Configure Oracle Linux 10.x for NVMe-oF with ONTAP storage
Oracle Linux hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for Oracle Linux 10.x. For more support and feature information, see Oracle Linux ONTAP support and features.
NVMe-oF with Oracle Linux 10.x has the following known limitation:
The
nvme disconnect-allcommand disconnects both root and data filesystems and might lead to system instability. Do not issue this on systems booting from SAN over NVMe-TCP or NVMe-FC namespaces.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Reboot the host and verify that the OS is up and running.
Step 2: Install Oracle Linux and NVMe software and verify your configuration
Use the following procedure to validate the minimum supported Oracle Linux 10.x software versions.
Install Oracle Linux 10.x on the server. After the installation is complete, verify that you are running the specified Oracle Linux 10.x kernel.
uname -rExample Oracle Linux kernel version:
6.12.0-105.51.5.el10uek.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cliThe following example shows an
nvme-clipackage version:nvme-cli-2.13-2.0.1.el10.x86_64
Install the
libnvmepackage:rpm -qa|grep libnvmeThe following example shows an
libnvmepackage version:libnvme-1.13-1.el10.x86_64
On the Oracle Linux 10.x host, check the
hostnqnstring at/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows a
hostnqnvalue:nqn.2014-08.org.nvmexpress:uuid:8397xxxx-30f0-xxxx-850f-7edxxxxf0cc7
On the ONTAP system, verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP storage system:vserver nvme subsystem host show -vserver vs_coexistence_emulexShow example
Vserver Subsystem Priority Host NQN ------- --------- ------- ------------------------------------------------ vs_coexistence_emulex nvme1 regular nqn.2014-08.org.nvmexpress:uuid:8397cecc-30f0-11e8-850f-7ed30aef0cc7 nvme2 regular nqn.2014-08.org.nvmexpress:uuid:8397cecc-30f0-11e8-850f-7ed30aef0cc7If the hostnqnstrings don't match, you can use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Step 3: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you're using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe37102 LPe37102
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see an output similar to the following example:
Emulex LPe37102 32Gb 2-port Fibre Channel Adapter Emulex LPe37102 32Gb 2-port Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe following example shows firmware versions:
14.4.725.15, sli-4:6:e 14.4.725.15, sli-4:6:e
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:14.4.0.8
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/<port_name>The following example shows port identities:
0x100070b7e422ab3f 0x100070b7e422ab40
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000620b3c0869 WWNN x200000620b3c0869 DID x080e00 ONLINE NVME RPORT WWPN x2001d039eabac36f WWNN x2000d039eabac36f DID x021401 TARGET DISCSRVC ONLINE NVME RPORT WWPN x20e2d039eabac36f WWNN x20e1d039eabac36f DID x02141f TARGET DISCSRVC ONLINE NVME RPORT WWPN x2011d039eabac36f WWNN x2010d039eabac36f DID x021429 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2002d039eabac36f WWNN x2000d039eabac36f DID x021003 TARGET DISCSRVC ONLINE NVME RPORT WWPN x20e4d039eabac36f WWNN x20e1d039eabac36f DID x02100f TARGET DISCSRVC ONLINE NVME RPORT WWPN x2012d039eabac36f WWNN x2010d039eabac36f DID x021015 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000027ccf Cmpl 0000027cca Abort 00000014 LS XMIT: Err 00000005 CMPL: xb 00000014 Err 00000014 Total FCP Cmpl 00000000000613ff Issue 00000000000613fc OutIO fffffffffffffffd abort 00000007 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 0000000a Err 0000000d NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000620b3c086a WWNN x200000620b3c086a DID x080000 ONLINE NVME RPORT WWPN x2004d039eabac36f WWNN x2000d039eabac36f DID x021501 TARGET DISCSRVC ONLINE NVME RPORT WWPN x20e3d039eabac36f WWNN x20e1d039eabac36f DID x02150f TARGET DISCSRVC ONLINE NVME RPORT WWPN x2014d039eabac36f WWNN x2010d039eabac36f DID x021515 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2003d039eabac36f WWNN x2000d039eabac36f DID x02110b TARGET DISCSRVC ONLINE NVME RPORT WWPN x20e5d039eabac36f WWNN x20e1d039eabac36f DID x02111f TARGET DISCSRVC ONLINE NVME RPORT WWPN x2013d039eabac36f WWNN x2010d039eabac36f DID x021129 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000027ca3 Cmpl 0000027ca2 Abort 00000017 LS XMIT: Err 00000001 CMPL: xb 00000017 Err 00000017 Total FCP Cmpl 000000000006369d Issue 000000000006369a OutIO fffffffffffffffd abort 00000007 noxri 00000000 nondlp 00000011 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000008 Err 0000000c
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameThe following example shows driver and firmware versions:
QLE2872 FW:v9.15.06 DVR:v10.02.09.300-k
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected output is 1.
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddrShow example
nvme discover -t tcp -w 192.168.41.7 -a 192.168.41.10 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 8 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:discovery traddr: 192.168.31.99 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 6 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:discovery traddr: 192.168.30.99 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 7 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:discovery traddr: 192.168.31.98 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 5 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:discovery traddr: 192.168.30.98 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 8 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:subsystem.subsys_kvm traddr: 192.168.31.99 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 6 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:subsystem.subsys_kvm traddr: 192.168.30.99 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 7 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:subsystem.subsys_kvm traddr: 192.168.31.98 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 5 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:subsystem.subsys_kvm traddr: 192.168.30.98 eflags: none sectype: none
Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
nvme discover -t tcp -w 192.168.41.7 -a 192.168.41.10 nvme discover -t tcp -w 192.168.41.7 -a 192.168.41.11 nvme discover -t tcp -w 192.168.48.7 -a 192.168.48.10 nvme discover -t tcp -w 192.168.48.7 -a 192.168.48.11
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddrShow example
nvme connect-all -t tcp -w 192.168.41.7 -a 192.168.41.10 nvme connect-all -t tcp -w 192.168.41.7 -a 192.168.41.11 nvme connect-all -t tcp -w 192.168.48.7 -a 192.168.48.10 nvme connect-all -t tcp -w 192.168.48.7 -a 192.168.48.11
Beginning with Oracle Linux 9.4, the setting for the NVMe/TCP
Step 4: Optionally, modify the iopolicy in the udev rules
The Oracle Linux 10.x host sets the default iopolicy for NVMe-oF to queue-depth. You can change the iopolicy to round-robin by modifying the udev rules file.
Open the udev rules file in a text editor with root privileges:
/usr/lib/udev/rules.d/71-nvmf-netapp.rulesYou should see the following output:
vi /usr/lib/udev/rules.d/71-nvmf-netapp.rules
Find the line that sets iopolicy for the NetApp ONTAP Controller.
The following example shows an example rule:
ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="queue-depth" -
Modify the rule so that
queue-depthbecomesround-robin:ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="round-robin" -
Reload the udev rules and apply the changes:
udevadm control --reload udevadm trigger --subsystem-match=nvme-subsystem -
Verify the current iopolicy for your subsystem:
cat /sys/class/nvme-subsystem/<subsystem>/iopolicyYou should see the following output:
round-robin.
The new iopolicy applies automatically to matching NetApp ONTAP Controller devices. No reboot is required. |
Step 5: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 6: Verify NVMe boot services
The nvmefc-boot-connections.service and nvmf-autoconnect.service boot services included in the NVMe/FC nvme-cli package are automatically enabled when the system boots.
After booting completes, verify that the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services are enabled.
Verify that
nvmf-autoconnect.serviceis enabled:systemctl status nvmf-autoconnect.serviceShow example output
nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: disabled) Active: inactive (dead) since Tue 2026-02-02 09:48:11 EDT; 1 week 0 days ago Main PID: 2620 (code=exited, status=0/SUCCESS) CPU: 19ms Feb 02 09:48:11 sr630-13-169 systemd[1]: Starting Connect NVMe-oF subsystems automatically during boot... Feb 02 09:48:11 sr630-13-169 systemd[1]: nvmf-autoconnect.service: Deactivated successfully. Feb 02 09:48:11 sr630-13-169 systemd[1]: Finished Connect NVMe-oF subsystems automatically during boot. -
Verify that
nvmefc-boot-connections.serviceis enabled:systemctl status nvmefc-boot-connections.serviceShow example output
nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot-connections.service; enabled; preset: enabled) Active: inactive (dead) since Tue 2026-02-02 09:47:07 EDT; 1 week 0 days ago2 Main PID: 1651 (code=exited, status=0/SUCCESS) CPU: 14ms Feb 02 09:47:07 sr630-13-169 systemd[1]: Starting Auto-connect to subsystems on FC-NVME devices found during boot... Feb 02 09:47:07 sr630-13-169 systemd[1]: nvmefc-boot-connections.service: Deactivated successfully. Feb 02 09:47:07 sr630-13-169 systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Step 7: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to queue-depth) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the value set for iopolicy, for example:
queue-depth queue-depth
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node Generic SN Model Namespace Usage Format FW Rev --------------- --------------- -------------------- ------------------------ ---------- -------------------------- ------------- -------- /dev/nvme10n1 /dev/ng10n1 81NQfNZTUE14AAAAAAAN NetApp ONTAP Controller 0x1 0.00 B / 21.47 GB 4 KiB + 0 B 9.18.1 /dev/nvme10n2 /dev/ng10n2 81NQfNZTUE14AAAAAAAN NetApp ONTAP Controller 0x2 0.00 B / 21.47 GB 4 KiB + 0 B 9.18.1 /dev/nvme12n1 /dev/ng12n1 81NQfNZTUE14AAAAAAAb NetApp ONTAP Controller 0x1 0.00 B / 21.47 GB 4 KiB + 0 B 9.18.1
Verify that the controller state of each path is live and has the correct ANA status:
nvme list-subsys /dev/<controller_ID>Beginning with ONTAP 9.16.1, NVMe/FC and NVMe/TCP report all optimized paths on ASA r2 systems. NVMe/FCThe following example outputs show a namespace hosted on a two-node ONTAP controller for an AFF, FAS, ASA, or ASA r2 system with NVMe/FC.
Show example output for AFF, FAS, or ASA
nvme-subsys114 - NQN=nqn.1992-08.com.netapp:sn.9e30b9760a4911f08c87d039eab67a95:subsystem.sles_161_27 hostnqn=nqn.2014-08.org.nvmexpress:uuid:f651xxxx-3133-xxxx-bbff-7edxxxxf123f iopolicy=round-robin\ +- nvme114 fc traddr=nn-0x234ed039ea359e4a:pn-0x2360d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live optimized +- nvme115 fc traddr=nn-0x234ed039ea359e4a:pn-0x2362d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live non-optimized +- nvme116 fc traddr=nn-0x234ed039ea359e4a:pn-0x2361d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live optimized +- nvme117 fc traddr=nn-0x234ed039ea359e4a:pn-0x2363d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live non-optimizedShow example output for ASA r2
nvme-subsys96 - NQN=nqn.1992-08.om.netapp:sn.b351b2b6777b11f0b3c2d039ea5cfc91:subsystem.nvme24 hostnqn=nqn.2014-08.org.nvmexpress:uuid:d3b5xxxx-c975-xxxx-8425-089xxxx1a074 \ +- nvme203 fc traddr=nn-0x2011d039ea5cfc90:pn-0x2015d039ea5cfc90,host_traddr=nn-0x200000109bdacc76:pn-0x100000109bdacc76 live optimized +- nvme25 fc traddr=nn-0x2011d039ea5cfc90:pn-0x2014d039ea5cfc90,host_traddr=nn-0x200000109bdacc75:pn-0x100000109bdacc75 live optimized +- nvme30 fc traddr=nn-0x2011d039ea5cfc90:pn-0x2012d039ea5cfc90,host_traddr=nn-0x200000109bdacc75:pn-0x100000109bdacc75 live optimized +- nvme32 fc traddr=nn-0x2011d039ea5cfc90:pn-0x2013d039ea5cfc90,host_traddr=nn-0x200000109bdacc76:pn-0x100000109bdacc76 live optimizedNVMe/TCPThe following example outputs show a namespace hosted on a two-node ONTAP controller for an AFF, FAS, ASA, or ASA r2 system with NVMe/TCP.
nvme-subsys9 - NQN=nqn.1992-08.com.netapp:sn.9927e165694211f0b4f4d039eab31e9d:subsystem.nvme10 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b7cxxxx44d33 \ +- nvme105 tcp traddr=192.168.39.10,trsvcid=4420,host_traddr=192.168.39.20,src_addr=192.168.39.20 live optimized +- nvme153 tcp traddr=192.168.39.11,trsvcid=4420,host_traddr=192.168.39.20,src_addr=192.168.39.20 live non-optimized +- nvme57 tcp traddr=192.168.38.11,trsvcid=4420,host_traddr=192.168.38.20,src_addr=192.168.38.20 live non-optimized +- nvme9 tcp traddr=192.168.38.10,trsvcid=4420,host_traddr=192.168.38.20,src_addr=192.168.38.20 live optimizedShow example output for ASA r2
nvme-subsys4 - NQN=nqn.1992-08.com.netapp:sn.17e32b6e8c7f11f09545d039eac03c33:subsystem.Bidirectional_DHCP_1_0 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0054-xxxx-8039-c3cxxxx23034 \ +- nvme4 tcp traddr=192.168.20.28,trsvcid=4420,host_traddr=192.168.20.21,src_addr=192.168.20.21 live optimized +- nvme5 tcp traddr=192.168.20.29,trsvcid=4420,host_traddr=192.168.20.21,src_addr=192.168.20.21 live optimized +- nvme6 tcp traddr=192.168.21.28,trsvcid=4420,host_traddr=192.168.21.21,src_addr=192.168.21.21 live optimized +- nvme7 tcp traddr=192.168.21.29,trsvcid=4420,host_traddr=192.168.21.21,src_addr=192.168.21.21 live optimized -
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path NSID UUID Size ---------------- ----------------------- ----------------------- ----- -------------------------------------- -------- /dev/nvme1n1 vs_sanboot sanboot_169 /vol/nvme169/ns169 1 58443dbc-a472-45da-a5ef-3dd27c19d04b 171.80GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices":[ { "Device":"/dev/nvme11n1", "Vserver":"vs_sanboot", "Subsystem":"sanboot_169", "Namespace_Path": "/vol/nvme169/ns169", "NSID":1, "UUID":" 58443dbc-a472-45da-a5ef-3dd27c19d04b", "LBA_Size":4096, "Namespace_Size": 171798691840, "UsedBytes": 6016638976, "Version":"9.18.1" } ] }
Step 8: Set up secure in-band authentication
Secure in-band authentication is supported over NVMe/TCP between an Oracle Linux 10.x host and an ONTAP controller.
Each host or controller must be associated with a DH-HMAC-CHAP key to set up secure authentication. A DH-HMAC-CHAP key is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
Set up secure in-band authentication using the CLI or a config JSON file. Use a config JSON file if you need to specify different dhchap keys for different subsystems.
Set up secure in-band authentication using the CLI.
Obtain the host NQN:
cat /etc/nvme/hostnqn -
Generate the dhchap key for the Linux host.
The following output describes the
gen-dhchap-keycommand parameters:nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn • -s secret key in hexadecimal characters to be used to initialize the host key • -l length of the resulting key in bytes • -m HMAC function to use for key transformation 0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512 • -n host NQN to use for key transformationIn the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
# nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b7cxxxx44d33 DHHC-1:03:xhAfbAD5IVLZDxiVbmFEOA5JZ3F/ERqTXhHzZQJKgkYkTbPI9dhRyVtr4dBD+SGiAJO3by4FbnVtov1Lmk+86+nNc6k=:
On the ONTAP controller, add the host and specify both dhchap keys:
vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit} -
A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret> -
Validate the
nvme connect authenticationcommand by verifying the host and controller dhchap keys:-
Verify the host dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secretShow example output for a unidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=: DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=: DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=: DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:
Verify the controller dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secretShow example output for a bidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=: DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=: DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=: DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=:
When multiple NVMe subsystems are available on the ONTAP controller configuration, you can use the /etc/nvme/config.json file with the nvme connect-all command.
Use the -o option to generate the JSON file. See the NVMe connect-all manual pages for more syntax options.
Configure the JSON file:
Show example
[ { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b7cxxxx44d33", "hostid":"4c4cxxxx-0035-xxxx-804b-b7cxxxx44d33", "dhchap_key":"DHHC-1:01:nFg06gV0FNpXqoiLOF0L+swULQpZU/PjU9v/McDeJHjTZFlF:", "subsystems":[ { "nqn":"nqn.1992-08.com.netapp:sn.09035a8d8c8011f0ac0fd039eabac370:subsystem.subsys", "ports":[ { "transport":"tcp", "traddr":"192.168.30.69", "host_traddr":"192.168.41.7", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:03:n3F8d+bvxKW/s+lEhqXaOohI2sxrQ9iLutzduuFq49JgdjjaFtTpDSO9kQl/bvZj+Bo3rdHh3xPXeP6a4xyhcRyqdds=:" } ] } ] } ]In the preceding example, dhchap_keycorresponds todhchap_secretanddhchap_ctrl_keycorresponds todhchap_ctrl_secret. -
Connect to the ONTAP controller using the config JSON file:
nvme connect-all -J /etc/nvme/config.json -
Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secretThe following example shows a dhchap key:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secretYou should see an output similar to the following example:
Step 9: Review the known issues
There are no known issues.
