REST API reference
Manage HA network security
Overview
You can use the security ha-network API endpoint to modify the HA network security configuration for NVLog traffic. The following operations are supported:
  • GET to retrieve the HA network security status: GET security/ha-network
  • PATCH to update the HA network security configuration: PATCH security/ha-network
