ONTAP ONTAPI-to-REST mapping
storage-pool
storage-pool-add
PATCH /api/storage/pools/{uuid}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
auto-grow-aggregates
No REST Equivalent
This field is always true when invoked via REST.
disk-count
capacity.disk_count
disk-list
capacity.disks
nodes
nodes.name
simulate
simulate
storage-pool
No REST Equivalent
Specify the storage pool uuid for this PATCH request.
storage-pool-aggregate-get-iter
GET /api/storage/pools
aggregate
capacity.used_allocation_units.aggregate.name
allocated-unit-count
capacity.used_allocation_units.count
node
capacity.used_allocation_units.node.name
original-owner
No REST Equivalent
storage-pool
name
used-capacity
capacity.used_allocation_units.current_usage
max-records
max_records
Specifies the maximum number of records to return before paging.
storage-pool-available-capacity-get-iter
allocation-unit-count
capacity.spare_allocation_units.count
allocation-unit-size
capacity.spare_allocation_units.size
available-size
capacity.spare_allocation_units.available_size
node
capacity.spare_allocation_units.node.name
storage-pool
name
storage-type
storage_type
syncmirror-pool
capacity.spare_allocation_units.syncmirror_pool
max-records
max_records
storage-pool-create
POST /api/storage/pools
disk-count
capacity.disk_count
disk-list
disks
disk-size
disk_size
nodes
nodes.name
simulate
simulate
storage-pool
name
storage-pool-delete
DELETE /api/storage/pools/{uuid}
storage-pool
No REST Equivalent
Specify the storage pool uuid for this DELETE request.
storage-pool-disk-get-iter
disk
capacity.disks.disk.name
disk-total-size
capacity.disks.total_size
disk-type
No REST Equivalent
This field is insignificant since all cache disks are SSDs.
disk-usable-size
capacity.disks.usable_size
storage-pool
name
max-records
max_records
storage-pool-get-iter
allocation-unit-data-size-raid-dp
No REST Equivalent
allocation-unit-data-size-raid-tec
No REST Equivalent
allocation-unit-data-size-raid4
No REST Equivalent
current-operation-job-id
No REST Equivalent
disk-count
capacity.disk_count
is-healthy
health.is_healthy
nodes
nodes.name
pool-state
health.state
pool-total-size
capacity.total
pool-usable-size
capacity.remaining
storage-pool
name
storage-type
storage_type
unhealthy-reason
health.unhealthy_reason
max-records
max_records
storage-pool-reassign
allocation-units
capacity.spare_allocation_units[].count
from-node
capacity.spare_allocation_units[].node.name
storage-pool
No REST Equivalent
to-node
storage-pool-rename
new-name
name
storage-pool
No REST Equivalent
