REST API reference
Retrieve applications
Retrieves applications to access their specific configurations and details. Use this endpoint to gather information on applications for management and analysis purposes.
HTTP method and endpoint
GET /application/applications
Introduced in
ONTAP 9.6
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • <template> the property corresponding to the template.name of the application
Query examples
Numerous queries are available for classifying and sorting applications:
  1. Return a list of applications sorted by name.
      GET /application/applications?order_by=name
  2. Return a list of applications for a specific SVM.
      GET /application/applications?svm.name=<name>
  3. Return a list of all SQL applications.
      GET /application/applications?template.name=sql*
  4. Return a list of all applications that can be accessed via SAN.
      GET /application/applications?template.protocol=san
  5. Return the top five applications consuming the most IOPS.
      GET /application/applications?order_by=statistics.iops.total desc&max_records=5
The above examples are not comprehensive. There are many more properties available for queries. Also, multiple queries can be mixed and matched with other query parameters for a large variety of requests. See the per-property documentation below for the full list of supported query parameters.
Learn more
uuid
string
query
False
Filter by UUID
name
string
query
False
Filter by name
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
template.name
string
query
False
Filter by template.name
template.version
string
query
False
Filter by template.version
template.protocol
string
query
False
Filter by template.protocol
generation
string
query
False
Filter by generation
state
string
query
False
Filter by state
protection_granularity
string
query
False
Filter by protection granularity
rpo.is_supported
string
query
False
Filter by rpo.is_supported
rpo.local.name
string
query
False
Filter by rpo.local.name
rpo.local.description
string
query
False
Filter by rpo.local.description
rpo.remote.name
string
query
False
Filter by rpo.remote.name
rpo.remote.description
string
query
False
Filter by rpo.remote.description
rpo.components.name
string
query
False
Filter by rpo.components.name
rpo.components.uuid
string
query
False
Filter by rpo.components.uuid
rpo.components.rpo.local.name
string
query
False
Filter by rpo.components.rpo.local.name
  • Introduced in: 9.7
rpo.components.rpo.local.description
string
query
False
Filter by rpo.components.rpo.local.description
rpo.components.rpo.remote.name
string
query
False
Filter by rpo.components.rpo.remote.name
rpo.components.rpo.remote.description
string
query
False
Filter by rpo.components.rpo.remote.description
statistics.space.provisioned
string
query
False
Filter by statistics.space.provisioned
statistics.space.used
string
query
False
Filter by statistics.space.used
statistics.space.used_percent
string
query
False
Filter by statistics.space.used_percent
statistics.space.used_excluding_reserves
string
query
False
Filter by statistics.space.used_excluding_reserves
statistics.space.logical_used
string
query
False
Filter by statistics.space.logical_used
statistics.space.reserved_unused
string
query
False
Filter by statistics.space.reserved_unused
statistics.space.available
string
query
False
Filter by statistics.space.available
statistics.space.savings
string
query
False
Filter by statistics.space.savings
string
query
False
Filter by statistics.iops.total
statistics.iops.per_tb
string
query
False
Filter by statistics.iops.per_tb
statistics.snapshot.reserve
string
query
False
Filter by statistics.snapshot.reserve
statistics.snapshot.used
string
query
False
Filter by statistics.snapshot.used
statistics.latency.raw
string
query
False
Filter by statistics.latency.raw
statistics.latency.average
string
query
False
Filter by statistics.latency.average
statistics.statistics_incomplete
string
query
False
Filter by statistics.statistics_incomplete
statistics.shared_storage_pool
string
query
False
Filter by statistics.shared_storage_pool
statistics.components.name
string
query
False
Filter by statistics.components.name
statistics.components.uuid
string
query
False
Filter by statistics.components.uuid
statistics.components.storage_service.name
string
query
False
Filter by statistics.components.storage_service.name
statistics.components.space.provisioned
string
query
False
Filter by statistics.components.space.provisioned
statistics.components.space.used
string
query
False
Filter by statistics.components.space.used
statistics.components.space.used_percent
string
query
False
Filter by statistics.components.space.used_percent
statistics.components.space.used_excluding_reserves
string
query
False
Filter by statistics.components.space.used_excluding_reserves
statistics.components.space.logical_used
string
query
False
Filter by statistics.components.space.logical_used
statistics.components.space.reserved_unused
string
query
False
Filter by statistics.components.space.reserved_unused
statistics.components.space.available
string
query
False
Filter by statistics.components.space.available
statistics.components.space.savings
string
query
False
Filter by statistics.components.space.savings
statistics.components.iops.total
string
query
False
Filter by statistics.components.iops.total
statistics.components.iops.per_tb
string
query
False
Filter by statistics.components.iops.per_tb
statistics.components.snapshot.reserve
string
query
False
Filter by statistics.components.snapshot.reserve
statistics.components.snapshot.used
string
query
False
Filter by statistics.components.snapshot.used
statistics.components.latency.raw
string
query
False
Filter by statistics.components.latency.raw
statistics.components.latency.average
string
query
False
Filter by statistics.components.latency.average
statistics.components.statistics_incomplete
string
query
False
Filter by statistics.components.statistics_incomplete
statistics.components.shared_storage_pool
string
query
False
Filter by statistics.components.shared_storage_pool
smart_container
string
query
False
Filter by smart_container
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[application]
    "next": {
      "href": "/api/resourcelink"
  "records": [
        "snapshots": {
      "creation_timestamp": "string",
      "delete_data": null,
      "generation": 0,
      "maxdata_on_san": {
        "app_type": "string",
        "application_components": [
            "file_system": "string",
            "host_management_url": "string",
            "host_name": "string",
            "igroup_name": "string",
            "lun_count": 0,
            "metadata": [
                "key": "string",
                "value": "string"
            "name": "string",
            "protection_type": {
              "local_rpo": "string",
              "remote_rpo": "string"
            "storage_service": {
              "name": "string"
            "tiering": {
              "policy": "string"
            "total_size": 0
        "metadata": [
            "key": "string",
            "value": "string"
        "ocsm_url": "string",
        "os_type": "string"
      "mongo_db_on_san": {
        "dataset": {
          "size": 0,
            "name": "string"
        "os_type": "string",
        "primary_igroup_name": "string",
        "secondary_igroups": [
            "name": "string"
      "name": "string",
      "nas": {
            "export_policy": {
              "name": "string"
            "flexcache": {
              "origin": {
                "component": {
                  "name": "string"
                "svm": {
                  "name": "string"
            "name": "string",
            "qos": {
              "policy": {
                "name": "string",
                "uuid": "string"
            "share_count": 0,
              "name": "string"
            "tiering": {
              "policy": "string"
            "total_size": 0
        "cifs_access": [
            "access": "string",
            "user_or_group": "string"
        "exclude_aggregates": [
            "name": "string",
            "uuid": "string"
        "nfs_access": [
            "access": "string",
            "host": "string"
          "local_policy": "string",
      "nvme": {
        "components": [
            "name": "string",
            "performance": {
                "name": "string"
            "qos": {
              "policy": {
                "name": "string",
                "uuid": "string"
            "subsystem": {
              "hosts": [
                  "nqn": "string"
              "name": "string",
              "uuid": "string"
            "tiering": {
              "policy": "string"
        "rpo": {
          "local": {
            "name": "string",
            "policy": "string"
      "oracle_on_nfs": {
        "archive_log": {
            "name": "string"
        "db": {
          "size": 0,
            "name": "string"
        "nfs_access": [
            "access": "string",
            "host": "string"
        "ora_home": {
            "name": "string"
        "redo_log": {
          "size": 0,
            "name": "string"
      "oracle_on_san": {
        "archive_log": {
            "name": "string"
        "db": {
          "size": 0,
            "name": "string"
        "ora_home": {
            "name": "string"
        "redo_log": {
          "size": 0,
            "name": "string"
      "oracle_rac_on_nfs": {
        "archive_log": {
            "name": "string"
        "db": {
          "size": 0,
            "name": "string"
        "grid_binary": {
            "name": "string"
        "nfs_access": [
            "access": "string",
            "host": "string"
        "ora_home": {
            "name": "string"
        "oracle_crs": {
            "name": "string"
        "redo_log": {
          "size": 0,
            "name": "string"
      "oracle_rac_on_san": {
        "archive_log": {
            "name": "string"
        "db": {
          "size": 0,
            "name": "string"
        "db_sids": [
        "grid_binary": {
            "name": "string"
        "ora_home": {
            "name": "string"
        "oracle_crs": {
            "name": "string"
        "redo_log": {
          "size": 0,
            "name": "string"
      "protection_granularity": "string",
      "rpo": {
        "components": [
            "name": "string",
            "rpo": {
              "local": {
                "description": "string",
                "name": "string"
              "remote": {
                "name": "string"
            "uuid": "string"
        "local": {
          "name": "string"
        "remote": {
          "name": "string"
      "s3_bucket": {
            "access_policies": [
                "actions": [
                  "string"
                "conditions": [
                    "delimiters": [
                      "string"
                    "max_keys": [
                      "integer"
                    "operator": "string",
                    "prefixes": [
                      "string"
                    "source_ips": [
                      "string"
                    "usernames": [
                      "string"
                "effect": "string",
                "principals": [
                  "string"
                "resources": [
                  "string"
                "sid": "string"
            "comment": "string",
                "name": "string",
                "uuid": "string"
            "name": "string",
            "qos": {
              "policy": {
                "name": "string",
                "uuid": "string"
            "size": 0,
              "name": "string"
            "uuid": "string"
      "san": {
            "name": "string",
            "qos": {
              "policy": {
                "name": "string",
                "uuid": "string"
              "name": "string"
            "tiering": {
              "policy": "string"
            "name": "string",
            "uuid": "string"
      "sql_on_san": {
        "db": {
          "size": 0,
            "name": "string"
        "log": {
          "size": 0,
            "name": "string"
        "temp_db": {
            "name": "string"
      "sql_on_smb": {
        "access": {
          "installer": "string",
          "service_account": "string"
        "db": {
          "size": 0,
            "name": "string"
        "log": {
          "size": 0,
            "name": "string"
        "temp_db": {
            "name": "string"
      "state": "string",
      "statistics": {
        "components": [
            "iops": {
              "per_tb": 0,
              "total": 0
            "latency": {
              "average": 0,
              "raw": 0
            "name": "string",
            "snapshot": {
              "reserve": 0,
              "used": 0
            "space": {
              "available": 0,
              "logical_used": 0,
              "provisioned": 0,
              "reserved_unused": 0,
              "savings": 0,
              "used": 0,
              "used_excluding_reserves": 0,
              "used_percent": 0
              "name": "string",
              "uuid": "string"
            "uuid": "string"
        "iops": {
          "per_tb": 0,
          "total": 0
        "latency": {
          "average": 0,
          "raw": 0
        "snapshot": {
          "reserve": 0,
          "used": 0
        "space": {
          "available": 0,
          "logical_used": 0,
          "provisioned": 0,
          "savings": 0,
          "used": 0,
          "used_percent": 0
      "svm": {
        "name": "string",
        "uuid": "string"
      "template": {
        "name": "string",
        "protocol": "string",
        "version": 0
      "uuid": "string",
      "vdi_on_nas": {
        "desktops": {
          "size": 0,
            "name": "string"
        "hyper_v_access": {
        "nfs_access": [
            "access": "string",
            "host": "string"
      "vdi_on_san": {
        "desktops": {
          "size": 0,
            "name": "string"
        "hypervisor": "string",
      "vsi_on_nas": {
        "datastore": {
          "size": 0,
            "name": "string"
        "hyper_v_access": {
        "nfs_access": [
            "access": "string",
            "host": "string"
      "vsi_on_san": {
        "datastore": {
          "size": 0,
            "name": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
snapshots
metadata
key
string
Key to look up metadata associated with an application component.
value
string
Value associated with the key.
protection_type
local_rpo
string
The local rpo of the application component.
remote_rpo
string
The remote rpo of the application component.
storage_service
name
string
The storage service of the application component.
object_stores
maxdata_on_san_application_components_tiering
tiering
policy
string
The storage tiering type of the application component.
The list of application components to be created.
file_system
string
Defines the type of file system that will be installed on this application component.
host_management_url
string
The host management URL for this application component.
host_name
string
FQDN of the L2 host that contains the hot tier of this application component.
igroup_name
string
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup.
lun_count
integer
The number of LUNs in the application component.
metadata
array[metadata]
name
string
The name of the application component.
protection_type
protection_type
storage_service
storage_service
tiering
tiering
total_size
integer
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]}
metadata
key
string
Key to look up metadata associated with an application.
value
string
igroups
initiator_objects
maxdata_on_san_new_igroups
The list of initiator groups to create.
initiators
array[string]
maxdata_on_san
MAX Data application using SAN.
app_type
string
Type of the application that is being deployed on the L2.
array[maxdata_on_san_application_components]
metadata
array[metadata]
ocsm_url
string
The OnCommand System Manager URL for this application.
os_type
string
The name of the host OS running the application.
storage_service
name
string
The storage service of the database.
dataset
element_count
integer
The number of storage elements (LUNs for SAN) of the database to maintain. Must be an even number between 2 and 16. Odd numbers will be rounded up to the next even number within range.
replication_factor
integer
The number of data bearing members of the replicaset, including 1 primary and at least 1 secondary.
size
integer
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
mongo_db_on_san_new_igroups
initiators
array[string]
protection_type
local_rpo
string
The local RPO of the application.
remote_rpo
string
The remote RPO of the application.
secondary_igroups
name
string
The name of the initiator group for each secondary.
mongo_db_on_san
MongoDB using SAN.
dataset
dataset
os_type
string
primary_igroup_name
string
The initiator group for the primary.
protection_type
protection_type
secondary_igroups
array[secondary_igroups]
export_policy
id
integer
The ID of an existing NFS export policy.
name
string
The name of an existing NFS export policy.
component
name
string
Name of the source component.
svm
name
string
Name of the source SVM.
origin
component
component
svm
svm
flexcache
dr_cache
boolean
Dr-cache is a FlexCache volume create time option that has the same flexgroup-msid as that of the origin of a FlexCache volume. By default, dr-cache is disabled. The flexgroup-msid of the FlexCache volume does not need to be same as that of the origin of a FlexCache volume.
origin
origin
policy
name
string
The name of an existing QoS policy.
uuid
string
The UUID of an existing QoS policy. Usage: <UUID>
qos
policy
policy
nas_application_components_tiering
application-components.tiering
policy
string
export_policy
export_policy
flexcache
flexcache
name
string
qos
qos
scale_out
boolean
Denotes a Flexgroup.
share_count
integer
The number of shares in the application component.
storage_service
storage_service
tiering
total_size
integer
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]}
app_cifs_access
The list of CIFS access controls. You must provide either 'user_or_group' or 'access' to enable CIFS access.
access
string
The CIFS access granted to the user or group.
user_or_group
string
The name of the CIFS user or group that will be granted access.
exclude_aggregates
name
string
The name of the aggregate to exclude. Usage: <aggregate name>
uuid
string
The ID of the aggregate to exclude. Usage: <UUID>
app_nfs_access
The list of NFS access controls. You must provide either 'host' or 'access' to enable NFS access.
access
string
The NFS access granted.
host
string
The name of the NFS entity granted access.
protection_type
local_policy
string
The Snapshot copy policy to apply to each volume in the smart container. This property is only supported for smart containers. Usage: <snapshot policy>
local_rpo
string
remote_rpo
string
nas
A generic NAS application.
array[application_components]
cifs_access
array[app_cifs_access]
exclude_aggregates
array[exclude_aggregates]
nfs_access
array[app_nfs_access]
protection_type
protection_type
performance
storage_service
storage_service
hosts
nqn
string
The host NQN.
zapp_nvme_components_subsystem
components.subsystem
hosts
array[hosts]
name
string
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not.
os_type
string
The name of the host OS accessing the component. The default value is the host OS that is running the application.
uuid
string
The UUID of an existing subsystem to be granted access to the component. Usage: <UUID>
zapp_nvme_components_tiering
policy
string
components
name
string
namespace_count
integer
The number of namespaces in the component.
os_type
string
performance
performance
qos
qos
subsystem
tiering
total_size
integer
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]}
local
name
string
policy
string
rpo
local
local
zapp_nvme
An NVME application.
components
array[components]
os_type
string
rpo
rpo
storage_service
name
string
The storage service of the archive log.
archive_log
size
integer
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
db
size
integer
storage_service
storage_service
storage_service
name
string
The storage service of the ORACLE_HOME storage volume.
ora_home
size
integer
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the redo log group.
redo_log
mirrored
boolean
Specifies whether the redo log group should be mirrored.
size
integer
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
oracle_on_nfs
Oracle using NFS.
archive_log
archive_log
db
db
nfs_access
ora_home
ora_home
protection_type
protection_type
redo_log
redo_log
oracle_on_san_new_igroups
initiators
array[string]
oracle_on_san
Oracle using SAN.
archive_log
archive_log
db
db
igroup_name
string
ora_home
ora_home
os_type
string
protection_type
protection_type
redo_log
redo_log
storage_service
name
string
The storage service of the Oracle grid binary storage volume.
grid_binary
size
integer
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the Oracle CRS volume.
oracle_crs
copies
integer
The number of CRS volumes.
size
integer
The size of the Oracle CRS/voting storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
oracle_rac_on_nfs
Oracle RAC using NFS.
archive_log
archive_log
db
db
grid_binary
grid_binary
nfs_access
ora_home
ora_home
oracle_crs
oracle_crs
protection_type
protection_type
redo_log
redo_log
db_sids
igroup_name
string
oracle_rac_on_san_new_igroups
initiators
array[string]
oracle_rac_on_san
Oracle RAC using SAN.
archive_log
archive_log
db
db
db_sids
array[db_sids]
grid_binary
grid_binary
ora_home
ora_home
oracle_crs
oracle_crs
os_type
string
protection_type
protection_type
redo_log
redo_log
local
description
string
A detailed description of the local RPO. This will include details about the Snapshot copy schedule.
name
string
The local RPO of the component. This indicates how often component Snapshot copies are automatically created.
remote
description
string
A detailed description of the remote RPO.
name
string
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster.
rpo
local
local
remote
remote
components
name
string
Component Name.
rpo
rpo
uuid
string
Component UUID.
local
description
string
name
string
The local RPO of the application. This indicates how often application Snapshot copies are automatically created.
remote
description
string
name
string
The remote RPO of the application. A remote RPO of zero indicates that the application is synchronously replicated to another cluster.
rpo
components
array[components]
is_supported
boolean
Is RPO supported for this application? Generation 1 applications did not support Snapshot copies or MetroCluster.
local
local
remote
remote
zapp_s3_bucket_application_components_access_policies_conditions
conditions
delimiters
array[string]
max_keys
array[integer]
operator
string
Policy Condition Operator.
prefixes
array[string]
source_ips
array[string]
usernames
array[string]
The list of S3 objectstore policies to be created.
actions
array[string]
conditions
array[zapp_s3_bucket_application_components_access_policies_conditions]
conditions.
effect
string
Allow or Deny Access.
principals
array[string]
resources
array[string]
sid
string
Statement Identifier Usage: <(size 1..256)>
access_policies
array[zapp_s3_bucket_application_components_access_policies]
capacity_tier
boolean
Prefer lower latency storage under similar media costs.
comment
string
Object Store Server Bucket Description Usage: <(size 1..256)>
exclude_aggregates
name
string
qos
qos
size
integer
The total size of the S3 Bucket, split across the member components. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
uuid
string
Object Store Server Bucket UUID Usage: <UUID>
zapp_s3_bucket
A generic S3 bucket application.
array[zapp_s3_bucket_application_components]
policy
string
igroup_name
string
lun_count
integer
name
string
os_type
string
qos
qos
storage_service
storage_service
tiering
total_size
integer
san_new_igroups
initiators
array[string]
san
A generic SAN application.
exclude_aggregates
os_type
string
protection_type
protection_type
storage_service
name
string
The storage service of the DB.
db
size
integer
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
storage_service
name
string
The storage service of the log DB.
log
size
integer
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san_new_igroups
initiators
array[string]
storage_service
name
string
The storage service of the temp DB.
temp_db
size
integer
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
sql_on_san
Microsoft SQL using SAN.
db
db
igroup_name
string
log
log
os_type
string
protection_type
protection_type
server_cores_count
integer
The number of server cores for the DB.
temp_db
temp_db
access
installer
string
SQL installer admin user name.
service_account
string
SQL service account user name.
sql_on_smb
Microsoft SQL using SMB.
access
access
db
db
log
log
protection_type
protection_type
server_cores_count
integer
temp_db
temp_db
iops
per_tb
integer
The number of IOPS per terabyte of logical space currently being used by the application component.
total
integer
The total number of IOPS being used by the application component.
latency
average
integer
The cumulative average response time in microseconds for this component.
raw
integer
The cumulative response time in microseconds for this component.
snapshot
reserve
integer
The amount of space reserved by the system for Snapshot copies.
used
integer
The amount of spacing currently in use by the system to store Snapshot copies.
space
available
integer
The available amount of space left in the application component. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
  • readOnly: 1
logical_used
integer
The amount of space that would currently be used if no space saving features were enabled. For example, if compression were the only space saving feature enabled, this field would represent the uncompressed amount of space used.
provisioned
integer
The originally requested amount of space that was provisioned for the application component.
reserved_unused
integer
The amount of space reserved for system features such as Snapshot copies that has not yet been used.
savings
integer
The amount of space saved by all enabled space saving features.
used
integer
The amount of space that is currently being used by the application component. Note that this includes any space reserved by the system for features such as Snapshot copies.
integer
The amount of space that is currently being used, excluding any space that is reserved by the system for features such as Snapshot copies.
used_percent
integer
The percentage of the originally provisioned space that is currently being used by the application component.
storage_service
name
string
The storage service name. AFF systems support the extreme storage service. All other systems only support value.
uuid
string
The storage service UUID.
components
iops
iops
latency
latency
name
string
Component Name.
shared_storage_pool
boolean
An application component is considered to use a shared storage pool if storage elements for for other components reside on the same aggregate as storage elements for this component.
snapshot
snapshot
space
space
boolean
If not all storage elements of the application component are currently available, the returned statistics might only include data from those elements that were available.
storage_service
storage_service
uuid
string
Component UUID.
iops
per_tb
integer
The number of IOPS per terabyte of logical space currently being used by the application.
total
integer
The total number of IOPS being used by the application.
latency
average
integer
The cumulative average response time in microseconds for this application.
raw
integer
The cumulative response time in microseconds for this application.
space
available
integer
The available amount of space left in the application. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
  • readOnly: 1
  • Introduced in: 9.6
logical_used
integer
provisioned
integer
The originally requested amount of space that was provisioned for the application.
reserved_unused
integer
savings
integer
used
integer
The amount of space that is currently being used by the application. Note that this includes any space reserved by the system for features such as Snapshot copies.
integer
used_percent
integer
The percentage of the originally provisioned space that is currently being used by the application.
statistics
components
array[components]
iops
iops
latency
latency
shared_storage_pool
boolean
An application is considered to use a shared storage pool if storage elements for multiple components reside on the same aggregate.
snapshot
snapshot
space
space
boolean
If not all storage elements of the application are currently available, the returned statistics might only include data from those elements that were available.
svm
name
string
SVM Name. Either the SVM name or UUID must be provided to create an application.
uuid
string
SVM UUID. Either the SVM name or UUID must be provided to create an application.
self
template
_links
self_link
name
string
The name of the template that was used to provision this application.
protocol
string
The protocol access of the template that was used to provision this application.
version
integer
The version of the template that was used to provision this application. The template version changes only if the layout of the application changes over time. For example, redo logs in Oracle RAC templates were updated and provisioned differently in DATA ONTAP 9.3.0 compared to prior releases, so the version number was increased. If layouts change in the future, the changes will be documented along with the corresponding version numbers.
  • readOnly: 1
storage_service
name
string
The storage service of the desktops.
desktops
count
integer
The number of desktops to support.
size
integer
The size of the desktops. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
hyper_v_access
service_account
string
Hyper-V service account.
vdi_on_nas
A VDI application using NAS.
desktops
desktops
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vdi_on_san_new_igroups
initiators
array[string]
vdi_on_san
A VDI application using SAN.
desktops
desktops
hypervisor
string
The name of the hypervisor hosting the application.
igroup_name
string
protection_type
protection_type
storage_service
name
string
The storage service of the datastore.
datastore
count
integer
The number of datastores to support.
size
integer
The size of the datastore. Usage: {<integer>[KB|MB|GB|TB|PB]}
storage_service
storage_service
vsi_on_nas
A VSI application using NAS.
datastore
datastore
hyper_v_access
hyper_v_access
nfs_access
protection_type
protection_type
vsi_on_san_new_igroups
initiators
array[string]
vsi_on_san
A VSI application using SAN.
datastore
datastore
hypervisor
string
igroup_name
string
protection_type
protection_type
application
Applications
_links
_links
creation_timestamp
string
The time when the application was created.
generation
integer
The generation number of the application. This indicates which features are supported on the application. For example, generation 1 applications do not support Snapshot copies. Support for Snapshot copies was added at generation 2. Any future generation numbers and their feature set will be documented.
maxdata_on_san
maxdata_on_san
mongo_db_on_san
mongo_db_on_san
MongoDB using SAN.
name
string
Application Name. This field is user supplied when the application is created.
nas
nas
nvme
zapp_nvme
oracle_on_nfs
oracle_on_nfs
Oracle using NFS.
oracle_on_san
oracle_on_san
Oracle using SAN.
oracle_rac_on_nfs
oracle_rac_on_nfs
oracle_rac_on_san
oracle_rac_on_san
string
Protection granularity determines the scope of Snapshot copy operations for the application. Possible values are "application" and "component". If the value is "application", Snapshot copy operations are performed on the entire application. If the value is "component", Snapshot copy operations are performed separately on the application components.
rpo
rpo
s3_bucket
zapp_s3_bucket
san
san
smart_container
boolean
Identifies if this is a smart container or not.
sql_on_san
sql_on_san
sql_on_smb
sql_on_smb
state
string
The state of the application. For full functionality, applications must be in the online state. Other states indicate that the application is in a transient state and not all operations are supported.
statistics
statistics
svm
svm
template
template
uuid
string
Application UUID. This field is generated when the application is created.
vdi_on_nas
vdi_on_nas
vdi_on_san
vdi_on_san
vsi_on_nas
vsi_on_nas
vsi_on_san
vsi_on_san
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
