐ This policy allows tiering of both destination endpoint snapshots and the user transferred data blocks to the cloud store as soon as possible by ignoring the temperature on the volume blocks. This tiering policy is not applicable for Consistency Group destination endpoints or for synchronous relationships. auto ‐ This policy allows tiering of both destination endpoint snapshots and the active file system user data to the cloud store none ‐ Destination endpoint volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the destination endpoint volume snapshots not associated with the active file system. The default tiering policy is "snapshot_only" for a FlexVol volume and "none" for a FlexGroup volume. This property is supported for Unified ONTAP destination endpoints only.
  • enum: ["all", "auto", "none", "snapshot_only"]
  • x-nullable: true
supported
boolean
Optional property to enable provisioning of the destination endpoint volumes on FabricPool aggregates. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. Only FabricPool aggregates are used if this property is set to "true" and only non FabricPool aggregates are used if this property is set to "false". Tiering support for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only do the destination endpoint volumes need to support tiering by using FabricPools, the "create_destination.tiering.policy" must not be "none". A destination endpoint that uses FabricPools but has a tiering "policy" of "none" supports tiering but will not tier any data. This property is supported for Unified ONTAP destination endpoints only.
  • x-nullable: true
Use this object to provision the destination endpoint when establishing a SnapMirror relationship for a FlexVol volume, FlexGroup volume, SVM, Consistency Group or ONTAP S3 Bucket. Given a source endpoint, the destination endpoint is provisioned in the SVM specified in the "destination.path" property. While protecting an SVM, the SVM destination endpoint can only be provisioned on the local cluster. To provision the SVM destination endpoint use the optional "source.cluster.name" property to specify the remote cluster name or use the optional "source.cluster.uuid" property to specify the remote cluster UUID. When "create_destination.enabled" option is specified while making a POST for a SnapMirror relationship, the relationship can be automatically initialized by setting the "state" either to "snapmirrored" when the policy is of type "async" or to "in_sync" when the policy is of type "sync". The "destination.path" property must specify the destination endpoint path. For example, for FlexVol volume and FlexGroup volume, the "destination.path" can be specified as , for SVM data protection, the "destination.path" must be specified as <destination-svm-name:>, and for Consistency Group, the "destination.path" must be specified as <destination-svm-name:> along with the "destination.consistency_group_volumes" or "destination.luns" property to indicate the list of destination volumes or LUNs of type "DP" in the Consistency Group. For a FlexVol volume, a FlexGroup volume, Consistency Group or a Bucket destination endpoint, the properties in this object can be specified either from the source or the destination cluster. For an SVM destination endpoint, the properties in this object can be specified from the destination cluster only. This object is not supported for non ONTAP endpoints. While protecting a S3 Bucket, the optional "size" property can be used to create ONTAP S3 Bucket destination endpoint of the specified size.</destination-svm-name:></destination-svm-name:>
bucket_retention
bucket_retention
enabled
boolean
Optional property to create the destination endpoint when establishing a SnapMirror relationship. It is assumed to be "false" if no other property is set and assumed to be "true" if any other property is set.
size
integer
Optional property to specify the size of destination endpoint in bytes. This property is applicable only to ONTAP S3 Bucket endpoints. The minimum size for S3 bucket is 80MB and maximum size is 64TB. If not specified, system will create destination with default size of 800GB.
  • Introduced in: 9.10
  • x-nullable: true
boolean
Optional property to create the destination endpoint with snapshot locking enabled when establishing a SnapMirror relationship. This property is applicable to FlexVol volumes and FlexGroup volumes.
storage_service
storage_service
tiering
tiering
cluster
name
string
uuid
string
name
string
The name of the volume.
uuid
string
Unique identifier of the volume. This corresponds to the instance-uuid that is exposed in the CLI and ONTAPI. It does not change due to a volume move.
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.8
  • x-nullable: true
luns
Optional property for a SnapMirror endpoint. Specifies the list of source LUNs and optionally list of destination LUNs during SnapMirror Consistency Group LUN restore operation.
name
string
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the LUN.
svm
name
string
uuid
string
snapmirror_endpoint
cluster
cluster
array[consistency_group_volumes]
This property specifies the list of FlexVol volumes or LUNs of a Consistency Group. Optional on the ASA r2 platform. Mandatory for all other platforms.
ipspace
string
Optional property to specify the IPSpace of the SVM.
luns
luns
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
  • example: svm1:volume1
  • x-nullable: true
svm
svm
policy
name
string
Name of the SnapMirror policy.
type
string
uuid
string
Unique identifier of the SnapMirror policy.
cluster
cluster
luns
luns
path
string
  • Introduced in: 9.14
  • x-nullable: true
svm
svm
svmdr_volumes
name
string
transfer
bytes_transferred
integer
Total bytes transferred in the current or last successful transfer.
end_time
string
End time of the last transfer.
last_updated_time
string
Last updated time of the bytes transferred in the current transfer.
state
string
total_duration
string
Elapsed time to transfer all snapshots for the last successful transfer.
type
string
Specifies the operation type of the current transfer on the relationship. The initialize transfer occurs when the relationship state changes from "uninitialized" to "snapmirrored" or "in_sync". The update transfer occurs when snapshots are being transferred from the source endpoint to the destination endpoint as part of a scheduled or manual update. The resync transfer occurs when the relationship state changes from "broken_off" to "snapmirrored" or "in_sync". The restore transfer occurs when a snapshot is being restored from a destination endpoint to another endpoint.
uuid
string
Transfer UUID. This property is applicable only for active transfers.
transfer_schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_error
SnapMirror error
arguments
array[string]
Arguments present in the error message encountered.
code
string
Error code
message
string
Error message
snapmirror_relationship
SnapMirror relationship information. The SnapMirror relationship can be either "async" or "sync" based on the type of SnapMirror policy associated with the relationship. The source and destination endpoints of a SnapMirror relationship must be of the same type, for example, if the source endpoint is a FlexVol volume then the destination endpoint must be a FlexVol volume. The SnapMirror policy type "async" can be used when the SnapMirror relationship has FlexVol volume or FlexGroup volume or SVM as the endpoint. The SnapMirror policy type "sync" can be used when the SnapMirror relationship has FlexVol volume as the endpoint. The SnapMirror policy type "sync" with "sync_type" as "automated_failover" can be used when the SnapMirror relationship has Consistency Group as the endpoint.
backoff_level
string
create_destination
destination
snapmirror_endpoint
exported_snapshot
string
group_type
string
healthy
boolean
string
io_serving_copy
string
lag_time
string
string
last_transfer_type
string
string
policy
policy
preferred_site
string
preserve
boolean
quick_resync
boolean
recover_after_break
boolean
restore
boolean
restore_to_snapshot
string
source
state
string
svmdr_volumes
throttle
integer
integer
string
transfer
transfer
transfer_schedule
transfer_schedule
unhealthy_reason
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
