Event remediation and management action collection get
GET /private/manage/event-remediations
Introduced In: 9.8
Event remediation and management action collection GET
Learn more
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[event_remediations] |
List of event remediations |
"next": {
"href": "/api/resourcelink"
"num_records": "3",
"records": [
"cluster": {
"name": "cluster1",
"completion_time": "string",
"description": "Disable Telnet",
"event_remediation_action": "string",
"event_remediation_action_type": "string",
"event_remediation_state": "string",
"event_type_name": "cluster_telnet_enabled",
"id": "198",
"solution": "Continue to disable telnet on the selected cluster using the 'security protocol modify -application telnet -enabled false’ ontap cli command.",
"source": {
"object_id": "5666",
"object_type": "inventory.ontap.fas.Cluster"
"source_full_name": "shrey-vsim1",
"source_resource_type": "cluster",
"start_time": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
cluster
name |
string |
uuid |
string |
source
object_id |
integer |
object_type |
string |
event_remediations
cluster |
completion_time |
string |
Completion time of the event |
description |
string |
Description for the event |
event_remediation_action |
string |
Event remediation action |
event_remediation_action_type |
string |
Type of remediation action |
event_remediation_state |
string |
State of the event remediation |
event_type_name |
string |
Type of the event |
id |
integer |
Event Identifier |
solution |
string |
Corrective action for the event |
source |
source_full_name |
string |
Source of the event |
source_resource_type |
string |
Type of source of the event |
start_time |
string |
Start time of the event |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
