REST API reference
Retrieve a specific user account
Retrieves details about a specific user account, which helps you manage access and permissions within your ONTAP environment.
HTTP method and endpoint
GET /security/accounts/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific user account.
  • security login show
owner.uuid
string
path
True
Account owner UUID
name
string
path
True
User account name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
applications
array[account_application]
comment
string
Optional comment for the user account.
locked
boolean
Locked status of the account.
name
string
User or group account name
owner
owner
Owner name and UUID that uniquely identifies the user account.
role
role
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
      "href": "/api/resourcelink"
  "applications": [
      "application": "string",
      "authentication_methods": [
        "string"
      "second_authentication_method": "string"
  "comment": "string",
  "name": "joe.smith",
  "owner": {
    "name": "svm1",
  "role": {
    "name": "admin"
  "scope": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
account_application
application
string
Applications
array[string]
string
An optional additional authentication method for MFA. This only works with SSH as the application. It is ignored for all other applications.
owner
_links
_links
name
string
The name of the SVM.
uuid
string
role
_links
_links
name
string
Role name
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
