ONTAP SAN Host Utilities
Linux Host Utilities 7.1 Release Notes
Contributors netapp-ranuk netapp-pcarriga netapp-sarajane
The release notes describe new features and enhancements, known problems and limitations, and important cautions for configuring and managing your specific host with your ONTAP storage system.
For specific information about the operating system versions and updates that the Host Utilities support, see the Interoperability Matrix Tool.
What's New
The Linux Host Utilities 7.1 release contains the following new features and enhancements:
  • Linux Host Utilities is now called Linux Unified Host Utilities because it supports NetApp E-Series storage systems running SANtricity as well as AFF, FAS, and ASA systems running ONTAP.
    Note Any mention of Host Utilities or Linux Host Utilities in this document refers to Linux Unified Host Utilities.
  • The following operating systems are now supported:
    • SUSE Linux Enterprise Server 15 series
    • Oracle VM 3.2 series
    • Oracle Linux 6 and 7 series
    • Red Hat Enterprise Linux 6 and 7 series
    • SUSE Linux Enterprise Server 11 SP4
    • KVM and XEN, RHEV 6.4 and 6.5
    • Citrix XenServer
  • On Red Hat Enterprise Linux (RHEL) 6 and RHEL 7 hosts, a tuned package for setting server profiles is now supported. You can use the tuned-adm command to set different profiles, depending on the environment. For example, you can also use the virtual guest profile as a guest virtual machine and you can use the enterprise storage profile for configurations where LUNs from enterprise storage arrays are used. Using these tuned packages can result in improvement in throughput and latency in ONTAP.
  • Adds support for 32GB FC adapters from Broadcom Emulex and Marvell Qlogic.
Note NetApp continues to work with the Host Utilities to add support for features after the initial release. For latest information about the features that are supported and the new features that have been added, see the Interoperability Matrix Tool.
Fixed in this release
The intermittent host OS failure issue that occurs when running the sanlun lun show -p command in SUSE Linux Enterprise Server 12 SP1, OL 7.2, RHEL 7.2, and RHEL 6.8 is fixed in this release.
Known problems and limitations
The Linux Host Utilities 7.1 release has the following known problems and limitations.
NetApp Bug ID Title Description
1457017
sanlun installation issues warning messages related to libdevmapper.so and libnl.so libraries. These warnings do not affect the functionality of sanlun kit.
When you execute the Linux Host Utilities CLI command - "sanlun fcp show adapter -v" on a SAN host, the command fails with an error message displaying that the library dependencies required for an host bus adapter (HBA) discovery cannot be
located:
[root@hostname ~]# sanlun fcp show adapter -v
Unable to locate /usr/lib64/libHBAAPI.so library
Make sure the package installing the library is installed & loaded
Refer to NetApp Bugs Online - 1508554.
NetApp Bugs Online provides complete information for most known issues, including suggested workarounds where possible.
