ONTAP SAN Host Utilities
ONTAP support and features for Oracle Linux hosts
Contributors netapp-pcarriga netapp-sarajane netapp-camdenc
Features supported for host configuration with NVMe over Fabrics (NVMe-oF) vary based on your version of ONTAP and Oracle Linux.
Feature Oracle Linux host version ONTAP version
NVMe/FC and NVMe/TCP report all optimized paths on ASA r2 systems
9.0 or later
9.16.1 or later
Beginning with Oracle Linux 9.6, nvme supports "queue-depth" i/o policy and enabled as default option.
9.6 or later
9.10.1 or later
Secure in-band authentication is supported over NVMe/TCP between a Oracle Linux host and an ONTAP controller
9.4 or later
9.12.1 or later
NVMe/TCP is a fully supported enterprise feature
9.0 or later
9.10.1 or later
NVMe/TCP provides namespaces using the native nvme-cli package
8.2 or later
9.10.1 or later
NVMe and SCSI traffic is supported on the same host using NVMe multipath for NVMe-oF namespaces and dm-multipath for SCSI LUNs
7.7 or later
9.4 or later
Note The NetApp sanlun host utility isn't supported for NVMe-oF. Instead, you can use the NetApp plug-in included in the native nvme-cli for all NVMe-oF transports.
ONTAP supports the following SAN host features regardless of the ONTAP version running on your system setup.
The native udev rule in the nvme-cli package provides queue-depth load balancing for NVMe multipathing
9.6 or later
SAN booting is enabled using the NVMe/FC protocol
9.5 or later
In-kernel NVMe multipathing for NVMe namespaces is enabled by default
8.3 or later
The nvme-cli package includes auto-connect scripts removing the need for third-party scripts
8.3 or later
The native udev rule in the nvme-cli package provides round-robin load balancing for NVMe multipathing
8.3 or later
Note For details on supported configurations, see the Interoperability Matrix Tool.
