Creates an audit log redirect configuration
related ontap commands
vserver audit audit-log-redirect create# learn more -
doc /private/protocols/audit/audit-log-redirect](#docs-nas-private_protocols_audit_audit-log-redirect)
POST /private/protocols/audit/audit-log-redirect
Introduced In: 9.8
Creates an Audit Log Redirect configuration.
Required properties
svm.uuidorsvm.name- Existing SVM to which NAS audit events logs will be redirected to.
Related ONTAP commands
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
svm |
Example request
"svm": {
"name": "svm1",
Status: 201, Created
svm |
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9699478 |
Audit Log Redirect configuration already exists. |
9699479 |
Failed to create Audit Log Redirect configuration. |
9699483 |
Audit Log Redirect configuration not available. |
9699484 |
Failed to modify Audit Log Redirect configuration because all SVMs audit configuration must be deleted first. |
9699486 |
Audit Log Redirect feature is not available in maintenance mode. |
9699487 |
Node is not part of a cluster. |
9699488 |
SVM does not exist. |
9699489 |
Audit Log Redirect configuration only supported on Data SVM. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
audit_log_redirect
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
