REST API reference
Retrieve CIFS protocol historical performance metrics for an SVM
Accesses historical performance metrics for the CIFS protocol of an SVM. This is useful for analyzing past performance trends and troubleshooting issues related to CIFS protocol operations.
HTTP method and endpoint
GET /protocols/cifs/services/{svm.uuid}/metrics
Introduced in
ONTAP 9.7
Usage notes
Retrieves historical performance metrics for the CIFS protocol of an SVM.
timestamp
string
query
False
Filter by timestamp
status
string
query
False
Filter by status
throughput.total
integer
query
False
Filter by throughput.total
throughput.other
integer
query
False
Filter by throughput.other
throughput.read
integer
query
False
Filter by throughput.read
throughput.write
integer
query
False
Filter by throughput.write
iops.total
integer
query
False
Filter by iops.total
iops.other
integer
query
False
Filter by iops.other
iops.read
integer
query
False
Filter by iops.read
iops.write
integer
query
False
Filter by iops.write
latency.total
integer
query
False
Filter by latency.total
latency.other
integer
query
False
Filter by latency.other
latency.read
integer
query
False
Filter by latency.read
latency.write
integer
query
False
Filter by latency.write
duration
string
query
False
Filter by duration
svm.uuid
string
path
True
Unique identifier of the SVM.
interval
string
query
False
The time range for the data. Examples can be 1h, 1d, 1m, 1w, 1y. The period for each time range is as follows:
  • 1h: Metrics over the most recent hour sampled over 15 seconds.
  • 1d: Metrics over the most recent day sampled over 5 minutes.
  • 1w: Metrics over the most recent week sampled over 30 minutes.
  • 1m: Metrics over the most recent month sampled over 2 hours.
  • 1y: Metrics over the most recent year sampled over a day.
  • Default value: 1
  • enum: ["1h", "1d", "1w", "1m", "1y"]
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "duration": "PT15S",
      "iops": {
        "read": "200",
        "total": "1000",
        "write": "100"
      "latency": {
        "read": "200",
        "total": "1000",
        "write": "100"
      "status": "ok",
      "throughput": {
        "read": "200",
        "total": "1000",
        "write": "100"
      "timestamp": "2017-01-25T11:20:13Z"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
records
Performance numbers, such as IOPS latency and throughput.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
