REST API reference
Manage FlexCache volumes
Overview
FlexCache is a persistent cache of an origin volume. An origin volume can only be a FlexVol while a FlexCache is always a FlexGroup.
The following relationship configurations are supported:
– Intra-Vserver where FlexCache and the corresponding origin volume reside in the same Vserver.
– Cross-Vserver but intra-cluster where FlexCache and the origin volume reside in the same cluster but belong to different Vservers.
– Cross-cluster where FlexCache and the origin volume reside in different clusters.
FlexCache supports fan-out and more than one FlexCache can be created from one origin volume. This API retrieves and manages FlexCache configurations in the cache cluster.
FlexCache APIs
The following APIs can be used to perform operations related with FlexCache:
– GET /api/storage/flexcache/flexcaches
– GET /api/storage/flexcache/flexcaches/{uuid}
– POST /api/storage/flexcache/flexcaches
– DELETE /api/storage/flexcache/flexcaches/{uuid}
Creating a FlexCache
The POST request is used to create a FlexCache.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/flexcache/flexcaches" -H  "accept: application/json" -H  "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr_1\" } ], \"name\": \"fc_333\", \"origins\": [ {  \"svm\": { \"name\": \"vs_3\"  }, \"volume\": { \"name\": \"vol_o1\" } } ], \"svm\": { \"name\": \"vs_1\" } }"
# The response:
"job": {
  "uuid": "e751dd5d-0f3c-11e9-8b2b-0050568e0b79",
      "href": "/api/cluster/jobs/e751dd5d-0f3c-11e9-8b2b-0050568e0b79"
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/flexcache/flexcaches" -H  "accept: application/json" -H  "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr_1\" } ], \"name\": \"fc_333\", \"origins\": [ {  \"svm\": { \"name\": \"vs_3\"  }, \"volume\": { \"name\": \"vol_o1\" } } ], \"svm\": { \"name\": \"vs_1\" },  \"path\": \"/fc_333\", \"prepopulate\": { \"dir_paths\": [ \"/dir1\" ] } }"
# The response:
"job": {
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/flexcache/flexcaches" -H  "accept: application/json" -H  "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\":           \"aggr_1\" } ], \"name\": \"fc_333\", \"origins\": [ {  \"svm\": { \"name\": \"vs_3\"  }, \"volume\": { \"name\": \"vol_o1\" } } ], \"svm\": { \"name\": \"vs_1\" },  \"path\": \"/       fc_333\", \"prepopulate\": { \"dir_paths\": [ \"/dir1\" ], \"exclude_dir_paths\": [ \"/dir1/dir11\" ] } }"
# The response:
"job": {
  "uuid": "5afe9ea4-1dcf-11eb-b006-005056ac6a93",
      "href": "/api/cluster/jobs/5afe9ea4-1dcf-11eb-b006-005056ac6a93"
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/flexcache/flexcaches" -H  "accept: application/json" -H  "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr_1\" } ], \"name\": \"fc_333\", \"origins\": [ {  \"svm\": { \"name\": \"vs_3\"  }, \"volume\": { \"name\": \"vol_o1\" } } ], \"svm\":{ \"name\": \"vs_1\" }, \"dr_cache\": true,  \"path\": \"/fc_333\", \"prepopulate\": { \"dir_paths\": [ \"/dir1\" ] } }"
# The response:
"job": {
Retrieving FlexCache attributes
The GET request is used to retrieve FlexCache attributes. The object includes a large set of fields which can be expensive to retrieve. Most notably, the fields size, guarantee.type, aggregates, path, origins.ip_address, origins.size, and origins.state are expensive to retrieve. The recommended method to use this API is to filter and retrieve only the required fields.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/flexcache/flexcaches?" -H  "accept: application/json"
# The response:
"records": [
    "uuid": "04d5e07b-0ebe-11e9-8180-0050568e0b79",
    "name": "fc_322",
        "href": "/api/storage/flexcache/flexcaches/04d5e07b-0ebe-11e9-8180-0050568e0b79"
    "uuid": "47902654-0ea4-11e9-8180-0050568e0b79",
    "name": "fc_321",
        "href": "/api/storage/flexcache/flexcaches/47902654-0ea4-11e9-8180-0050568e0b79"
    "uuid": "77e911ff-0ebe-11e9-8180-0050568e0b79",
    "name": "fc_323",
        "href": "/api/storage/flexcache/flexcaches/77e911ff-0ebe-11e9-8180-0050568e0b79"
    "uuid": "ddb42bbc-0e95-11e9-8180-0050568e0b79",
    "name": "fc_32",
        "href": "/api/storage/flexcache/flexcaches/ddb42bbc-0e95-11e9-8180-0050568e0b79"
    "uuid": "ec774932-0f3c-11e9-8b2b-0050568e0b79",
    "name": "fc_333",
        "href": "/api/storage/flexcache/flexcaches/ec774932-0f3c-11e9-8b2b-0050568e0b79"
"num_records": 5,
    "href": "/api/storage/flexcache/flexcaches?"
Retrieving the attributes of a FlexCache
The GET request is used to retrieve the attributes of a FlexCache. The object includes a large set of fields which can be expensive to retrieve. Most notably, the fields size, guarantee.type, aggregates, path, origins.ip_address, origins.size, and origins.state are expensive to retrieve. The recommended method to use this API is to filter and retrieve only the required fields.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/flexcache/flexcaches/ec774932-0f3c-11e9-8b2b-0050568e0b79" -H  "accept: application/json"
# The response:
"name": "fc_333",
"svm": {
  "name": "vs_1",
  "uuid": "e708fbe2-0e92-11e9-8180-0050568e0b79"
"size": 4294967296,
"guarantee": {
    "type": "volume"
"dr_cache": "true",
"aggregates": [
    "name": "aggr_1",
    "uuid": "26f34b76-88f8-4a47-b5e0-d8e901fb1114"
"origins": [
    "ip_address": "10.140.103.175",
    "size": 20971520,
    "create_time": "2019-01-03T15:19:55+05:30",
    "state": "online",
    "volume": {
      "name": "vol_o1",
      "uuid": "2bc957dd-2617-4afb-8d2f-66ac6070d313"
    "svm": {
      "name": "vs_3",
      "uuid": "8aa2cd28-0e92-11e9-b391-0050568e4115"
    "cluster": {
      "name": "node2",
      "uuid": "50733f81-0e90-11e9-b391-0050568e4115"
Deleting a FlexCache
The DELETE request is used to delete a FlexCache.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/flexcache/flexcaches/ec774932-0f3c-11e9-8b2b-0050568e0b79" -H  "accept: application/json"
# The response:
"job": {
  "uuid": "e17994f2-0f3e-11e9-8b2b-0050568e0b79",
      "href": "/api/cluster/jobs/e17994f2-0f3e-11e9-8b2b-0050568e0b79"
Modifying a FlexCache volume
Use the PATCH request to update a FlexCache volume.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/ec774932-0f3c-11e9-8b2b-0050568e0b79"  -H  "accept: application/json" -H  "Content-Type: application/json" -d "{ \"prepopulate\": { \"dir_paths\": [ \"/dir1\" ] } }"
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/ec774932-0f3c-11e9-8b2b-0050568e0b79"  -H  "accept: application/json" -H  "Content-Type: application/json" -d "{ \"prepopulate\": { \"dir_paths\": [ \"/dir1\" ], \"exclude_dir_paths\": [ \"/dir1/dir11\" ] } }"
# The response:
"job": {
  "uuid": "b574c48c-1da7-11eb-b006-005056ac6a93",
      "href": "/api/cluster/jobs/b574c48c-1da7-11eb-b006-005056ac6a93"
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H  "Content-Type: application/json" -d "{ \"nfsv4\" : { \"enabled\": true } }"
# The response:
"job": {
  "uuid": "c521a541-3046-11ed-a5d5-005056bbb2b7",
      "href": "/api/cluster/jobs/c521a541-3046-11ed-a5d5-005056bbb2b7"
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"nfsv4\" : { \"enabled\": false } }"
# The response:
"job": {
  "uuid": "17e193f3-304b-11ed-a5d5-005056bbb2b7",
      "href": "/api/cluster/jobs/17e193f3-304b-11ed-a5d5-005056bbb2b7"
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H  "Content-Type: application/json" -d "{ \"cifs\" : { \"enabled\": true } }"
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"cifs\" : { \"enabled\": false } }"
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H  "Content-Type: application/json" -d "{ \"s3\" : { \"enabled\": true } }"
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H  "Content-Type: application/json" -d "{ \"s3\" : { \"enabled\": false } }"
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H  "Content-Type: application/json" -d "{ \"writeback\" : { \"enabled\": true } }"
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/28f9734a-2fc2-11ed-a5d5-005056bb2b7" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"writeback\" : { \"enabled\": false } }"
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/885dfd0f-ac37-11ed-a2ca-005056bb5573" -H "accept: application/json" -d '{"relative_size" : {"enabled":true, "percentage" : 50}}'
# The response:
"job": {
  "uuid": "34d9c90d-ac38-11ed-a2ca-005056bb5573",
      "href": "/api/cluster/jobs/34d9c90d-ac38-11ed-a2ca-005056bb5573"
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/885dfd0f-ac37-11ed-a2ca-005056bb5573" -H "accept: application/json" -d '{"relative_size" : {"enabled":false}}'
# The response:
"job": {
  "uuid": "14bfcc28-ac82-11ed-83bd-005056bb5573",
      "href": "/api/cluster/jobs/14bfcc28-ac82-11ed-83bd-005056bb5573"
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/885dfd0f-ac37-11ed-a2ca-005056bb5573" -H "accept: application/json" -d '{"atime_scrub" : {"enabled":true, "period" : 30}}'
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/885dfd0f-ac37-11ed-a2ca-005056bb5573" -H "accept: application/json" -d '{"atime_scrub" : {"enabled":false}}'
# The response:
"job": {
# The API:
# The call
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/flexcaches/885dfd0f-ac37-11ed-a2ca-005056bb5573" -H "accept: application/json" -d '{"cifs_change_notify" : {"enabled":true}}'
# The response:
"job": {
