ONTAP SAN Host Utilities
Configure Oracle Linux 9.x for NVMe-oF with ONTAP storage
Contributors netapp-pcarriga netapp-sarajane netapp-camdenc
Oracle Linux hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for Oracle Linux 9.x. For more support and feature information, see Oracle Linux ONTAP support and features.
NVMe-oF with Oracle Linux 9.x has the following known limitation:
  • The nvme disconnect-all command disconnects both root and data filesystems and might lead to system instability. Do not issue this on systems booting from SAN over NVMe-TCP or NVMe-FC namespaces.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a NVMe namespace and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Reboot the host and verify that the OS is up and running.
Step 2: Install Oracle Linux and NVMe software and verify your configuration
Use the following procedure to validate the minimum supported Oracle Linux 9.x software versions.
Steps
  1. Install Oracle Linux 9.x on the server. After the installation is complete, verify that you are running the specified Oracle Linux 9.x kernel.
    uname -r
    Example Oracle Linux kernel version:
    6.12.0-105.51.5.el9uek.x86_64
  2. Install the nvme-cli package:
    rpm -qa|grep nvme-cli
    The following example shows an nvme-cli package version:
    nvme-cli-2.13-1.el9.x86_64
  3. Install the libnvme package:
    rpm -qa|grep libnvme
    The following example shows an libnvme package version:
    libnvme-1.13-1.el9.x86_64
  4. On the Oracle Linux 9.x host, check the hostnqn string at /etc/nvme/hostnqn:
    cat /etc/nvme/hostnqn
    The following example shows a hostnqn value:
    nqn.2014-08.org.nvmexpress:uuid:8397xxxx-30f0-xxxx-850f-7ed3xxxf0cc7
  5. On the ONTAP system, verify that the hostnqn string matches the hostnqn string for the corresponding subsystem on the ONTAP storage system:
    vserver nvme subsystem host show -vserver vs_coexistence_emulex
    Show example
    Vserver Subsystem Priority  Host NQN
            Nvme1     regular   nqn.2014-08.org.nvmexpress:uuid:8397cecc-30f0-11e8-850f-7ed30aef0cc7
            Nvme2     regular   nqn.2014-08.org.nvmexpress:uuid:8397cecc-30f0-11e8-850f-7ed30aef0cc7
    Note If the hostnqn strings don't match, you can use the vserver modify command to update the hostnqn string on your corresponding ONTAP array subsystem to match the hostnqn string from /etc/nvme/hostnqn on the host.
Step 3: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
NVMe/FC - Broadcom/Emulex
Configure NVMe/FC for a Broadcom/Emulex adapter.
Steps
  1. Verify that you're using the supported adapter model:
    1. Display the model names:
      cat /sys/class/scsi_host/host*/modelname
      You should see the following output:
      LPe36002-M64
      LPe36002-M64
    2. Display the model descriptions:
      cat /sys/class/scsi_host/host*/modeldesc
      You should see an output similar to the following example:
      Emulex LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
  2. Verify that you are using the recommended Broadcom lpfc firmware and inbox driver:
    1. Display the firmware version:
      cat /sys/class/scsi_host/host*/fwrev
      The following example shows firmware versions:
      14.4.725.15, sli-4:6:d
    2. Display the inbox driver version:
      cat /sys/module/lpfc/version
      The following example shows a driver version:
      0:14.4.0.8
      For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
  3. Verify that lpfc_enable_fc4_type is set to 3:
    cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
  4. Verify that you can view your initiator ports:
    cat /sys/class/fc_host/host*/<port_name>
    The following example shows port identities:
    0x100000620b3c089c
    0x100000620b3c089d
  5. Verify that your initiator ports are online:
    cat /sys/class/fc_host/host*/port_state
    Online
    Online
  6. Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
    cat /sys/class/scsi_host/host*/nvme_info
    Show example
    NVME Initiator Enabled
    XRI Dist lpfc0 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc0 WWPN x100000620b3c089c WWNN x200000620b3c089c DID x081300 ONLINE
    NVME RPORT       WWPN x2001d039eab0dadc WWNN x2000d039eab0dadc DID x080107 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2221d039eab0dadc WWNN x2220d039eab0dadc DID x080105 TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 000000713b Cmpl 000000713b Abort 00000001
    LS XMIT: Err 00000000  CMPL: xb 00000001 Err 00000001
    Total FCP Cmpl 00000000a513b8bb Issue 00000000a4f2485c OutIO ffffffffffde8fa1
            abort 00006935 noxri 000004f0 nondlp 0002e119 qdepth
    00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 0000693d Err 0009cb89
    XRI Dist lpfc1 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc1 WWPN x100000620b3c089d WWNN x200000620b3c089d DID x081900 ONLINE
    NVME RPORT       WWPN x2002d039eab0dadc WWNN x2000d039eab0dadc DID x080207 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2222d039eab0dadc WWNN x2220d039eab0dadc DID x080205 TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 0000007171 Cmpl 0000007171 Abort 00000000
    LS XMIT: Err 00000000  CMPL: xb 00000000 Err 00000000
    Total FCP Cmpl 00000000a509cecc Issue 00000000a4e7ed6c OutIO ffffffffffde1ea0
            abort 000069c5 noxri 00000406 nondlp 000301e6 qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 000069d6 Err 0009cbcds
NVMe/FC - Marvell/QLogic
Configure NVMe/FC for a Marvell/QLogic adapter.
Steps
  1. Verify that you are running the supported adapter driver and firmware versions:
    cat /sys/class/fc_host/host*/symbolic_name
    The following example shows driver and firmware versions:
    QLE2872 FW:v9.15.17 DVR:v10.02.09.300-k
  2. Verify that ql2xnvmeenable is set. This enables the Marvell adapter to function as an NVMe/FC initiator:
    cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
    The expected output is 1.
NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Steps
  1. Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
    nvme discover -t tcp -w host-traddr -a traddr
    Show example
    nvme discover -t tcp -w 192.168.41.7 -a 192.168.41.10
    Discovery Log Entry =====
    trtype: tcp
    adrfam: ipv4
    subtype: current discovery subsystem
    treq: not specified
    portid: 8
    trsvcid: 8009
    subnqn: nqn.1992-08.com.netapp:sn.06a49b19b3ee11f09dcad039eabac370:discovery
    traddr: 192.168.31.99
    eflags: explicit discovery connections, duplicate discovery information
    sectype: none
    Discovery Log Entry 1=====
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 8
    trsvcid: 8009
    traddr: 192.168.30.99
    sectype: none
    Discovery Log Entry 2=====
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 8
    trsvcid: 8009
    traddr: 192.168.31.98
    sectype: none
    Discovery Log Entry 3=====
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 5
    trsvcid: 8009
    traddr: 192.168.30.98
    sectype: none
    Discovery Log Entry 4=====
    trtype: tcp
    adrfam: ipv4
    subtype: nvme subsystem
    treq: not specified
    portid: 8
    trsvcid: 4420
    subnqn: nqn.1992-08.com.netapp:sn.06a49b19b3ee11f09dcad039eabac370:subsystem
    eflags: none
    sectype: none
    Discovery Log Entry 5=====
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 6
    trsvcid: 4420
    eflags: none
    sectype: none
    Discovery Log Entry 6=====
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 7
    trsvcid: 4420
    eflags: none
    sectype: none
    Discovery Log Entry 7=====
    trtype: tcp
    adrfam: ipv4
    treq: not specified
    portid: 5
    trsvcid: 4420
    eflags: none
    sectype: none
  2. Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
    Show example
    nvme discover -t tcp -w 192.168.41.7 -a 192.168.41.11
    nvme discover -t tcp -w 192.168.48.7 -a 192.168.48.10
    nvme discover -t tcp -w 192.168.48.7 -a 192.168.48.11
  3. Run the nvme connect-all command across all the supported NVMe/TCP initiator-target LIFs across the nodes:
    nvme connect-all -t tcp -w host-traddr -a traddr
    Show example
    nvme connect-all -t tcp -w 192.168.41.7 -a 192.168.41.10
    nvme connect-all -t tcp -w 192.168.41.7 -a 192.168.41.11
    nvme connect-all -t tcp -w 192.168.48.7 -a 192.168.48.10
    nvme connect-all -t tcp -w 192.168.48.7 -a 192.168.48.11
Note
Beginning with Oracle Linux 9.4, the setting for the NVMe/TCP ctrl_loss_tmo timeout is automatically set to "off". As a result:
  • There are no limits on the number of retries (indefinite retry).
  • You don't need to manually configure a specific ctrl_loss_tmo timeout duration when using the nvme connect or nvme connect-all commands (option -l ).
  • The NVMe/TCP controllers don't experience timeouts in the event of a path failure and remain connected indefinitely.
Step 4: Optionally, modify the iopolicy in the udev rules
The Oracle Linux 9.x the host sets the default iopolicy for NVMe-oF to round-robin. Beginning with Oracle Linux 9.6, you can change the iopolicy to queue-depth by modifying the udev rules file.
Steps
  1. Open the udev rules file in a text editor with root privileges:
    /usr/lib/udev/rules.d/71-nvmf-netapp.rules
    vi /usr/lib/udev/rules.d/71-nvmf-netapp.rules
  2. Find the line that sets iopolicy for the NetApp ONTAP Controller.
    The following example shows an example rule:
    ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="queue-depth"
  3. Modify the rule so that queue-depth becomes round-robin:
    ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="round-robin"
  4. Reload the udev rules and apply the changes:
    udevadm control --reload
    udevadm trigger --subsystem-match=nvme-subsystem
  5. Verify the current iopolicy for your subsystem:
    cat /sys/class/nvme-subsystem/<subsystem>/iopolicy
    round-robin
Note The new iopolicy applies automatically to matching NetApp ONTAP Controller devices. No reboot is required.
Step 5: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
Note These steps don't apply to Qlogic NVMe/FC hosts.
Steps
  1. Set the lpfc_sg_seg_cnt parameter to 256:
    cat /etc/modprobe.d/lpfc.conf
    options lpfc lpfc_sg_seg_cnt=256
  2. Run the dracut -f command, and reboot the host.
  3. Verify that the value for lpfc_sg_seg_cnt is 256:
    cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 6: Verify NVMe boot services
The nvmefc-boot-connections.service and nvmf-autoconnect.service boot services included in the NVMe/FC nvme-cli package are automatically enabled when the system boots.
After booting completes, verify that the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services are enabled.
Steps
  1. Verify that nvmf-autoconnect.service is enabled:
    systemctl status nvmf-autoconnect.service
    Show example output
    nvme-autoconnect.service - Connect NVMe-oF subsystems automatically during boot
      Loaded: loaded (/usr/lib/systemd/system/nvme-autoconnect.service; enabled; preset: disabled)
      Active: inactive (dead) since Tue 2026-02-02 09:48:11 EDT; 1 week 0 days ago
      Main PID: 2620 (code=exited, status=0/SUCCESS)
           CPU: 19ms
    Feb 02 09:48:11 sr630-13-169 systemdStarting Connect NVMe-oF subsystems automatically during boot...
    Feb 02 09:48:11 sr630-13-169 systemdnvme-autoconnect.service: Deactivated successfully.
    Feb 02 09:48:11 sr630-13-169 systemdFinished Connect NVMe-oF subsystems automatically during boot.
  2. Verify that nvmefc-boot-connections.service is enabled:
    systemctl status nvmefc-boot-connections.service
    Show example output
    nvmfcs-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot
      Loaded: loaded (/usr/lib/systemd/system/nvmfcs-bootconnections.service; enabled; preset: enabled)
      Active: inactive (dead) since Tue 2026-02-02 09:47:07 EDT; 1 week 0 days ago
      Main PID: 1651 (code=exited, status=0/SUCCESS)
           CPU: 14ms
    Feb 02 09:47:07 sr630-13-169 systemdStarting Auto-connect to subsystems on FC-NVME devices found during boot...
    Feb 02 09:47:07 sr630-13-169 systemdnvmfcs-bootconnections.service: Deactivated successfully.
    Feb 02 09:47:07 sr630-13-169 systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Step 7: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Steps
  1. Verify that the in-kernel NVMe multipath is enabled:
    cat /sys/module/nvme_core/parameters/multipath
    Y
  2. Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
    1. Display the subsystems:
      cat /sys/class/nvme-subsystem/nvme-subsys*/model
    2. Display the policy:
      cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
      You should see the value set for iopolicy, for example:
      queue-depth
      queue-depth
  3. Verify that the namespaces are created and correctly discovered on the host:
    nvme list
    Show example
    Node            Generic         SN                   Model                    Namespace  Usage                      Format         FW Rev
    /dev/nvme102n1  /dev/ng102n1    81LLqNYTindCAAAAAAAk NetApp ONTAP Controller   0x1          2.25  GB /   5.37  GB   4 KiB +  0 B   9.17.1
    /dev/nvme102n2  /dev/ng102n2    81LLqNYTindCAAAAAAAk NetApp ONTAP Controller   0x2          2.25  GB /   5.37  GB   4 KiB +  0 B   9.17.1
    /dev/nvme106n1  /dev/ng106n1    81LLqNYTindCAAAAAAAs NetApp ONTAP Controller   0x1          2.25  GB /   5.37  GB   4 KiB +  0 B   9.17.1
    /dev/nvme106n2  /dev/ng106n2    81LLqNYTindCAAAAAAAs NetApp ONTAP Controller   0x2          2.25  GB /   5.37  GB   4 KiB +  0 B   9.17.1
  4. Verify that the controller state of each path is live and has the correct ANA status:
    nvme list-subsys /dev/<controller_ID>
    Note Beginning with ONTAP 9.16.1, NVMe/FV and NVMe/TCP report all optimized paths on ASA r2 systems.
    NVMe/FC
    The following example outputs show a namespace hosted on a two-node ONTAP controller for an AFF, FAS, ASA, or ASA r2 system with NVMe/FC.
    Show AFF, FAS, and ASA example output
    nvme-subsys14 - NQN=nqn.1992-08.com.netapp:sn.9e30b9760a4911f08c87d039eab67a95:subsystem.sles_161_27 hostnqn=nqn.2014-08.org.nvmexpress:uuid:f6517cae-3133-11e8-bbff-7ed30aef123f
       iopolicy=round-robin
       +- nvme114 fc traddr=nn-0x234ed039ea359e4a:pn-0x2360d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live optimized
       +- nvme115 fc traddr=nn-0x234ed039ea359e4a:pn-0x2362d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live non-optimized
       +- nvme116 fc traddr=nn-0x234ed039ea359e4a:pn-0x2361d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live optimized
       +- nvme117 fc traddr=nn-0x234ed039ea359e4a:pn-0x2363d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live non-optimized
    Show ASA r2 example output
    nvme-subsys96 - NQN=nqn.1992-08.com.netapp:sn.b351b2b6777b11f0b3c2d039ea5cf9c1:subsystem.nvme24 hostnqn=nqn.2014-08.org.nvmexpress:uuid:d3b581b4-c975-11e6-8425-0894ef31a074
       +- nvme203 fc traddr=nn-0x2011d039ea5cfc90:pn-0x2015d039ea5cfc90,host_traddr=nn-0x200000109bdacc76:pn-0x100000109bdacc76 live optimized
       +- nvme25  fc traddr=nn-0x2011d039ea5cfc90:pn-0x2014d039ea5cfc90,host_traddr=nn-0x200000109bdacc75:pn-0x100000109bdacc75 live optimized
       +- nvme30  fc traddr=nn-0x2011d039ea5cfc90:pn-0x2012d039ea5cfc90,host_traddr=nn-0x200000109bdacc75:pn-0x100000109bdacc75 live optimized
       +- nvme32  fc traddr=nn-0x2011d039ea5cfc90:pn-0x2013d039ea5cfc90,host_traddr=nn-0x200000109bdacc76:pn-0x100000109bdacc76 live optimized
    NVMe/TCP
    The following example outputs show a namespace hosted on a two-node ONTAP controller for an AFF, FAS, ASA, or ASA r2 system with NVMe/TCP.
    nvme-subsys9 - NQN=nqn.1992-08.com.netapp:sn.9927e165694211f0b4f4d039eab31e9d:subsystem.nvme10 hostnqn=nqn.2014-08.org.nvmexpress:uuid:44cc4544-0035-5910-804b-b7c04f444d33
       +- nvme105 tcp traddr=192.168.39.10,trsvcid=4420,host_traddr=192.168.39.20,src_addr=192.168.39.20 live optimized
       +- nvme153 tcp traddr=192.168.39.11,trsvcid=4420,host_traddr=192.168.39.20,src_addr=192.168.39.20 live non-optimized
       +- nvme57  tcp traddr=192.168.38.11,trsvcid=4420,host_traddr=192.168.38.20,src_addr=192.168.38.20 live non-optimized
       +- nvme9   tcp traddr=192.168.38.10,trsvcid=4420,host_traddr=192.168.38.20,src_addr=192.168.38.20 live optimized
    nvme-subsys4 - NQN=nqn.1992-08.com.netapp:sn.17e32b6e8c7f11f09545d039eac03c33:subsystem.Bidirectional_DHCP_1_0 hostnqn=nqn.2014-08.org.nvmexpress:uuid:44cc4544-0054-5110-8039-c3c0f523034
       +- nvme4  tcp traddr=192.168.20.28,trsvcid=4420,host_traddr=192.168.20.21,src_addr=192.168.20.21 live optimized
       +- nvme5  tcp traddr=192.168.20.29,trsvcid=4420,host_traddr=192.168.20.21,src_addr=192.168.20.21 live optimized
       +- nvme6  tcp traddr=192.168.21.28,trsvcid=4420,host_traddr=192.168.21.21,src_addr=192.168.21.21 live optimized
       +- nvme7  tcp traddr=192.168.21.29,trsvcid=4420,host_traddr=192.168.21.21,src_addr=192.168.21.21 live optimized
  5. Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
    Column
    nvme netapp ontapdevices -o column
    Show example
    Device          Vserver     Namespace Path        NSID  UUID                                   Size
    /dev/nvme1n1    vs_sanboot  sanboot_169           1     58443dbc-a472-45da-a5ef-3dd27c19d04b   171.80GB
    JSON
    nvme netapp ontapdevices -o json
    Show example
      "ONTAPDevices": [
          "Device": "/dev/nvme11n1",
          "Vserver": "vs_sanboot",
          "Subsystem": "sanboot_169",
          "Namespace_Path": "/vol/nvme169/ns169",
          "NSID": 1,
          "UUID": "58443dbc-a472-45da-a5ef-3dd27c19d04b",
          "LBA_Size": 4096,
          "Namespace_Size": 171798691840,
          "UsedBytes": 6016638976,
          "Version": "9.18.1"
Step 8: Set up secure in-band authentication
Secure in-band authentication is supported over NVMe/TCP between a Oracle Linux 9.x host and an ONTAP controller.
Each host or controller must be associated with a DH-HMAC-CHAP key to set up secure authentication. A DH-HMAC-CHAP key is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
Steps
Set up secure in-band authentication using the CLI or a config JSON file. Use a config JSON file if you need to specify different dhchap keys for different subsystems.
CLI
Set up secure in-band authentication using the CLI.
  1. Obtain the host NQN:
  2. Generate the dhchap key for the Linux host.
    The following output describes the gen-dhchap-key command paramters:
    nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn
    •	-s secret key in hexadecimal characters to be used to initialize the host key
    •	-l length of the resulting key in bytes
    •	-m HMAC function to use for key transformation
    0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512
    •	-n host NQN to use for key transformation
    In the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
    # nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-c4c04f425633
    DHHC-1:03:xhAfbAD5IVLZDxiVbmFEOA5JZ3F/ERqTXhHzZQJKgkYkTbPI9dhRyVtr4dBD+SGiAJO3by4FbnVtov1Lmk+86+nNc6k=
  3. On the ONTAP controller, add the host and specify both dhchap keys:
    vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit}
  4. A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
    nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret>
  5. Validate the nvme connect authentication command by verifying the host and controller dhchap keys:
    1. Verify the host dhchap keys:
      cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secret
      Show example output for a unidirectional configuration
      cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret
      DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:
    2. Verify the controller dhchap keys:
      cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secret
      Show example output for a bidirectional configuration
      cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret
      DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=:
JSON
When multiple NVMe subsystems are available on the ONTAP controller configuration, you can use the /etc/nvme/config.json file with the nvme connect-all command.
Use the -o option to generate the JSON file. See the NVMe connect-all manual pages for more syntax options.
  1. Configure the JSON file:
    Show example
        "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b7cxxxx44d33",
        "hostid":"4c4cxxxx-0035-xxxx-804b-b7cxxxx44d33",
        "dhchap_key":"DHHC-1:01:nFg06gV0FNpXqoiLOF0L+swULQpZU/PjU9v/McDeJHjTZFlF:",
        "subsystems":[
            "nqn":"nqn.1992-08.com.netapp:sn.09035a8d8c8011f0ac0fd039eabac370:subsystem.subsys",
            "ports":[
                "transport":"tcp",
                "traddr":"192.168.30.69",
                "host_traddr":"192.168.30.10",
                "trsvcid":"4420",
                "dhchap_ctrl_key":"DHHC-1:03:n3F8d+bvxKW/s+lEhqXaOohI2sxrQ9iLutzduuFq49JgdjjaFtTpDSO9kQl/bvZj+Bo3rdHh3xPXeP6a4xyhcRyqdds=:"
    Note In the preceding example, dhchap_key corresponds to dhchap_secret and dhchap_ctrl_key corresponds to dhchap_ctrl_secret.
  2. Connect to the ONTAP controller using the config JSON file:
    nvme connect-all -J /etc/nvme/config.json
  3. Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem:
      cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secret
      The following example shows a dhchap key:
      cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secret
Step 9: Review the known issues
There are no known issues.
