(AIX MPIO without PowerVM) Discover and configure LUNs with AIX
When you use AIX without PowerVM, you can run the cfgmgr command to enable the host to discover the LUNs. You don't need to reboot the host to discover the LUNs. To confirm that the host discovered the LUNS, you can use the sanlun utility.
The following steps don't apply to a host that is running a PowerVM environment. |
Log in as root on the host.
On the AIX host, discover the newly created LUNs:
cfgmgrThe
cfgmgrcommand helps with the following:-
The initiators to log in to the fabric.
The system to check for new devices.
The system to create new device entries.
Display all AIX disks, including the NetApp LUNs:
lsdev -Cc diskThe LUNs appear on the host as disks. You can use these disks the same way you use local disks on the host. The host settings ODM file that is installed as part of the Host Utilities causes the LUNs to be displayed as NetApp FCP disks.
Write down the hdisk instance numbers. You use them when you perform the path configuration.
The following example shows the
lsdev -Cc diskcommand output in an FC environment.Show example output
# lsdev -Cc disk hdisk0 Available 08-08-00-5,0 16 Bit LVD SCSI Disk Drive hdisk1 Available 08-08-00-8,0 16 Bit LVD SCSI Disk Drive hdisk2 Available 04-08-02 MPIO NetApp FCP Default PCM Disk hdisk3 Available 04-08-02 MPIO NetApp FCP Default PCM Disk hdisk4 Available 04-08-02 MPIO NetApp FCP Default PCM Disk hdisk5 Available 04-08-02 MPIO NetApp FCP Default PCM Disk
Retrieve information about your setup:
lsattr -El hdisk_nameShow example output
# lsattr -El hdisk65 PCM PCM/friend/NetApp PCM Path Control Module False PR_key_value none Persistant Reserve Key Value True algorithm round_robin Algorithm True clr_q no Device CLEARS its Queue on error True dist_err_pcnt 0 Distributed Error Sample Time True dist_tw_width 50 Distributed Error Sample Time True hcheck_cmd inquiry Health Check Command True hcheck_interval 30 Health Check Interval True hcheck_mode nonactive Health Check Mode True location Location Label True lun_id 0x2000000000000 Logical Unit Number ID False lun_reset_spt yes LUN Level Reset True max_transfer 0x100000 Maximum TRANSFER Size True node_name 0x500a0980894ae0e0 FC Node Name False pvid 00067fbad453a1da0000000000000000 Physical volume identifier False q_err yes Use QERR bit True q_type simple Queuing TYPE True qfull_dly 2 Delay in seconds for SCSI TASK SET FULL True queue_depth 64 Queue DEPTH True reassign_to 120 REASSIGN time out value True reserve_policy no_reserve Reserve Policy True rw_timeout 30 READ/WRITE time out value True scsi_id 0xd10001 SCSI ID False start_timeout 60 START unit time out value True ww_name 0x500a0984994ae0e0 FC World Wide Name False
If your configuration supports ALUA, you can use it to set path priority. Verify that ALUA is enabled:
lun igroup show -instance igroup_name-
If ALUA is not enabled, enable it:
igroup set igroup_name alua yes
If your configuration does not support ALUA, you need to use the dotpaths utility to set the path priorities. The dotpaths utility is installed when you install the Host Utilities. Don't use the dotpaths utility if ALUA is enabled.
Set the priority for all ONTAP LUNs:
dotpaths -
Set the priority for a specific set of disks:
dotpaths [-hqv] [hdiskN ...]Use the
-voption to enable verbose mode and display all the priorities. Use the-qoption to query all or individual disk priorities.
Verify that the host has discovered the LUNs:
sanlun lun showThe following example shows the typical output for the
sanlun lun showcommand in a Microsoft Multipath I/O (MPIO) multipathing environment:Show example output
sanlun lun show -p ONTAP Path: fas3170-aix03:/vol/ibmbc_aix01b14_fcp_vol8/ibmbc-aix01b14_fcp_lun0 LUN: 8 LUN Size: 3g Controller CF State: Cluster Enabled Controller Partner: fas3170-aix04 Host Device: hdisk9 Mode: 7 Multipath Provider: AIX Native Multipathing Algorithm: round_robin --------- ----------- ------ ------- ---------------------------------------------- ---------- host controller AIX controller AIX MPIO path path MPIO host target path state type path adapter port priority --------- ----------- ------ ------- ---------------------------------------------- ---------- up secondary path0 fcs0 3b 1 up primary path1 fcs0 3a 1 up secondary path2 fcs0 3a 1 up primary path3 fcs0 3b 1 up secondary path4 fcs0 4b 1 up secondary path5 fcs0 4a 1 up primary path6 fcs0 4b 1 up primary path7 fcs0 4a 1 up secondary path8 fcs1 3b 1 up primary path9 fcs1 3a 1 up secondary path10 fcs1 3a 1 up primary path11 fcs1 3b 1 up secondary path12 fcs1 4b 1 up secondary path13 fcs1 4a 1 up primary path14 fcs1 4b 1 up primary path15 fcs1 4a 1
