REST API reference
Manage directories
Overview
You can use this API to retrieve a list of directories with the greatest value performance metric or capacity metric for a specified volume. Use the top_metric parameter to specify which type of metric to filter for. This API is used to provide insight into performance metrics, namely iops and throughput, or capacity metrics such as non_recursive_bytes_used. This API only supports returning one metric per request.
Retrieve a list of the directories with the most I/O activity
For a report on the directories with the most I/O activity in the past several seconds returned in descending order, specify the performance metric type you want to filter for by passing the iops or throughput property into the top_metric parameter. If the metric type is not specified, by default the API returns a list of the directories with the greatest number of the average read operations per second. The current maximum number of directories returned by the API for a metric type is 25.
Approximate accounting and error bars for the list of directories with the most I/O activity
When too many directories have recent activity, some directories might be dropped from the list. In this situation, the spread of values in the error field increases, indicating that there are larger error bars on the value for iops or throughput. As the list becomes increasingly more approximate due to dropped entries, some of the directories that would have otherwise been included might not be present in the final list returned by the API.
Retrieve a list of the largest directories
For a report on the largest directories returned in descending order, specify the capacity metric by passing the non_recursive_bytes_used property into the top_metric parameter. If the metric type is not specified, by default the API returns a list of directories with the greatest number of average read operations per second. The current maximum number of directories returned by the API for a metric type is 25.
Failure to return list of directories with most I/O activity
The API can sometimes fail to return the list of directories with the most I/O activity, due to the following reasons:
– The volume does not have the activity tracking feature enabled.
– The volume has not had any recent NFS/CIFS client traffic.
– The NFS/CIFS client operations are being served by the client-side filesystem cache.
– The NFS/CIFS client operations are being buffered by the client operating system.
– On rare occasions, the incoming traffic pattern is not suitable to obtain the list of directories with the most I/O activity.
– NFSv4 client read operations using Multi-Processor I/O (MPIO) are not tracked.
Failure to return list of largest directories
The API can sometimes fail to return the list of largest directories, due to the following reasons:
– The volume does not have file system analytics enabled.
– The volume's file system analytics database version doesn't support this report.
Failure to return pathnames
The API can sometimes fail to obtain filesystem pathnames for certain directories, either due to internal transient errors or if those directories have been recently deleted. In such cases, instead of the pathname, the API will return "{.}" for that directory.
Retrieving a list of the directories with the greatest average number of read operations per second
# The API:
GET /api/storage/volumes/{volume.uuid}/top-metrics/directories
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/directories?top_metric=iops.read"
# The Response:
"records": [
    "volume": {
      "name": "vol1",
    "iops": {
      "read": 1495,
      "error": {
        "lower_bound": 1495,
        "upper_bound": 1505
    "path": "/dir1/dir2",
    "svm": {
      "uuid": "572361f3-e769-439d-9c04-2ba48a08ff43",
      "name": "vs1",
          "href": "/api/svm/svms/572361f3-e769-439d-9c04-2ba48a08ff43"
      "directory": {
        "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir1%2Fdir2"
      "metadata": {
        "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir1%2Fdir2?return_metadata=true"
    "volume": {
      "name": "vol1",
    "iops": {
      "read": 1022,
      "error": {
        "lower_bound": 1022,
        "upper_bound": 1032
    "path": "/dir3/dir4",
    "svm": {
      "name": "vs1",
      "directory": {
        "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir3%2Fdir4"
      "metadata": {
        "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir3%2Fdir4?return_metadata=true"
    "volume": {
      "uuid": "73b293df-e9d7-46cc-a9ce-2df8e52ef864",
      "name": "vol1",
          "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864"
    "iops": {
      "read": 345,
      "error": {
        "lower_bound": 345,
        "upper_bound": 355
    "path": "/dir12",
    "svm": {
      "name": "vs1",
      "directory": {
        "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir12"
      "metadata": {
        "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir12?return_metadata=true"
"num_records": 3,
    "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/top-metrics/directories?top_metric=iops.read"
Retrieving a list of the directories with the most traffic with failure in obtaining the pathnames for the directories:
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/directories?top_metric=throughput.write"
# The Response:
"records": [
    "volume": {
      "name": "fv"
    "throughput": {
      "write": 24,
      "error": {
        "lower_bound": 24,
        "upper_bound": 29
    "path": "{4ec6d1ea-d5da-11eb-a25f-005056ac0f77:1232}",
    "svm": {
      "uuid": "0ba74c3e-d5ca-11eb-8fbb-005056ac0f77",
      "name": "vs0",
          "href": "/api/svm/svms/0ba74c3e-d5ca-11eb-8fbb-005056ac0f77"
    "volume": {
      "name": "fv"
    "throughput": {
      "write": 12,
      "error": {
        "lower_bound": 12,
        "upper_bound": 22
    "path": "{4ec6d1ea-d5da-11eb-a25f-005056ac0f77:6754}",
    "svm": {
      "name": "vs0",
    "volume": {
      "name": "fv"
    "throughput": {
      "write": 8,
      "error": {
        "lower_bound": 8,
        "upper_bound": 10
    "path": "{4ec6d1ea-d5da-11eb-a25f-005056ac0f77:8654}",
    "svm": {
      "name": "vs0",
"num_records": 3,
    "href": "/api/storage/volumes/4ec6d1ea-d5da-11eb-a25f-005056ac0f77/top-metrics/directories?top_metric=throughput.write"
Retrieving a list of the largest directories
The following example shows how to retrieve a list of the largest directories based on the non-recursive bytes used by the contents of a directory.
# The API:
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/directories?top_metric=non_recursive_bytes_used"
# The Response:
"records": [
    "volume": {
      "name": "vol1"
    "non_recursive_bytes_used": 345,
    "svm": {
      "name": "vs1",
      "directory": {
      "metadata": {
    "volume": {
      "name": "vol1"
    "svm": {
      "name": "vs1",
      "directory": {
      "metadata": {
    "volume": {
      "name": "vol1"
    "path": "/dir12",
    "svm": {
      "name": "vs1",
      "directory": {
      "metadata": {
"num_records": 3,
    "href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/top-metrics/directories?top_metric=non_recursive_bytes_used"
Retrieving a list of the largest directories where incomplete data is reported
The following example retrieves a list of the largest directories when partial data is returned.
# The API:
# The Call:
# The Response:
"records": [
    "volume": {
      "name": "vol1"
    "non_recursive_bytes_used": 1022,
    "svm": {
      "name": "vs1",
      "directory": {
      "metadata": {
    "volume": {
      "name": "vol1"
    "non_recursive_bytes_used": 261,
    "path": "/dir12",
    "svm": {
      "name": "vs1",
      "directory": {
      "metadata": {
"num_records": 2,
"incomplete_response_reason": {
  "message": "Partial data has been returned for this metric report. Reason: Data collection for the large directory report is in progress.",
  "code": "111411234",
  "arguments": [
      "message": "Data collection for the large directory report is in progress."
Retrieving a list of the largest directories when the file system analytics database version doesn't support this report
The following example shows the behavior of the API when the file system analytics database version doesn't support the large directory report.
# The API:
# The Call:
# The Response:
"records": [
"num_records": 0,
"error": {
  "message": "The large directory report for volume \"FV\" in Vserver \"vs0\" is not available because the file system analytics database version doesn't support this report. Use the \"volume analytics off\" command to disable analytics on the volume, then use the \"volume analytics on\" command to re-enable analytics.",
  "code": "124519410"
Example showing the behavior of the API when there is no read/write traffic:
# The Call:
# The Response:
"records": [
"num_records": 0,
"notice": {
  "message": "The activity tracking report for volume \"FV\" in SVM \"vs0\" returned zero records. Check whether the volume have read/write traffic. Refer to the REST API documentation for more information on why there might be no records.",
  "code": "124518418"
    "href": "/api/storage/volumes/9af63729-8ac8-11ec-b1bc-005056a79da4/top-metrics/directories?top_metric=throughput.write"
