REST API reference
Update the access level for a REST API path or command/command directory path
Updates the privilege level for a specific REST API path, ensuring the appropriate access control for various operations. Use this when you need to adjust access permissions to align with your security requirements.
HTTP method and endpoint
PATCH /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Updates the privilege level for a REST API path.
Required parameters
  • owner.uuid - UUID of the SVM that houses this role.
  • name - Name of the role to be updated.
  • path - Constituent REST API path whose access level has to be updated.
  • access - Access level for the path (one of "all", "readonly", or "none")
  • security login rest-role modify
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
path
string
path
True
REST API path
Request Body
Name Type Description
access
string
Access level for the REST endpoint.
Example request
  "access": "readonly"
Status: 200, Ok
Status: Default, Error
string
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
access
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
