REST API reference
ONTAP REST API Storage volumes volume.uuid files path endpoints
Overview
This API is used to read a file, write to a file, retrieve a list of files and directories, and retrieve or modify certain properties of files and directories. The path field is used to specify the path to the directory or file to be acted on. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided.
File data
Read and write data from/to a named file. To read a file, the Accept request HTTP header must be specified as multipart/form-data, and a value for the length query property, which represents the number of bytes to be read, must be specified. The API will fail if the length of data being read/written exceeds 1 MB. This API should only be used on normal files or streams associated with files. The results for other file types, such as LUNs is undefined.
The following APIs are used to read or write data to a file:
– GET /api/storage/volumes/{volume.uuid}/files/{path}?byte_offset=0&length=40 -H "Accept: multipart/form-data"
– POST /api/storage/volumes/{volume.uuid}/files/{path} -H "Content-Type: multipart/form-data" --form "file=the data to be written to the new file"
– PATCH /api/storage/volumes/{volume.uuid}/files/{path}?byte_offset=10 -H "Content-Type: multipart/form-data" --form "file=the new data to be written or overwritten to the existing file starting at byte_offset"
Listing directories and files
A list of files and directories and their properties can be retrieved for a specified path.
The following APIs are used to view a list of files and directories:
– GET /api/storage/volumes/{volume.uuid}/files/{path}?fields=*
File information
The metadata and detailed information about a single directory or file can be retrieved by setting the return_metadata query property to true. The information returned includes type, creation_time, modified_time, changed_time, accessed_time, unix_permissions, ownder_id, group_id, size, hard_links_count, inode_number, is_empty, bytes_used, unique_bytes, inode_generation, is_vm_aligned, is_junction, links, and analytics (if requested).
The following API is used to view the properties of a single file or directory:
– GET /api/storage/volumes/{volume.uuid}/files/{path}?return_metadata=true
File usage
Custom details about the usage of a file can be retrieved by specifying a value for the byte_offset and length query properties.
The following API is used to view the unique bytes, and bytes used, by a file based on the range defined by byte_offset and length:
– GET /api/storage/volumes/{volume.uuid}/files/{path}?return_metadata=true&byte_offset={int}&length={int}
Create a directory
The following API is used to create a directory:
– POST /api/storage/volumes/{volume.uuid}/files/{path} -d '{ "type" : "directory", "unix-permissions" : "644"}'
Delete an entire directory
A directory can be deleted. The behavior of this call is equivalent to rm -rf.
The following API is used to delete an entire directory:
– DELETE /api/storage/volumes/{volume.uuid}/files/{path}?recurse=true
Delete a file or an empty directory
The following API is used to delete a file or an empty directory:
– DELETE /api/storage/volumes/{volume.uuid}/files/{path}?recurse=false
File system analytics
File system analytics provide a quick method for obtaining information summarizing properties of all files within any directory tree of a volume. When file system analytics are enabled on a volume, analytics.* fields may be requested, and will be populated in the response records corresponding to directories. The API does not support file system analytics for requests that are made beyond the boundary of the specified volume.uuid.
The following APIs are used to obtain analytics information for a directory:
– GET /api/storage/volumes/{volume.uuid}/files/{path}?fields=analytics
– GET /api/storage/volumes/{volume.uuid}/files/{path}?fields=**
QoS
QoS policies and settings enforce Service Level Objectives (SLO) on a file. A pre-created QoS policy can be used by specifying the qos.name or qos.uuid properties.
The following APIs are used to assign a QoS policy to a file:
– PATCH /api/storage/volumes/{volume.uuid}/files/{path} -d '{ "qos_policy.name" : "policy" }'
– PATCH /api/storage/volumes/{volume.uuid}/files/{path} -d '{ "qos_policy.uuid" : "b89bc5dd-94a3-11e8-a7a3-0050568edf84" }'
The following APIs are used to create a symlink and read the contents of a symlink:
– POST /api/storage/volumes/{volume.uuid}/files/{path} -d '{ "target" : "directory2/file1" }'
– GET /api/storage/volumes/{volume.uuid}/files/{path}?return_metadata=true&fields=target
Rename a file or a directory
The following API can be used to rename a file or a directory. Note that you need to provide the path relative to the root of the volume in the path body parameter.
– PATCH /api/storage/volumes/{volume.uuid}/files/{path} -d '{ "path" : "directory1/directory2" }'
– PATCH /api/storage/volumes/{volume.uuid}/files/{path} -d '{ "path" : "directory1/directory2/file1" }'
Writing to a new file
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/volumes/54c06ce2-5430-11ea-90f9-005056a73aff/files/aNewFile" -H "Content-Type: multipart/form-data" --form "file=the data to be written to the new file"
Writing to an existing file
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/volumes/54c06ce2-5430-11ea-90f9-005056a73aff/files/aNewFile?byte_offset=39" -H "Content-Type: multipart/form-data" --form "file=*here is a little more data"
Reading a file
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/54c06ce2-5430-11ea-90f9-005056a73aff/files/aNewFile?byte_offset=0&length=100" -H "Accept: multipart/form-data"
# Response for file data:
--ec51b3541741ade7
Content-Disposition: form-data; name="bytes_read"
Content-Type: text/plain
66
--ec51b3541741ade7
Content-Disposition: form-data; filename="aNewFile"
Content-Type: application/octet-stream
the data to be written to the new file*here is a little more data
--ec51b3541741ade7--
Creating a directory
You can use the POST request to create a directory.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/dir1"  -H 'accept: application/hal+json' -d '{ "type" : "directory", "unix_permissions" : "644" }'
# The response:
"num_records": 1,
"records": [
    "path": "dir1",
    "type": "directory",
    "unix_permissions": 644
Creating a stream on a file
# The API:
POST /api/storage/volumes/{volume.uuid}/files/{path}?overwrite=true
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/volumes/54c06ce2-5430-11ea-90f9-005056a73aff/files/aNewFile?overwrite=true&byte_offset=-1&stream_name=someStream" -H "Content-Type: multipart/form-data" --form "file=the data to be written to the new file"
Retrieving the list of files in a directory
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/d1%2Fd2%2Fd3"
# Response for file records:
"records": [
    "path": "d1/d2/d3",
    "name": ".",
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d1%2Fd2%2Fd3%2F%2E"
      "metadata": {
        "href": "/api/storage/volumes/e8274d79-3bba-11ea-b780-005056a7d72a/files/d1%2Fd2%2Fd3%2F%2E?return_metadata=true"
    "path": "d1/d2/d3",
    "name": "..",
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d1%2Fd2%2Fd3%2F%2E%2E"
      "metadata": {
        "href": "/api/storage/volumes/e8274d79-3bba-11ea-b780-005056a7d72a/files/d1%2Fd2%2Fd3%2F%2E%2E?return_metadata=true"
    "path": "d1/d2/d3",
    "name": "f1",
    "type": "file",
      "metadata": {
        "href": "/api/storage/volumes/e8274d79-3bba-11ea-b780-005056a7d72a/files/d1%2Fd2%2Fd3%2File1?return_metadata=true"
    "path": "d1/d2/d3",
    "name": "d5",
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d1%2Fd2%2Fd3%2Fd5"
      "metadata": {
        "href": "/api/storage/volumes/e8274d79-3bba-11ea-b780-005056a7d72a/files/d1%2Fd2%2Fd3%2Fd5?return_metadata=true"
"num_records": 4,
    "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d1%2Fd2%2Fd3"
Retrieving a list of files based on file type
You can filter the list of files you retrieve based on multiple file types by including a query parameter in the following format type="file\|symlink"
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/d1%2Fd2%2Fd3?type=file&#124;directory"
"records": [
    "path": "d1/d2/d3",
    "name": ".",
      "metadata": {
    "path": "d1/d2/d3",
    "name": "..",
      "metadata": {
    "path": "d1/d2/d3",
    "name": "f1",
    "type": "file",
      "metadata": {
    "path": "d1/d2/d3",
    "name": "d5",
      "metadata": {
"num_records": 4,
Retrieving the properties of a directory or a file
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/d1%2Fd2%2Fd3%2Ff1?return_metadata=true"
# Response for file properties:
"records": [
    "path": "d1/d2/d3/f1",
    "name": "",
    "type": "file",
    "creation_time": "2019-06-12T21:27:28-04:00",
    "modified_time": "2019-06-12T21:27:28-04:00",
    "changed_time": "2019-06-12T21:27:28-04:00",
    "accessed_time": "2019-06-12T21:27:28-04:00",
    "unix_permissions": 644,
    "owner_id": 54738,
    "group_id": 30,
    "size": 200,
    "hard_links_count": 1,
    "inode_number": 1233,
    "bytes_used": 4096,
    "unique_bytes": 4096,
    "inode_generation": 214488325,
    "is_vm_aligned": false,
    "is_junction": false
"num_records": 1,
    "href": "/api/storage/volumes/da8bb06c-823e-11e9-b790-005056acdcb0/files/d1%2Fd2%2Fd3%2Ff1?return_metadata=true"
You can use the POST request to create a symlink.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/symlink1"  -H 'accept: application/hal+json' -d '{ "target" : "d1/f1"}'
# The response:
"num_records": 1,
"records": [
    "path": "symlink1",
    "target": "d1/f1"
You can use the GET request to view the target of a symlink.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/symlink1?return_metadata=true&fields=target"
# The response:
"records": [
    "path": "symlink1",
    "target": "d1/f1"
"num_records": 1,
    "href": "/api/storage/volumes/54c06ce2-5430-11ea-90f9-005056a73aff/files/symlink1?return_metadata=true&fields=target"
Retrieving the usage information for a file
You can use the GET request to retrieve the unique bytes held in a file with or without specifing the offset.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/f1?return_metadata=true&byte_offset=100&length=200"
# The response:
"records": [
    "type": "file",
    "owner_id": 54738,
    "group_id": 30,
    "size": 200,
    "bytes_used": 4096,
"num_records": 1,
    "href": "/api/storage/volumes/cb6b139-8d21-11e9-b926-05056aca658/files/f1?return_metadata=true&byte_offset=100&length=200"
Retrieving all information (including analytics) for a directory
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/1ef5d1b2-f9d7-11e9-8043-00505682f860/files/d1?return_metadata=true&fields=**"
# Response for all fields of the directory:
"records": [
    "svm": {
      "uuid": "58a996a2-f9d5-11e9-8043-00505682f860",
          "href": "/api/svm/svms/58a996a2-f9d5-11e9-8043-00505682f860"
    "volume": {
        "uuid": "1ef5d1b2-f9d7-11e9-8043-00505682f860",
            "href": "/api/storage/volumes/1ef5d1b2-f9d7-11e9-8043-00505682f860"
    "path": "d1",
    "creation_time": "2019-10-28T23:04:13+00:00",
    "modified_time": "2019-10-28T23:10:30+00:00",
    "changed_time": "2019-10-28T23:10:30+00:00",
    "accessed_time": "2019-10-28T23:10:38+00:00",
    "unix_permissions": 755,
    "owner_id": 1002,
    "group_id": 65533,
    "size": 4096,
    "hard_links_count": 5,
    "inode_number": 96,
    "is_empty": false,
    "bytes_used": 4096,
    "inode_generation": 214514951,
    "is_junction": false,
    "analytics": {
      "file_count": 668,
      "bytes_used": 209657856,
      "subdir_count": 18,
      "by_modified_time": {
        "bytes_used": {
          "values": [
            0,
            0,
            0,
            0,
            3112960,
            0,
            14041088,
            20545536,
            0,
            57933824,
            61947904,
            68804608,
            188686336,
            0,
            0,
            0,
            20971520,
            0
          "percentages": [
            0,
            0,
            0,
            0,
            1.48,
            0,
            6.7,
            9.8,
            0,
            27.63,
            29.55,
            32.82,
            90,
            0,
            0,
            0,
            10,
            0
          "labels": [
            "2019-W42",
            "2019-W41",
            "2019-W40",
            "2019-W39",
            "2019-W38",
            "2019-10",
            "2019-09",
            "2019-08",
            "2019-Q4",
            "2019-Q3",
            "2019-Q2",
            "2019-Q1",
            "2019",
            "2018",
            "2017",
            "2016",
            "--2015",
            "unknown"
      "by_accessed_time": {
        "bytes_used": {
          "values": [
            102760448,
            1867776,
            1245184,
            2179072,
            1556480,
            105873408,
            9027584,
            8093696,
            105873408,
            23969792,
            32382976,
            26460160,
            188686336,
            0,
            0,
            0,
            20971520,
            0
          "percentages": [
            49.01,
            0.89,
            0.59,
            1.04,
            0.74,
            50.5,
            4.31,
            3.86,
            50.5,
            11.43,
            15.45,
            12.62,
            90,
            0,
            0,
            0,
            10,
            0
          "labels": [
            "2019-W42",
            "2019-W41",
            "2019-W40",
            "2019-W39",
            "2019-W38",
            "2019-10",
            "2019-09",
            "2019-08",
            "2019-Q4",
            "2019-Q3",
            "2019-Q2",
            "2019-Q1",
            "2019",
            "2018",
            "2017",
            "2016",
            "--2015",
            "unknown"
"num_records": 1,
    "href": "/api/storage/volumes/1ef5d1b2-f9d7-11e9-8043-00505682f860/files/d1?return_metadata=true&fields=**"
Retrieving file system analytics information for a set of histogram buckets
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/d3?type=directory&fields=analytics&analytics.histogram_by_time_labels=2019-Q3,2019-Q2,2019-Q1,2018-Q4"
# Response with analytics data
"records": [
    "path": "d3",
    "name": ".",
    "analytics": {
      "file_count": 44,
      "bytes_used": 244240384,
      "subdir_count": 14,
        "bytes_used": {
          "values": [
            57344,
            29720576,
            196141056,
            57344
          "percentages": [
            0.02,
            12.17,
            80.31,
            0.02
        "bytes_used": {
          "values": [
            69632,
            244170752,
            0,
            0
          "percentages": [
            0.03,
            99.97,
            0,
            0
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d3%2F%2E"
      "metadata": {
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d3%2F%2E?return_metadata=true"
    "path": "d3",
    "name": "..",
    "analytics": {
      "file_count": 515,
      "bytes_used": 3034574848,
      "subdir_count": 23,
        "bytes_used": {
          "values": [
            61440,
            1756479488,
            214622208,
            1191936
          "percentages": [
            0,
            57.88,
            7.07,
            0.04
        "bytes_used": {
          "values": [
            282624,
            3034292224,
            0,
            0
          "percentages": [
            0.01,
            99.99,
            0,
            0
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d3%2F%2E%2E"
      "metadata": {
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d3%2F%2E%2E?return_metadata=true"
    "path": "d3",
    "name": "d5",
    "analytics": {
      "file_count": 10,
      "bytes_used": 47648768,
      "subdir_count": 4,
        "bytes_used": {
          "values": [
            0,
            29638656,
            0,
            0
          "percentages": [
            0,
            62.20,
            0,
            0
        "bytes_used": {
          "values": [
            0,
            47648768,
            0,
            0
          "percentages": [
            0,
            100,
            0,
            0
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d3%2Fd5"
      "metadata": {
        "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d3%2Fd5?return_metadata=true"
"num_records": 3,
"analytics": {
    "bytes_used": {
      "labels": [
        "2019-Q3",
        "2019-Q2",
        "2019-Q1",
        "2018-Q4"
    "bytes_used": {
      "labels": [
        "2019-Q3",
        "2019-Q2",
        "2019-Q1",
        "2018-Q4"
    "href": "/api/storage/volumes/cb6b1b39-8d21-11e9-b926-005056aca658/files/d3?type=directory&fields=analytics&analytics.histogram_by_time_labels=2019-Q3,2019-Q2,2019-Q1,2018-Q4"
Identifying the largest subdirectories
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/1ef5d1b2-f9d7-11e9-8043-00505682f860/files/d1?fields=analytics.bytes_used&type=directory&order_by=analytics.bytes_used%20desc"
# Response with the largest subdirectories sorted by their usage:
"records": [
    "path": "d1",
    "name": "..",
    "analytics": {
      "bytes_used": 56623104
    "path": "d1",
    "name": ".",
    "analytics": {
      "bytes_used": 35651584
    "path": "d1",
    "name": "biggest",
    "analytics": {
      "bytes_used": 17825792
    "path": "d1",
    "name": "bigger",
    "analytics": {
      "bytes_used": 10485760
    "path": "d1",
    "name": "big",
    "analytics": {
      "bytes_used": 5242880
"num_records": 5,
    "href": "/api/storage/volumes/1ef5d1b2-f9d7-11e9-8043-00505682f860/files/d1?fields=analytics.bytes_used&type=directory&order_by=analytics.bytes_used%20desc"
Assigning a QoS policy to a file
You can use the PATCH request to assign a QoS policy to a file.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/directory1%2Ffile1" -d '{ "qos_policy": { "name": "policy" }}'
# The response:
Retrieving QoS information for a file
You can use the GET request for all fields with return_metadata="true" to retrieve QoS information for the file.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/file?return_metadata=true&fields=**"
# The response:
"records": [
    "svm": {
     "uuid": "42ee3002-67dd-11ea-8508-005056a7b8ac"
    "volume": {
      "uuid": "c05eb66a-685f-11ea-8508-005056a7b8ac"
    "path": "file",
    "type": "lun",
    "creation_time": "2020-03-17T10:58:40-04:00",
    "modified_time": "2020-03-24T18:15:40-04:00",
    "changed_time": "2020-03-24T18:15:40-04:00",
    "accessed_time": "2020-03-24T18:15:40-04:00",
    "owner_id": 0,
    "group_id": 0,
    "size": 1048576,
    "hard_links_count": 2,
    "inode_number": 96,
    "bytes_used": 1056768,
    "inode_generation": 219748425,
    "is_snapshot": false,
    "qos_policy": {
      "name": "pg1",
      "uuid": "00725264-688f-11ea-8f10-005056a7b8ac"
"num_records": 1
Deleting an entire directory
You can use the DELETE request to remove an entire directory recursively.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/directory1%2Fdirectory2?recurse=true"
# The response:
"job": {
  "uuid": "27d287e8-fcd4-11e9-b8a4-005056a7b97b",
      "href": "/api/cluster/jobs/27d287e8-fcd4-11e9-b8a4-005056a7b97b"
Deleting an entire directory with specified throttling threshold
You can specify the maximum number of directory delete operations per second when removing an entire directory recursively.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/directory1%2Fdirectory2?recurse=true&throttle_deletion=100"
# The response:
"job": {
Deleting an empty directory
You can use the DELETE request to remove an empty directory.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/directory1%2Fdirectory2"
# The response:
Deleting a file
You can use the DELETE request to remove a file.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/directory1%2Ffile2"
# The response:
Renaming a file
You can use the PATCH request to rename a file.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/directory1%2Fdirectory2%2Ffile1" -d '{ "path": "directory1/file2" }'
# The response:
Renaming a directory
You can use the PATCH request to rename a directory.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/volumes/cb6b1b39-8d21-11e9-b926-05056aca658/files/directory1%2Fdirectory2" -d '{ "path": "d3/d4" }'
# The response:
