Retrieve a QoS policy
Retrieves details of a specific QoS policy, which helps you manage and monitor quality of service settings for storage performance.
HTTP method and endpoint
GET /storage/qos/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific QoS policy.
Related ONTAP commands
qos policy-group show -
qos adaptive-policy-group show
uuid |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
adaptive |
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space. |
fixed |
QoS policy-groups define a fixed service level objective (SLO) for a storage object. |
name |
string |
Name of the QoS policy. |
object_count |
integer |
Number of objects attached to this policy. |
svm |
uuid |
string |
"href": "/api/resourcelink"
"name": "extreme",
"object_count": 0,
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
adaptive
absolute_min_iops |
integer |
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
expected_iops |
integer |
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
peak_iops |
integer |
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size. |
fixed
capacity_shared |
boolean |
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false. |
max_throughput_iops |
integer |
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced. |
max_throughput_mbps |
integer |
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced. |
min_throughput_iops |
integer |
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
min_throughput_mbps |
integer |
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
