REST API reference
Create a cluster-scoped or an SVM-scoped SNMP user
POST /support/snmp/users
Introduced In: 9.7
Creates either a cluster-scoped or an SVM-scoped SNMP user. This user can be an SNMPv1 or SNMPv2c community user or an SNMPv3 user. An SNMPv3 user can be a local SNMPv3 user or a remote SNMPv3 user.
Required properties
  • name - SNMP user name
Optional properties
  • owner - Name and UUID of owning SVM.
  • engine_id - Engine ID of owning SVM or remote switch.
  • authentication_method - Authentication method
  • switch_address - Optional remote switch address
  • snmpv3 - SNMPv3-specific credentials
  • comment - Comment text
Default property values
  • snmpv3.authentication_protocol - none
  • snmpv3.privacy_protocol - none
  • security login create
  • system snmp community add
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
string
Optional authentication method.
comment
string
Optional comment text.
engine_id
string
Optional SNMPv3 engine identifier. For a local SNMP user belonging to the administrative Storage Virtual Machine (SVM), the default value of this parameter is the SNMPv3 engine identifier for the administrative SVM. For a local SNMP user belonging to a data SVM, the default value of this parameter is the SNMPv3 engine identifier for that data SVM. For an SNMPv1/SNMPv2c community, this parameter should not be specified in "POST" method. For a remote switch SNMPv3 user, this parameter specifies the SNMPv3 engine identifier for the remote switch. This parameter can also optionally specify a custom engine identifier.
name
string
SNMP user name.
owner
owner
Optional name and UUID of owning Storage Virtual Machine (SVM).
snmpv3
snmpv3
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user.
switch_address
string
Optional remote switch address. It can be an IPv4 address or an IPv6 address. A remote switch can be queried over SNMPv3 using ONTAP SNMP client functionality. Querying such a switch requires an SNMPv3 user (remote switch user) to be configured on the switch. Since ONTAP requires remote switch user's SNMPv3 credentials (to query it), this user must be configured in ONTAP as well. This parameter is specified when configuring such a user.
  • example: 10.23.34.45
  • Introduced in: 9.7
  • readCreate: 1
  • x-nullable: true
Example request
  "authentication_method": "usm",
  "comment": "This is a comment.",
  "engine_id": "80000315055415ab26d4aae811ac4d005056bb792e",
  "name": "snmpv3user2",
  "owner": {
    "name": "svm1",
  "snmpv3": {
    "authentication_password": "humTdumt*@t0nAwa11",
    "authentication_protocol": "sha2_256",
    "privacy_password": "p@**GOandCLCt*200",
    "privacy_protocol": "aes128"
  "switch_address": "10.23.34.45"
Status: 201, Created
string
comment
string
engine_id
string
name
string
SNMP user name.
owner
owner
snmpv3
snmpv3
switch_address
string
  • readCreate: 1
  • x-nullable: true
  "owner": {
    "name": "svm1",
  "snmpv3": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1263341
Invalid authentication protocol.
1263342
Invalid privacy protocol.
1263567
Authentication password not supplied.
1263568
Privacy password not supplied.
1263569
Authentication password does not conform to ONTAP requirements.
1263570
Privacy password does not conform to ONTAP requirements.
2621475
This operation is not allowed on a node SVM.
2621601
This operation is not permitted on a system SVM.
5636101
One role for all applications and authentication methods is recommended for a user account.
5636106
Engine ID starting with first bit set as 1 in first octet should have a minimum of 5 or maximum of 32 octets.
5636107
Engine ID specified is based on an IP address, and must therefore be 9 octets in length.
5636108
Engine ID specified is based on an IPv6 address, and must therefore be 21 octets in length.
5636109
Engine ID specified is based on a MAC address, and must therefore be 11 octets in length.
5636110
Engine ID starting with first bit set as 0 in the first octet needs to be 12 octets in length.
5636111
Engine ID cannot have all zeroes.
5636112
Invalid Engine ID specified.
5636113
Cannot enable SNMP user capability for data SVM.
5636116
Cannot read SNMP user capability for data SVM.
5636121
User account name is reserved for use by the system.
5636123
Cannot create an SNMP user with a role other than readonly, none, or admin.
5636124
Cannot create an SNMP user with a role other than vsadmin-readonly, none, or vsadmin.
5636148
Failed to discover SNMPv3 engine ID of remote SNMP agent.
5636150
The switch_address parameter can be specified only for administrative SVMs.
5636152
0.0.0.0 cannot be specified as the IP Address for the switch_address parameter.
5636153
Engine ID is already associated with user.
7077897
Invalid character in username. Valid characters":" A-Z, a-z, 0-9, ".", "_", and "-". Note that the user name cannot start with "-".
7077899
Username does not meet length requirements.
7077906
Cannot use given role with this SVM because a role with that name has not been defined for the SVM.
9043995
Failed to create SNMP community. Reason":" SNMPv1 and SNMPv2c are not supported when cluster FIPS mode is enabled.
9043999
ONTAP failed to create an SNMPv3 user because SNMPv3 is disabled in the cluster.
9044020
Customized engine-id cannot be specified for community users.
9044021
The specified authentication protocol is not supported when cluster FIPS mode is enabled.
9044022
The specified privacy protocol is not supported when cluster FIPS mode is enabled.
9044023
The switch_address parameter can be specified only for creating remote SNMPv3 users.
string
owner
name
string
uuid
string
snmpv3
string
Authentication protocol password.
string
Authentication protocol.
privacy_password
string
Privacy protocol password.
privacy_protocol
string
Privacy protocol.
snmp_user
An SNMP user can be an SNMPv1/SNMPv2c user or an SNMPv3 user. SNMPv1/SNMPv2c user is also called a "community" user. An SNMPv3 user, also called a User-based Security Model (USM) user, can be a local SNMPv3 user or a remote SNMPv3 user. A local SNMPv3 user can be used for querying ONTAP SNMP server over SNMPv3 and/or for sending SNMPv3 traps. The local SNMPv3 user used for sending SNMPv3 traps must be configured with the same authentication and privacy credentials on the traphost receiver as well. A remote SNMPv3 user is also configured on a remote switch and used by ONTAP SNMP client functionality to query the remote switch over SNMPv3. An SNMP user is scoped to its owning Storage Virtual Machine (SVM). Owning SVM could be a data SVM or the administrative SVM.
string
comment
string
engine_id
string
name
string
SNMP user name.
owner
owner
snmpv3
snmpv3
switch_address
string
  • readCreate: 1
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
