REST API reference
Update the Vscan On-Demand policy configuration for an SVM
Updates the Vscan On-Demand policy configuration for an SVM. Use this endpoint to modify or set the schedule for an On-Demand scan using the schedule name or schedule UUID.
HTTP method and endpoint
PATCH /protocols/vscan/{svm.uuid}/on-demand-policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Updates the Vscan On-Demand policy configuration of an SVM. Use schedule name or schedule UUID to schedule an On-Demand scan.
  • vserver vscan on-demand-task modify
  • vserver vscan on-demand-task schedule
  • vserver vscan on-demand-task unschedule
name
string
path
True
svm.uuid
string
path
True
Request Body
Name Type Description
log_path
string
The path from the Vserver root where the task report is created.
scan_paths
array[string]
List of paths that need to be scanned.
schedule
schedule
Schedule of the task.
scope
scope
Example request
  "log_path": "/vol0/report_dir",
  "scan_paths": [
    "/vol1/",
    "/vol2/cifs/"
  "schedule": {
    "name": "weekly",
  "scope": {
    "exclude_extensions": [
      "mp3",
      "mp4"
    "exclude_paths": [
      "/vol1/cold-files/",
      "/vol1/cifs/names"
    "include_extensions": [
      "vmdk",
      "mp*"
    "max_file_size": "10737418240"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10027101
The file size must be in the range 1KB to 1TB
10027107
The include extensions list cannot be empty. Specify at least one extension for inclusion.
10027164
An On-Demand policy cannot be scheduled, as the Vscan is disabled. Enable the Vscan and retry the operation.
10027167
The specified schedule does not exist. Create the schedule or create a policy without specifying the schedule.
10027168
The specified scan path does not exist. The scan path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use “/” not “\”)
10027169
The specified scan path is not supported for scanning.
10027174
The specified exclude path is invalid. The path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use "/" not "\")
10027175
An On-Demand policy cannot be scheduled as the SVM is not in an operational state.
10027176
The log-path specified does not exist. The log path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use “/” not “\”)
10027177
The log path specified is not supported.
10027253
The number of paths specified exceeds the configured maximum number of paths. You cannot specify more than the maximum number of configured paths.
10027254
The number of extensions specified exceeds the configured maximum number of extensions. You cannot specify more than the maximum number of configured extensions.
10027255
Another policy is already scheduled. Only one policy per SVM is allowed to be scheduled at any one time. Update a policy without specifying a schedule.
string
schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
scan_without_extension
boolean
Specifies whether or not files without any extension can be scanned.
vscan_on_demand
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path
string
scan_paths
array[string]
schedule
schedule
scope
scope
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
