Install Solaris Host Utilities 6.2 for ONTAP storage
The Solaris Host Utilities help you manage ONTAP storage attached to a Solaris host and assist technical support with gathering configuration data.
The Solaris Host Utilities support several Solaris environments and multiple transport protocols. These are the primary Solaris Host Utilities environments:
The native OS with MPxIO and either the Fibre Channel (FC) or iSCSI protocol on a system using either a SPARC processor or an x86/64 processor.
Veritas Dynamic Multipathing (DMP) with either the FC or iSCSI protocol on a system using a SPARC processor, or the iSCSI protocol on a system using an x86/64 processor.
The Solaris Host Utilities 6.2 support the following Solaris series:
Solaris 11.x
Solaris 10.x
Verify that your iSCSI, FC, or FCoE configuration is supported. You can use the Interoperability Matrix Tool to verify your configuration.
Log in to your host as root.
Download a copy of the compressed file containing the Host Utilities from the NetApp Support Site to a directory on your Solaris host:
SPARC CPUnetapp_solaris_host_utilities_6_2_sparc.tar.gzx86/x64 CPUnetapp_solaris_host_utilities_6_2_amd.tar.gz -
Go to the directory on your Solaris host containing the download.
Unzip the file using the
gunzipcommand:gunzip netapp_solaris_host_utilities_6_2_sparc.tar.gz -
Extract the file using the
tar xvfcommand:tar xvf netapp_solaris_host_utilities_6_2_sparc.tar -
Add the packages that you extracted from tar file to your host
pkgaddThe packages are added to the
/opt/NTAP/SANToolkit/bindirectory.The following example uses the
pkgaddcommand to install the Solaris installation package:pkgadd -d ./NTAPSANTool.pkg -
Confirm that the toolkit was successfully installed by using one of the following commands:
pkginfols - alShow example outputs
# ls -alR /opt/NTAP/SANToolkit /opt/NTAP/SANToolkit: total 1038 drwxr-xr-x 3 root sys 4 Jul 22 2019 . drwxr-xr-x 3 root sys 3 Jul 22 2019 .. drwxr-xr-x 2 root sys 6 Jul 22 2019 bin -r-xr-xr-x 1 root sys 432666 Sep 13 2017 NOTICES.PDF /opt/NTAP/SANToolkit/bin: total 7962 drwxr-xr-x 2 root sys 6 Jul 22 2019 . drwxr-xr-x 3 root sys 4 Jul 22 2019 .. -r-xr-xr-x 1 root sys 2308252 Sep 13 2017 host_config -r-xr-xr-x 1 root sys 995 Sep 13 2017 san_version -r-xr-xr-x 1 root sys 1669204 Sep 13 2017 sanlun -r-xr-xr-x 1 root sys 677 Sep 13 2017 vidpid.dat # (cd /usr/share/man/man1; ls -al host_config.1 sanlun.1) -r-xr-xr-x 1 root sys 12266 Sep 13 2017 host_config.1 -r-xr-xr-x 1 root sys 9044 Sep 13 2017 sanlun.1
Configure the host parameters for your MPxIO or Veritas DMP environment:
/opt/NTAP/SANToolkit/bin/host_config -
Verify the installation:
sanlun version
