ONTAP 9.13.1 ONTAPI-to-REST mapping
storage-adapter
storage-adapter-enable-adapter
This ONTAPI call does not have an equivalent REST API call.
storage-adapter-get-adapter-info
GET /api/storage/ports/{node.uuid}/{name}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
adapter-fc
See comment column for details
adapter-fc-info.adapter-bar → NA
adapter-fc-info.adapter-model → NA
adapter-fc-info.adapter-sff-info → NA
adapter-fc-info.adapter-sfp-info.part-number → cable.part_number
adapter-fc-info.adapter-sfp-info.serial-number → cable.serial_number
adapter-fc-info.adapter-sfp-info.speed-capabilities → NA
adapter-fc-info.adapter-sfp-info.vendor → NA
adapter-fc-info.cache-line-sz → NA
comment: adapter-fc-info.adapter-model available as part of the "description" attribute
adapter-fc-info.fc-link-rate → speed
adapter-fc-info.fc-node-name → NA
adapter-fc-info.fc-packet-size → NA
adapter-fc-info.fc-port-name → wwpn
comment: adapter-fc-info.fc-port-name contains ":" in ONTAPI, but not in REST
adapter-fc-info.firmware-rev → firmware_version
adapter-fc-info.hardware-rev → NA
comment: adapter-fc-info.hardware-rev available as part of the "description" attribute
adapter-fc-info.host-loop-id → NA
adapter-fc-info.host-port-id → NA
adapter-fc-info.is-enabled → state
comment: adapter-fc-info.is-enabled is false when the REST "state" is "offline"
adapter-fc-info.is-ext-gbic → NA
adapter-fc-info.is-in-use → in_use
adapter-fc-info.is-pci-64-capable → NA
adapter-fc-info.is-redundant → redundant
adapter-fc-info.is-sram-parity → NA
adapter-fc-info.preload-table-rev → NA +
adapter-name
name
adapter-parallel-scsi
No REST Equivalent
adapter-sas
adapter-sas-info.adapter-board-revision → NA
adapter-sas-info.adapter-date-code → NA
adapter-sas-info.adapter-family → NA
comment: adapter-sas-info.adapter-family available as part of the "description" attribute
adapter-sas-info.adapter-manufacturer → NA
adapter-sas-info.adapter-manufacturer-part-number → NA
adapter-sas-info.adapter-model → NA
comment: adapter-sas-info.adapter-model available as part of the "description" attribute
adapter-sas-info.adapter-slot → NA
comment: adapter-sas-info.adapter-slot available as part of the "name" attribute
adapter-sas-info.adapter-state → state
comment: adapter-sas-info.adapter-state is simplified to "online", "offline", and "error" in REST
adapter-sas-info.adapter-part-number → part_number
adapter-sas-info.adapter-serial-number → serial_number
adapter-sas-info.adapter-vendor → NA
adapter-sas-info.base-wwn → wwn
comment: adapter-sas-info.base-wwn contains ":" in ONTAPI, but not in REST
adapter-sas-info.firmware-rev → firmware_version
adapter-sas-info.hardware-rev → NA
comment: adapter-sas-info.hardware-rev available as part of the "description" attribute
adapter-sas-info.is-enabled → state
comment: adapter-sas-info.is-enabled is false when the REST "state" is "offline"
adapter-sas-info.is-in-use → in_use
adapter-sas-info.is-redundant → redundant
adapter-sas-info.sas-adapter-disabled-phy-count → NA
adapter-sas-info.sas-adapter-enabled-phy-count → NA
adapter-sas-info.sas-adapter-expander-phy-states → NA
adapter-sas-info.sas-phy → NA
adapter-sas-info.sas-qsfp-cable.sas-qsfp-cable-info.attached-serial-number → cable.serial_number
adapter-sas-info.sas-qsfp-cable.sas-qsfp-cable-info.cable-end-identifier → NA
adapter-sas-info.sas-qsfp-cable.sas-qsfp-cable-info.cable-length → cable.length
adapter-sas-info.sas-qsfp-cable.sas-qsfp-cable-info.cable-manufacturer → NA
adapter-sas-info.sas-qsfp-cable.sas-qsfp-cable-info.cable-part-number → cable.part_number
adapter-sas-info.sas-qsfp-cable.sas-qsfp-cable-info.cable-serial-number → cable.identifier
adapter-sas-info.sas-qsfp-cable.sas-qsfp-cable-info.cable-technology → NA +
adapter-type
type
ONTAPI adapter-type → REST API type
ADT_IF_ATA → NA
ADT_IF_PARALLEL_SCSI → NA
ADT_IF_SAS → sas
ADT_IF_FC → fc +
node-name
node.name
storage-adapter-get-adapter-list
node-name
node.name
