ONTAP SAN Host Utilities
ONTAP support and features for Proxmox hosts
Contributors netapp-pcarriga netapp-camdenc netapp-sarajane
Features supported for host configuration with NVMe over Fabrics (NVMe-oF) vary based on your version of ONTAP and Proxmox.
ONTAP feature Proxmox host version ONTAP version
NVMe/FC and NVMe/TCP report all optimized paths on ASA r2 systems
9.0 or later
9.16.1 or later
NVMe/TCP is a fully supported enterprise feature
9.0 or later
9.10.1 or later
Provides ONTAP details for both NVMe/FC and NVMe/TCP namespaces using the native nvme-cli package.
8.0 or later
9.10.1 or later
NVMe and SCSI traffic is supported on the same host using NVMe multipath for NVMe-oF namespaces and dm-multipath for SCSI LUNs
8.0 or later
9.4 or later
ONTAP supports the following SAN host features regardless of the ONTAP version running on your system setup.
Feature Proxmox host version
The nvme-cli package includes auto-connect scripts removing the need for third-party scripts
9.0 or later
The native udev rule in the nvme-cli package provides queue-depth load balancing for NVMe multipathing
9.0 or later
The native udev rule in the nvme-cli package provides round-robin load balancing for NVMe multipathing
9.0 or later
Native NVMe multipathing is enabled by default
8.0 or later
Note For details on supported configurations, see the Interoperability Matrix Tool.
What's next
If your Proxmox VE version is .. Learn about ..
9 series
Configuring NVMe for Proxmox VE 9.x
8 series
Configuring NVMe for Proxmox VE 8.x
