Configure Oracle Linux 8.x for NVMe-oF with ONTAP storage
Oracle Linux hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for Oracle Linux 8.x. For more support and feature information, see Oracle Linux ONTAP support and features.
NVMe-oF with Oracle Linux 8.x has the following known limitations:
SAN booting using the NVMe-oF protocol is not supported.
NetApp sanlun host utility support isn't available for NVMe-oF on an Oracle Linux 8.x host. Instead, you can rely on the NetApp plug-in included in the native
nvme-clipackage for all NVMe-oF transports. -
For Oracle Linux 8.2 and earlier, native NVMe/FC auto-connect scripts are not available in the nvme-cli package. Use the HBA vendor provided external auto-connect scripts.
For Oracle Linux 8.2 and earlier, round-robin load balancing is not enabled by default for NVMe multipathing. To enable this functionality, go to the step for writing a udev rule.
Step 1: Install Oracle Linux and NVMe software and verify your configuration
Use the following procedure to validate the minimum supported Oracle Linux 8.x software versions.
Install Oracle Linux 8.x on the server. After the installation is complete, verify that you are running the specified Oracle Linux 8.x kernel.
uname -rExample Oracle Linux kernel version:
5.15.0-206.153.7.1.el8uek.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cliThe following example shows an
nvme-clipackage version:nvme-cli-1.16-9.el8.x86_64
For Oracle Linux 8.2 and earlier, add the following string as a separate udev rule for
/lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules. This enables round-robin load balancing for NVMe multipath.cat /lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules Enable round-robin for NetApp ONTAP ACTION=="add", SUBSYSTEMS=="nvme-subsystem", ATTRS{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="round-robin" -
On the Oracle Linux 8.x host, check the
hostnqnstring at/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows a
hostnqnvalue:nqn.2014-08.org.nvmexpress:uuid:edd3xxxx-00f7-xxxx-a9dc-4d8xxxxd969a
On the ONTAP system, verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP storage system:vserver nvme subsystem host show -vserver vs_coexistence_LPE36002Show example
Vserver Subsystem Priority Host NQN ------- --------- -------- ------------------------------------------------ vs_coexistence_LPE36002 nvme regular nqn.2014-08.org.nvmexpress:uuid:edd3xxxx-00f7-xxxx-a9dc-4d8xxxxd969a nvme1 regular nqn.2014-08.org.nvmexpress:uuid:edd3xxxx-00f7-xxxx-a9dc-4d8xxxxd969a nvme2 regular nqn.2014-08.org.nvmexpress:uuid:edd3xxxx-00f7-xxxx-a9dc-4d8xxxxd969a nvme3 regular nqn.2014-08.org.nvmexpress:uuid:edd3xxxx-00f7-xxxx-a9dc-4d8xxxxd969a 4 entries were displayed.If the hostnqnstrings don't match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host. -
Optionally, to run both NVMe and SCSI co-existent traffic on the same host, NetApp recommends using the in-kernel NVMe multipath for ONTAP namespaces and
dm-multipathfor ONTAP LUNs respectively. This should exclude the ONTAP namespaces fromdm-multipathand preventdm-multipathfrom claiming the ONTAP namespace devices.-
Add the
enable_foreignsetting to the/etc/multipath.conffile.cat /etc/multipath.conf defaults { enable_foreign NONE } -
Restart the
multipathddaemon to apply the new setting.systemctl restart multipathd
Step 2: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you're using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe36002-M64 LPe36002-M64
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see an output similar to the following example:
Emulex LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe following example shows firmware versions:
14.4.317.10, sli-4:6:d 14.4.317.10, sli-4:6:d
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:14.2.0.13
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to "3":cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/<port_name>The following example shows port identities:
0x100000109bf0449c 0x100000109bf0449d
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109bf0449c WWNN x200000109bf0449c DID x061500 ONLINE NVME RPORT WWPN x200bd039eab31e9c WWNN x2005d039eab31e9c DID x020e06 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2006d039eab31e9c WWNN x2005d039eab31e9c DID x020a0a TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 000000002c Cmpl 000000002c Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000000008ffe8 Issue 000000000008ffb9 OutIO ffffffffffffffd1 abort 0000000c noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 0000000c Err 0000000c NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109bf0449d WWNN x200000109bf0449d DID x062d00 ONLINE NVME RPORT WWPN x201fd039eab31e9c WWNN x2005d039eab31e9c DID x02090a TARGET DISCSRVC ONLINE NVME RPORT WWPN x200cd039eab31e9c WWNN x2005d039eab31e9c DID x020d06 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000041 Cmpl 0000000041 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 00000000000936bf Issue 000000000009369a OutIO ffffffffffffffdb abort 00000016 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000016 Err 00000016
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameThe follow example shows driver and firware versions:
QLE2772 FW:v9.15.00 DVR:v10.02.09.100-k QLE2772 FW:v9.15.00 DVR:v10.02.09.100-k
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected output is 1.
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w <host-traddr> -a <traddr>Show example
nvme discover -t tcp -w 192.168.6.1 -a 192.168.6.24 Discovery Log Number of Records 20, Generation counter 45 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 6 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.6.25 sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.5.24 sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 4 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.6.24 sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:discovery traddr: 192.168.5.25 sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 6 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:subsystem.nvme_tcp_4 traddr: 192.168.6.25 sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.e6c438e66ac211ef9ab8d039eab31e9d:subsystem.nvme_tcp_4 ..........
Verify that all other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
nvme discover -t tcp -w 192.168.6.1 -a 192.168.6.24 nvme discover -t tcp -w 192.168.6.1 -a 192.168.6.25 nvme discover -t tcp -w 192.168.5.1 -a 192.168.5.24 nvme discover -t tcp -w 192.168.5.1 -a 192.168.5.25
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddr -l <ctrl_loss_timeout_in_seconds>Show example
nvme connect-all -t tcp -w 192.168.5.1 -a 192.168.5.24 -l -1 nvme connect-all -t tcp -w 192.168.5.1 -a 192.168.5.25 -l -1 nvme connect-all -t tcp -w 192.168.6.1 -a 192.168.6.24 -l -1 nvme connect-all -t tcp -w 192.168.6.1 -a 192.168.6.25 -l -1
NetApp recommends setting the |
Step 3: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 4: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model --------------------------------------------------------- /dev/nvme0n1 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n2 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller /dev/nvme0n3 814vWBNRwf9HAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF 2 85.90 GB / 85.90 GB 24 KiB + 0 B FFFFFFFF 3 85.90 GB / 85.90 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
nvme list-subsys /dev/nvme0n1Show NVMe/FC example
nvme-subsys0 - NQN=nqn.1992- 08.com.netapp: 4b4d82566aab11ef9ab8d039eab31e9d:subsystem.nvme\ +- nvme1 fc traddr=nn-0x2038d039eab31e9c:pn-0x203ad039eab31e9c host_traddr=nn-0x200034800d756a89:pn-0x210034800d756a89 live optimized +- nvme2 fc traddr=nn-0x2038d039eab31e9c:pn-0x203cd039eab31e9c host_traddr=nn-0x200034800d756a88:pn-0x210034800d756a88 live optimized +- nvme3 fc traddr=nn-0x2038d039eab31e9c:pn-0x203ed039eab31e9c host_traddr=nn-0x200034800d756a89:pn-0x210034800d756a89 live non-optimized +- nvme7 fc traddr=nn-0x2038d039eab31e9c:pn-0x2039d039eab31e9c host_traddr=nn-0x200034800d756a88:pn-0x210034800d756a88 live non-optimized
Show NVMe/TCP example
nvme-subsys0 - NQN=nqn.1992- 08.com.netapp: sn.e6c438e66ac211ef9ab8d039eab31e9d:subsystem.nvme_tcp_4 \ +- nvme1 tcp traddr=192.168.5.25 trsvcid=4420 host_traddr=192.168.5.1 src_addr=192.168.5.1 live optimized +- nvme10 tcp traddr=192.168.6.24 trsvcid=4420 host_traddr=192.168.6.1 src_addr=192.168.6.1 live optimized +- nvme2 tcp traddr=192.168.5.24 trsvcid=4420 host_traddr=192.168.5.1 src_addr=192.168.5.1 live non-optimized +- nvme9 tcp traddr=192.168.6.25 trsvcid=4420 host_traddr=192.168.6.1 src_addr=192.168.6.1 live non-optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path NSID UUID Size -------------- ------------------------ ----------------------------- ---- ------------------------------------- --------- /dev/nvme0n1 vs_coexistence_QLE2772 /vol/fcnvme_1_1_0/fcnvme_ns 1 159f9f88-be00-4828-aef6-197d289d4bd9 10.74GB /dev/nvme0n2 vs_coexistence_QLE2772 /vol/fcnvme_1_1_1/fcnvme_ns 2 2c1ef769-10c0-497d-86d7-e84811ed2df6 10.74GB /dev/nvme0n3 vs_coexistence_QLE2772 /vol/fcnvme_1_1_2/fcnvme_ns 3 9b49bf1a-8a08-4fa8-baf0-6ec6332ad5a4 10.74GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "vs_coexistence_QLE2772", "Namespace_Path" : "/vol/fcnvme_1_1_0/fcnvme_ns", "NSID" : 1, "UUID" : "159f9f88-be00-4828-aef6-197d289d4bd9", "Size" : "10.74GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 2621440 }, { "Device" : "/dev/nvme0n2", "Vserver" : "vs_coexistence_QLE2772", "Namespace_Path" : "/vol/fcnvme_1_1_1/fcnvme_ns", "NSID" : 2, "UUID" : "2c1ef769-10c0-497d-86d7-e84811ed2df6", "Size" : "10.74GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 2621440 }, { "Device" : "/dev/nvme0n4", "Vserver" : "vs_coexistence_QLE2772", "Namespace_Path" : "/vol/fcnvme_1_1_3/fcnvme_ns", "NSID" : 4, "UUID" : "f3572189-2968-41bc-972a-9ee442dfaed7", "Size" : "10.74GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 2621440 },
Step 5: Optionally, enable 1MB I/O size
Set the
Run the
Step 6: Review the known issues
These are the known issues:
| NetApp Bug ID | Title | Description |
Oracle Linux 8.x NVMe-oF hosts create duplicate Persistent Discovery Controllers (PDCs) |
On NVMe-oF hosts, you can use the |
