Update the SnapMirror policy
Updates SnapMirror policies to adjust configurations such as retention and transfer schedules. This helps you manage data replication settings according to your requirements.
HTTP method and endpoint
PATCH /snapmirror/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the SnapMirror policy.
Important notes
The properties "retention.label" and "retention.count" are mandatory if "retention" is provided in the input. The provided "retention.label" is the final list and it replaces the existing values.
The value of the "identity_preservation" property cannot be changed if the SnapMirror relationships associated with the policy have different identity_preservation configurations.
If the SnapMirror policy "identity_preservation" value matches the "identity_preservation" value of the associated SnapMirror relationships, then the "identity_preservation" value can be changed from a higher "identity_preservation" threshold value to a lower "identity_preservation" threshold value but not vice-versa. For example, the threshold value of the "identity_preservation" property can be changed from "full" to "exclude_network_config" to "exclude_network_and_protocol_config", but could not be increased from "exclude_network_and_protocol_config" to "exclude_network_config" to "full".
The policy properties "copy_all_source_snapshots", "copy_latest_source_snapshot", and "create_snapshot_on_source" cannot be modified.
No "retention" properties can be modified if the "copy_all_source_snapshots" or "copy_latest_source_snapshot" property is present in the policy.
Replacing or deleting all retention rules of a policy that has the "create_snapshot_on_source" property set to false in a single API call is not supported.
Modifying the property "retention.label" for all retention rules of a policy that has the "create_snapshot_on_source" property set to false in a single API call is not supported.
To remove a transfer_schedule on a SnapMirror policy set the "transfer_schedule" to null (no-quotes) during SnapMirror policy PATCH.
Related ONTAP commands
snapmirror policy modify
Example
Updating the "retention" property
PATCH "/api/snapmirror/policies/fe65686d-00dc-11e9-b5fb-0050568e3f83" '{"retention": [{"label": "newlabel", "count": 2}, {"label": "weekly", "count": 2, "creation_schedule": {"name": "weekly"}}, {"label": "daily", "count": 14}]}'
Updating "transfer_schedule", "throttle", and "identity_preservation" properties
PATCH "/api/snapmirror/policies/8aef950b-3bef-11e9-80ac-0050568ea591" '{"transfer_schedule.name" : "weekly", "throttle" : "100", "identity_preservation":"exclude_network_and_protocol_config"}'
Removing the SnapMirror transfer_schedule for a SnapMirror policy. Transfer_schedule can be specified as UUID or name or both with the value set to null (no-quotes).
PATCH "/api/snapmirror/policies/98bb2608-fc60-11e8-aa13-005056a707ff/" '{"transfer_schedule":{"uuid":null, "name":null}}'
Learn more
uuid |
string |
path |
True |
Policy UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Comment associated with the policy. |
identity_preservation |
string |
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type. |
network_compression_enabled |
boolean |
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async". |
retention |
array[snapmirror_policy_rule] |
Policy on Snapshot copy retention. |
scope |
string |
Set to "svm" for policies owned by an SVM, otherwise set to "cluster". |
sync_common_snapshot_schedule |
Schedule used to create common Snapshot copies for synchronous relationships. |
throttle |
integer |
Throttle in KB/s. Default to unlimited. |
transfer_schedule |
The schedule used to update asynchronous relationships. |
uuid |
string |
Example request
"comment": "string",
"copy_all_source_snapshots": 1,
"copy_latest_source_snapshot": 1,
"create_snapshot_on_source": "",
"identity_preservation": "string",
"retention": [
"count": "7",
"name": "weekly",
"label": "hourly",
"prefix": "string"
"scope": "string",
"sync_common_snapshot_schedule": {
"name": "weekly",
"throttle": 0,
"transfer_schedule": {
"name": "weekly",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303842 |
SnapMirror policy is not supported. |
13303843 |
Conflicting values between SnapMirror policy and SnapMirror relationships for either 'transfer_schedule, throttle or identity_preservation' properties |
13303850 |
Invalid input parameter |
13303887 |
Failed to create SnapMirror policy. Reason: Maximum number of allowed retention rules reached |
href |
string |
_links
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
SnapMirror policy rule for retention.
count |
integer |
Number of Snapshot copies to be kept for retention. |
creation_schedule |
Schedule used to create Snapshot copies on the destination for long term retention. |
label |
string |
Snapshot copy label |
prefix |
string |
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
transfer_schedule
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapmirror_policy
SnapMirror policy information. SnapMirror policy can either be of type "async" or "sync". The policy type "async" can be associated with a SnapMirror relationship that has either the FlexVol volume or FlexGroup volume or SVM as the endpoint. The policy type "sync" along with "sync_type" as "sync" or "strict_sync" can be associated with a SnapMirror relationship that has FlexVol volume as the endpoint. The policy type "sync" can have a "sync_type" of either "sync", "strict_sync" or "automated_failover". If the "sync_type" is "sync" then a write success is returned to the client after writing the data to the source endpoint and before writing the data to the destination endpoint. If the "sync_type" is "strict_sync" then a write success is returned to the client after writing the data to the both source and destination endpoints. If the "sync_type" is "automated_failover" then the policy can be associated with a SnapMirror relationship that has Consistency Group as the endpoint. Use the "sync" policy with "sync_type" as "automated_failover" to establish SnapMirror relationships for business continuity usecases. SnapMirror relationships with policy type as "sync" and "sync_type" as "automated_failover" can be monitored by the Mediator, if configured. In case the source Consistency Group endpoint is not reachable, the Mediator may trigger a failover to the destination Consistency Group endpoint.
comment |
string |
string |
boolean |
retention |
scope |
string |
throttle |
integer |
transfer_schedule |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
