REST API reference
Create a quota policy rule for a FlexVol or a FlexGroup volume
Creates a quota policy rule for a FlexVol or a FlexGroup volume to manage and enforce storage limits within your volumes effectively.
HTTP method and endpoint
POST /storage/quota/rules
Introduced in
ONTAP 9.6
Usage notes
Important notes:
  • Unlike CLI/ONTAPI, the quota policy input is not needed for POST.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the qtree.
  • volume.uuid or volume.name - Existing volume in which to create the qtree.
  • type - Quota type for the rule. This type can be user, group, or tree.
  • users.name or user.id - If the quota type is user, this property takes the user name or user ID. For default user quota rules, the user name must be specified as "".
  • group.name or group.id - If the quota type is group, this property takes the group name or group ID. For default group quota rules, the group name must be specified as "".
  • qtree.name - Qtree for which to create the rule. For default tree rules, the qtree name must be specified as "".
  • space.hard_limit - Specifies the space hard limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes.
  • space.soft_limit - Specifies the space soft limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes.
  • files.hard_limit - Specifies the hard limit for files.
  • files.soft_limit - Specifies the soft limit for files.
  • user_mapping - Specifies the user_mapping. This property is valid only for quota policy rules of type user.
  • quota policy rule create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
files
files
group
group
This parameter specifies the target group to which the group quota policy rule applies. This parameter takes a group name or identifier. This parameter is only valid for the POST operation of a group quota policy rule. The POST operation will fail with an appropriate error if this parameter is used as an input to create a user or a tree quota policy rule. This input parameter for POST takes either a group name or a group identifier, but not both. For default quota rules, the group name must be chosen and should be specified as "". For explicit group quota rules, this parameter can contain a UNIX group name or a UNIX group identifier.
qtree
qtree
This parameter specifies the target qtree to which the user/group/tree quota policy rule applies. For a user/group quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST. For a user/group quota policy rule at volume level, this parameter is not valid in GET or POST. For a tree quota policy rule, this parameter is mandatory and is valid in both POST and GET. For a default tree quota policy rule, this parameter needs to be specified as "". For a tree quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST.
space
space
svm
svm
type
string
This parameter specifies the quota policy rule type. This is required in POST only and can take either one of the "user", "group" or "tree" values.
user_mapping
boolean
This parameter enables user mapping for user quota policy rules. This is valid in POST or PATCH for user quota policy rules only.
users
array[users]
This parameter specifies the target user to which the user quota policy rule applies. This parameter takes single or multiple user names or identifiers. This parameter is valid only for the POST operation of a user quota policy rule. If this parameter is used as an input to create a group or a tree quota policy rule, the POST operation will fail with an appropriate error. For POST, this input parameter takes either a user name or a user identifier, not both. For default quota rules, the user name must be chosen and specified as "". For explicit user quota rules, this parameter can indicate either a user name or user identifier. The user name can be a UNIX user name or a Windows user name. If a name contains a space, enclose the entire value in quotes. A UNIX user name cannot include a backslash () or an @ sign; user names with these characters are treated as Windows names. The user identifer can be a UNIX user identifier or a Windows security identifier. For multi-user quota, this parameter can contain multiple user targets separated by a comma.
uuid
string
Unique identifier for the quota policy rule. This field is generated when the quota policy rule is created.
volume
volume
Example request
  "group": {
    "id": "string",
    "name": "string"
  "qtree": {
    "id": "1",
    "name": "qt1"
  "svm": {
    "name": "svm1",
  "type": "string",
  "users": [
      "id": "string",
      "name": "string"
  "uuid": "5f1d13a7-f401-11e8-ac1a-005056a7c3b9",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
917927
The specified volume was not found.
918232
Either volume.name or volume.uuid must be provided.
918236
The specified volume.uuid and volume.name refer to different volumes.
2621462
The specified SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5308501
Mapping from Windows user to UNIX user for user rule was unsuccessful.
5308502
Mapping from UNIX user to Windows user for user rule was unsuccessful.
5308552
Failed to get default quota policy name for SVM.
5308561
Failed to obtain volume quota state or invalid quota state obtained for volume.
5308562
users is a required input for creating a user rule and group is not allowed.
5308563
group is a required input for creating a group rule and users is not allowed.
5308564
qtree.name is a required input for creating a tree rule and users and group are not allowed.
5308565
Only one of name or id is allowed for each entry in the users array.
5308566
Only one of name or id is allowed for group.
5308568
Quota policy rule create operation succeeded, but quota resize failed due to internal error. To activate the rule, disable and enable quotas for this volume.
5308571
Quota policy rule create operation succeeded, but quota resize is skipped. To activate the rule, disable and enable quotas for this volume.
5308573
Input value is greater than limit for field.
5308574
Input value is out of range for field.
5308575
Input value is incorrectly larger than listed field.
string
files
hard_limit
integer
This parameter specifies the hard limit for files. This is valid in POST or PATCH.
soft_limit
integer
This parameter specifies the soft limit for files. This is valid in POST or PATCH.
group
id
string
Quota target group ID
name
string
Quota target group name
qtree
id
integer
The unique identifier for a qtree.
name
string
The name of the qtree.
space
hard_limit
integer
This parameter specifies the space hard limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.
soft_limit
integer
This parameter specifies the space soft limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.
svm
name
string
The name of the SVM.
uuid
string
users
id
string
Quota target user ID
name
string
Quota target user name
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
quota_rule
files
files
group
group
qtree
qtree
space
space
svm
svm
type
string
user_mapping
boolean
users
array[users]
uuid
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
