REST API reference
Retrieve the Vscan On-Access policy configuration for an SVM
Retrieves the Vscan On-Access policy configuration for a specific SVM to review its current settings. This is useful for managing and verifying the antivirus scanning policies applied to your storage resources.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/on-access-policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the Vscan On-Access policy configuration of an SVM.
  • vserver vscan on-access-policy show
  • vserver vscan on-access-policy file-ext-to-include show
  • vserver vscan on-access-policy file-ext-to-exclude show
  • vserver vscan on-access-policy paths-to-exclude show
name
string
path
True
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
enabled
boolean
Status of the On-Access Vscan policy
mandatory
boolean
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.
name
string
On-Access policy ame
scope
scope
  "name": "on-access-test",
  "scope": {
    "exclude_extensions": [
      "mp*",
      "txt"
    "exclude_paths": [
      "\\dir1\\dir2\\name",
      "\\vol\\a b",
      "\\vol\\a,b\\"
    "include_extensions": [
      "mp*",
      "txt"
    "max_file_size": "2147483648"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
only_execute_access
boolean
Scan only files opened with execute-access.
scan_readonly_volumes
boolean
Specifies whether or not read-only volume can be scanned.
scan_without_extension
boolean
Specifies whether or not files without any extension can be scanned.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
