Protocols NFS export-policies endpoint overview
Export Policies
1) Retrieve the export policy details
# The API: GET /api/protocols/nfs/export-policies # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies"
2) Create an export policy for an SVM
# The API: POST /api/protocols/nfs/export-policies # The call: curl -d "@test_post_policy_single_rule.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies" test_post_policy_single_rule.txt(body): { "name": "P1", "rules":[ { "clients": [ { "match": "host1" } ], "ro_rule": [ "krb5" ], "rw_rule": [ "ntlm" ], "anonymous_user": "anon1", "chown_mode": "restricted", "allow_suid": true }, { "clients": [ { "match": "host2" } ], "ro_rule": [ "sys" ], "rw_rule": [ "ntlm" ], "superuser": [ "any" ], "allow_device_creation": true, "ntfs_unix_security": "fail" } ] }
3) Update an export policy for an SVM
# The API: PATCH /api/protocols/nfs/export-policies/{policy.id} # The call: curl -d "@test_patch_policy.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934594" test_patch_policy.txt(body): { "name": "S1", "rules":[ { "clients": [ { "match": "host4" } ], "ro_rule": [ "krb5" ], "rw_rule": [ "ntlm" ] } ] }
4) Delete an export policy for an SVM
# The API: DELETE /api/protocols/nfs/export-policies/{policy.id} # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934594"
Export Rules
1) Retrieve the export policy rule details for an export policy
# The API: GET /api/protocols/nfs/export-policies/{policy.id}/rules # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules"
2) Create an export policy rule for an export policy
# The API: POST /api/protocols/nfs/export-policies/{policy.id}/rules # The call: curl -d "@test_patch_export_rule.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules" test_patch_export_rule.txt(body): { "clients": [ { "match": "host2" } ], "ro_rule": [ "sys" ], "rw_rule": [ "ntlm" ] }
3) Update an export policy rule for an export policy
# The API: PATCH /api/protocols/nfs/export-policies/{policy.id}/rules/{index} # The call: curl -d "@test_patch_export_rule.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules/5?new_index=10" test_patch_export_rule.txt(body): { "clients": [ { "match": "host4" } ], "ro_rule": [ "sys" ], "rw_rule": [ "krb5" ] }
4) Delete an export policy rule for an export policy
# The API: DELETE /api/protocols/nfs/export-policies/{policy.id}/rules/{index} # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules/15"
Export Clients
1) Retrieve the export client matches of an export policy rule
# The API: GET /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/2/clients"
2) Add an export client match to an export policy rule
# The API: POST /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients # The call: curl -d "@add_client_match.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/1/clients" add_client_match.txt(body): { "match" : "host4" }
3) Delete an export client match from an export policy rule
# The API: DELETE /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients/{match} # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/1/clients/host1,host2"
