Install Solaris Host Utilities 8.0 for ONTAP storage
The Solaris Host Utilities help you manage ONTAP storage attached to a Solaris host and assist technical support with gathering configuration data.
The Solaris Host Utilities support the following Solaris environments and transport protocols. These are the primary supported environments:
The native OS with Oracle Solaris I/O Multipathing (MPxIO) and either the FC or iSCSI protocol on a system using either a SPARC or x86/64 processor.
Veritas Dynamic Multipathing (DMP) with the FC or iSCSI protocol on a system using a SPARC processor.
Solaris Host Utilities 8.0 support the Solaris 11.4 series.
Verify that your iSCSI, FC, or FCoE configuration is supported. You can use the Interoperability Matrix Tool to verify your configuration.
Log in to your host as root.
Download a copy of the compressed file containing the Host Utilities from the NetApp Support Site to a directory on your host.
SPARC CPUnetapp_solaris_host_utilities_8_0_sparc.tar.gzx86/x64 CPUnetapp_solaris_host_utilities_8_0_amd.tar.gz -
Go to the directory on your host containing the download.
Unzip the file using the
gunzipcommand, and then extract the file usingtar -xvf:gunzip netapp_solaris_host_utilities_8_0_sparc.tar.gztar -xvf netapp_solaris_host_utilities_8_0_sparc.tar -
Add the packages that you extracted from the tar file to your host:
pkgaddThe packages are added to the
/opt/NTAP/SANToolkit/bindirectory.The following example uses the
pkgaddcommand to install the Solaris installation package:pkgadd -d ./NTAPSANTool.pkg -
Confirm that the toolkit was successfully installed by using the following command to the installed path:
pkgchkShow example output
# pkgchk -l -p /opt/NTAP/SANToolkit Pathname: /opt/NTAP/SANToolkit Type: directory Expected mode: 0755 Expected owner: root Expected group: sys Referenced by the following packages: NTAPSANTool Current status: installed # ls -alR /opt/NTAP/SANToolkit /opt/NTAP/SANToolkit: total 1038 drwxr-xr-x 3 root sys 4 Mar 7 13:11 . drwxr-xr-x 3 root sys 3 Mar 7 13:11 .. drwxr-xr-x 2 root sys 6 Mar 17 18:32 bin -r-xr-xr-x 1 root sys 432666 Dec 31 13:23 NOTICES.PDF /opt/NTAP/SANToolkit/bin: total 3350 drwxr-xr-x 2 root sys 6 Mar 17 18:32 . drwxr-xr-x 3 root sys 4 Mar 7 13:11 .. -r-xr-xr-x 1 root sys 1297000 Feb 7 22:22 host_config -r-xr-xr-x 1 root root 996 Mar 17 18:32 san_version -r-xr-xr-x 1 root sys 309700 Feb 7 22:22 sanlun -r-xr-xr-x 1 root sys 677 Feb 7 22:22 vidpid.dat # cd /usr/share/man/man1; ls -al host_config.1 sanlun.1 -r-xr-xr-x 1 root sys 12266 Feb 7 22:22 host_config.1 -r-xr-xr-x 1 root sys 9044 Feb 7 22:22 sanlun.1
Configure the host parameters for your "MPxIO" or "Veritas DMP" environment by using the
/opt/NTAP/SANToolkit/bin/host_configcommand with the multipath stack from the command reference:/opt/NTAP/SANToolkit/bin/host_config -setup -protocol fcp|iscsi|mixed -multipath mpxio|dmp|non [-noalua] [-mcc 60|90|120]For example, if your setup is… Use the command… FCP with multipath as MPxIO
#/opt/NTAP/SANToolkit/bin/host_config -setup -protocol fcp -multipath mpxioFor information on the configuration changes for SnapMirror active sync, see the Knowledge Base article Solaris Host support recommended settings in SnapMirror active sync (formerly SM-BC) configuration.
FCP with multipath as DMP
#/opt/NTAP/SANToolkit/bin/host_config -setup -protocol fcp -multipath dmpFCP on MetroCluster with multipath as MPxIO, and the All Paths Down value is set to 120s. (This is the recommended setting for MetroCluster configurations).
#/opt/NTAP/SANToolkit/bin/host_config -setup -protocol fcp -multipath mpxio -mcc 120For more information, see the Knowledge Base article Solaris host support considerations in a MetroCluster configuration.
Reboot the host.
The Host Utilities load the following NetApp recommended timeout parameter settings for ONTAP LUNs.
Show example
#prtconf -v |grep NETAPP value='NETAPP LUN' + physical-block-size:4096, retries-busy:30, retries-reset:30, retries-notready:300, retries-timeout:10, throttle-max:64, throttle-min:8, disksort:false, cache-nonvolatile:true'
Verify the Host Utilities installation:
sanlun version
