Install Linux Host Utilities 8.0 for ONTAP storage
The Linux Host Utilities help you manage ONTAP storage attached to a Linux host. NetApp strongly recommends installing the Linux Host Utilities, but it's not mandatory. The Linux Host Utilities improve management and assist NetApp customer support in gathering information about your configuration.
Linux Host Utilities 8.0 supports the following distribution types:
Red Hat Enterprise Linux (RHEL)
SUSE Linux Enterprise Server
Oracle Linux
Ubuntu
The Linux Host Utilities software doesn't support NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) host protocols. |
When you install the Linux Host Utilities, it doesn't change any settings or behavior on your host.
For reliable operation, use the Interoperability Matrix Tool to verify that your iSCSI, FC, or FCoE configuration is supported.
Install the host bus adapter (HBA) management packages available on the vendor support site. The management software enables the
sanluncommands to gather information about the FC HBAs, such as their WWPNs.Refer to the vendor documentation to verify that the following packages are correctly installed. These packages are required to support the
sanlun fcp show adaptercommand:-
Marvell QLogic HBA – QConvergeConsole CLI
Broadcom Emulex HBA - OneCommand Manager core application CLI
The Linux Host Utilities has an installation dependency on the libHBAAPI.so library. You need to install one of the packages listed above, even if a host is intended for an iSCSI-only configuration. Alternatively, you can use OS-level tools for LUN and path management.
If you have a version of Linux Host Utilities currently installed, remove it:
Linux hostsRemove Linux Host Utilities from a RHEL, SUSE Linux Enterprise Server, or Oracle Linux host:
rpm -e netapp_linux_unified_host_utilities-x-xUbuntuRemove Linux Host Utilities from an Ubuntu host:
sudo apt remove netapp_linux_unified_host_utilities-x-xFor earlier versions of Linux Host Utilities, go to the directory where the host utility software is installed and enter the uninstall command to remove the installed package.
The NetApp Linux Host Utilities software package is available on the NetApp Support Site in a 64-bit .rpm file. Download the 64-bit file from the NetApp Support Site to your host.
Go to the directory to which you downloaded the software package and install it:
Linux hostsInstall Linux Host Utilities 8.0 on a RHEL, SUSE Linux Enterprise Server, or Oracle Linux host:
rpm -ivh netapp_linux_unified_host_utilities-8-0.x86_xx.rpmYou should see an output similar to the following example:
rpm -ivh netapp_linux_unified_host_utilities-8-0.x86_64.rpm Verifying... ################################# [100%] Preparing... ################################# [100%] Updating / installing... 1:netapp_linux_unified_host_utiliti################################# [100%]
Ubuntu-
Install Linux Host Utilities 8.0 on an Ubuntu host:
sudo apt install /<path_to_file>/netapp_linux_unified_host_utilities-8-0.x86_xx.deb -
Manually link the Ubuntu OS to the HBA library:
cp /opt/QLogic_Corporation/QConvergeConsoleCLI/lib64/libHBAAPI.so.2.0.2 /usr/lib64/libHBAAPI.so
Verify the installation:
sanlun versionYou should see an output similar to the following example:
sanlun version 8.0.386.1644
Recommended driver settings with Linux kernel
When you configure an FC environment that uses native inbox drivers that are bundled with the Linux kernel, you can use the default values for the drivers.
