Perform an event management action
PATCH /private/manage/event-remediations/{id}
Introduced In: 9.8
Perform an event management action.
Learn more
id |
integer |
path |
True |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
cluster |
completion_time |
string |
Completion time of the event |
description |
string |
Description for the event |
event_remediation_action |
string |
Event remediation action |
event_remediation_action_type |
string |
Type of remediation action |
event_remediation_state |
string |
State of the event remediation |
event_type_name |
string |
Type of the event |
id |
integer |
Event Identifier |
solution |
string |
Corrective action for the event |
source |
source_full_name |
string |
Source of the event |
source_resource_type |
string |
Type of source of the event |
start_time |
string |
Start time of the event |
Example request
"cluster": {
"name": "cluster1",
"completion_time": "string",
"description": "Disable Telnet",
"event_remediation_action": "string",
"event_remediation_action_type": "string",
"event_remediation_state": "string",
"event_type_name": "cluster_telnet_enabled",
"id": "198",
"solution": "Continue to disable telnet on the selected cluster using the 'security protocol modify -application telnet -enabled false’ ontap cli command.",
"source": {
"object_id": "5666",
"object_type": "inventory.ontap.fas.Cluster"
"source_full_name": "shrey-vsim1",
"source_resource_type": "cluster",
"start_time": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Ontap error response codes
cluster
name |
string |
uuid |
string |
source
object_id |
integer |
object_type |
string |
event_remediations
cluster |
completion_time |
string |
description |
string |
string |
string |
string |
event_type_name |
string |
Type of the event |
id |
integer |
Event Identifier |
solution |
string |
source |
source_full_name |
string |
string |
start_time |
string |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
