REST API reference
Retrieve key servers configured in an external key manager
Retrieves information about key servers that are configured in an external key manager. Use this to assess and manage key server configurations for secure data management.
HTTP method and endpoint
GET /security/key-managers/{uuid}/key-servers/{server}
Introduced in
ONTAP 9.6
Usage notes
Retrieves key servers configured in an external key manager.
  • security key-manager external show
  • security key-manager external show-status
uuid
string
path
True
External key manager UUID
server
string
path
True
Key server configured in the key manager.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
password
string
Password credentials for connecting with the key server. This is not audited.
secondary_key_servers
array[string]
A list of the secondary key servers associated with the primary key server.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if records is provided.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
KMIP username credentials for connecting with the key server.
      "href": "/api/resourcelink"
  "password": "password",
  "secondary_key_servers": [
    "string"
  "server": "keyserver1.com:5698",
  "timeout": "60",
  "username": "username"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
records
_links
_links
password
string
array[string]
server
string
timeout
integer
username
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
