Configure Oracle Linux 7.x for NVMe-oF with ONTAP storage
Oracle Linux hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for Oracle Linux 7.x. For more support and feature information, see Oracle Linux ONTAP support and features.
NVMe-oF with Oracle Linux 7.x has the following known limitations:
SAN booting using the NVMe-oF protocol is not supported.
NetApp sanlun host utility support isn't available for NVMe-oF on an Oracle Linux 7.x host. Instead, you can rely on the NetApp plug-in included in the native
nvme-clipackage for all NVMe-oF transports. -
Native NVMe/FC auto-connect scripts are not available in the nvme-cli package. Use the HBA vendor provided external auto-connect scripts.
Round-robin load balancing is not enabled by default for NVMe multipathing. To enable this functionality, write a udev rule.
Step 1: Install Oracle Linux and NVMe software and verify your configuration
Use the following procedure to validate the minimum supported Oracle Linux 7.x software versions.
Install Oracle Linux 7.x on the server. After the installation is complete, verify that you are running the specified Oracle Linux 7.x kernel.
uname -rExample Oracle Linux kernel version:
5.4.17-2011.6.2.el7uek.x86_64
Install the
nvme-clipackage:rpm -qa | grep nvme-cliThe following example shows an
nvme-clipackage version:nvme-cli-1.8.1-3.el7.x86_64
Add the following string as a separate udev rule for
/lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules. This enables round-robin load balancing for NVMe multipath.cat /lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules Enable round-robin for NetApp ONTAP ACTION=="add", SUBSYSTEMS=="nvme-subsystem", ATTRS{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="round-robin" -
On the Oracle Linux 7.x host, check the
hostnqnstring at/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows a
hostnqnvalue:nqn.2014-08.org.nvmexpress:uuid:497axxxx-e6d0-xxxx-8dc2-a89xxxx00874
On the ONTAP system, verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP storage system:*> vserver nvme subsystem host show -vserver vs_nvme_10Show example
Vserver Subsystem Host NQN ------- --------- -------------------------------------- ----------- ol_157_nvme_ss_10_0 nqn.2014-08.org.nvmexpress:uuid:497axxxx-e6d0-xxxx-8dc2-a89xxxx00874
If the hostnqnstrings don't match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host. -
Reboot the host.
Step 2: Configure NVMe/FC
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you're using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe32002-M2 LPe32002-M2
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see an output similar to the following example:
Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that
lpfc_enable_fc4_typeis set to "3":cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Install the recommended lpfc auto-connect scripts:
rpm -ivh nvmefc-connect-12.8.264.0-1.noarch.rpm -
Verify that the auto-connect scripts are installed:
rpm -qa | grep nvmefcYou should see the following output:
Verify that your initiator ports are online:
Display the port name:
cat /sys/class/fc_host/host*/port_nameYou should see the following output:
0x10000090fae0ec61 0x10000090fae0ec62
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 NVME 2947 SCSI 2947 ELS 250 NVME LPORT lpfc0 WWPN x10000090fae0ec61 WWNN x20000090fae0ec61 DID x012000 ONLINE NVME RPORT WWPN x202d00a098c80f09 WWNN x202c00a098c80f09 DID x010201 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203100a098c80f09 WWNN x202c00a098c80f09 DID x010601 TARGET DISCSRVC ONLINE
Step 3: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 4: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model Namespace Usage Format FW Rev ---------------- -------------------- ----------------------- /dev/nvme0n1 80BADBKnB/JvAAAAAAAC NetApp ONTAP Controller 1 53.69 GB / 53.69 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
nvme list-subsys /dev/nvme0n1Show example
Nvme-subsysf0 – NQN=nqn.1992-08.com.netapp:sn.341541339b9511e8a9b500a098c80f09:subsystem.ol_157_nvme_ss_10_0 \ +- nvme0 fc traddr=nn-0x202c00a098c80f09:pn-0x202d00a098c80f09 host_traddr=nn-0x20000090fae0ec61:pn-0x10000090fae0ec61 live optimized +- nvme1 fc traddr=nn-0x207300a098dfdd91:pn-0x207600a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x207300a098dfdd91:pn-0x207500a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x207300a098dfdd91:pn-0x207700a098dfdd91 host traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live inaccessible
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path NSID UUID Size ------- -------- ------------------------- ------ ----- ----- /dev/nvme0n1 vs_nvme_10 /vol/rhel_141_vol_10_0/ol_157_ns_10_0 1 55baf453-f629-4a18-9364-b6aee3f50dad 53.69GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices" : [ { Device" : "/dev/nvme0n1", "Vserver" : "vs_nvme_10", "Namespace_Path" : "/vol/rhel_141_vol_10_0/ol_157_ns_10_0", "NSID" : 1, "UUID" : "55baf453-f629-4a18-9364-b6aee3f50dad", "Size" : "53.69GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 13107200 } ]
Step 5: Review the known issues
There are no known issues.
