Configure Proxmox VE 9.x for NVMe-oF with ONTAP storage
The Proxmox VE 9.x host supports the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for Proxmox VE 9.x. For more support and feature information, see ONTAP support and features.
NVMe-oF with Proxmox VE 9.x has the following known limitation:
The SAN boot configuration for NVMe-FC is not supported.
Step 1: Install Proxmox VE and NVMe software and verify your configuration
To configure your host for NVMe-oF you need to install the host and NVMe software packages, enable multipathing, and verify your host NQN configuration.
Install Proxmox VE 9.x on the server. After the installation is complete, verify that you are running the required Proxmox VE 9.x kernel:
uname -rExample Proxmox VE 9.x kernel version:
7.0.14-5-pve
Install the
nvme-clipackage:apt list|grep nvme-cliThe following example shows an
nvme-clipackage version:nvme-cli/stable,now 2.13-2 amd64
Install the
libnvmepackage:apt list|grep libnvmeThe following example shows an
libnvmepackage version:libnvme-dev/stable 1.13-2 amd64
On the host, check the hostnqn string at
/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows a
hostnqnvalue:nqn.2014-08.org.nvmexpress:uuid:3933xxxx-3333-xxxx-4844-325xxxxa5247
On the ONTAP system, verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_proxmox_FC_NVMeFCShow example
Vserver Subsystem Priority Host NQN ------- --------- -------- ----------------------------------------------- vs_proxmox_FC_NVMeFC sub_176 regular nqn.2014-08.org.nvmexpress:uuid:3933xxxx-3333-xxxx-4844-325xxxxa4834 regular nqn.2014-08.org.nvmexpress:uuid:3933xxxx-3333-xxxx-4844-325xxxxa524c 2 entries were displayedIf the hostnqnstrings do not match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP storage system subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Step 2: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
SN1700E2P SN1700E2P
Show the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see an output similar to the following example:
HPE SN1700E 64Gb 2p FC HBA HPE SN1700E 64Gb 2p FC HBA
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe command returns the firmware versions:
14.4.473.14, sli-4:6:d 14.4.473.14, sli-4:6:d
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:14.4.0.13
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_nameYou should see an output similar to:
0x10005ced8c531948 0x10005ced8c531949
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x10005ced8c531948 WWNN x20005ced8c531948 DID x082400 ONLINE NVME RPORT WWPN x200ed039eac79573 WWNN x200dd039eac79573 DID x060902 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2001d039eac79573 WWNN x2000d039eac79573 DID x060904 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000034 Cmpl 0000000034 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 0000000000142cfb Issue 0000000000142cfc OutIO 0000000000000001 abort 00000005 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000005 Err 00000005 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x10005ced8c531949 WWNN x20005ced8c531949 DID x082500 ONLINE NVME RPORT WWPN x2010d039eac79573 WWNN x200dd039eac79573 DID x062902 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2007d039eac79573 WWNN x2000d039eac79573 DID x062904 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000034 Cmpl 0000000034 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 00000000000d39f1 Issue 00000000000d39f2 OutIO 0000000000000001 abort 00000005 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000005 Err 00000005
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are using the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameThe following example shows driver and firmware versions:
SN1700Q FW:v9.15.05 DVR:v10.02.10.100-k SN1700Q FW:v9.15.05 DVR:v10.02.10.100-k
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected output is 1.
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Check that the initiator port can get the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddrShow example
nvme discover -t tcp -w 192.168.165.72 -a 192.168.165.51 Discovery Log Number of Records 4, Generation counter 47 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:discovery traddr: 192.168.165.51 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:discovery traddr: 192.168.166.50 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:subsystem.sub_176 traddr: 192.168.165.51 eflags: none sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:subsystem.sub_176 traddr: 192.168.166.50 eflags: none sectype: none
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddrShow example
nvme connect-all -t tcp -w 192.168.166.73 -a 192.168.166.50 nvme connect-all -t tcp -w 192.168.166.73 -a 192.168.166.51 nvme connect-all -t tcp -w 192.168.165.73 -a 192.168.165.50 nvme connect-all -t tcp -w 192.168.165.73 -a 192.168.165.51
The setting for the NVMe/TCP
Step 3: Optionally, modify the iopolicy in the udev rules
Beginning with Proxmox VE 9.0, the default iopolicy for NVMe-oF is set to queue-depth. If you want to change the iopolicy to round-robin, which is also available as a configurable option, modify the udev rules file as follows:
Open the udev rules file in a text editor with root privileges:
/usr/lib/udev/rules.d/71-nvmf-netapp.rulesYou should see the following output:
vi /usr/lib/udev/rules.d/71-nvmf-netapp.rules
Find the line that sets iopolicy for the NetApp ONTAP Controller, as shown in the following example rule:
ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="queue-depth" -
Modify the rule so that
queue-depthis changed toround-robin, as shown in the following example:ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="round-robin" -
Reload the udev rules and apply the changes:
udevadm control --reload udevadm trigger --subsystem-match=nvme-subsystem -
Verify the current iopolicy for your subsystem:
cat /sys/class/nvme-subsystem/<subsystem>/iopolicyYou should see the following output:
round-robin
The new iopolicy applies automatically to matching NetApp ONTAP Controller devices. You don't need to reboot. |
Step 4: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
update-initramfscommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Verify NVMe boot services
The nvmefc-boot-connections.service and nvmf-autoconnect.service boot services included in the NVMe/FC nvme-cli package are automatically enabled when the system boots.
After booting completes, verify that the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services are enabled.
Verify that
nvmf-autoconnect.serviceis enabled:systemctl status nvmf-autoconnect.serviceShow example output
○ nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: enabled) Active: inactive (dead) since Fri 2026-02-20 22:00:40 IST; 2 days ago Invocation: 48e3574eef064ff98928f840a62d787a Process: 3507 ExecStart=/usr/sbin/nvme connect-all --context=autoconnect (code=exited, status=0/SUCCESS) Main PID: 3507 (code=exited, status=0/SUCCESS) Mem peak: 6.9M CPU: 46ms -
Verify that
nvmefc-boot-connections.serviceis enabled:systemctl status nvmefc-boot-connections.serviceShow example output
nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot-connections.service; enabled; preset: enabled) Active: inactive (dead) since Fri 2026-02-20 22:00:11 IST; 2 days ago Invocation: 6f6d180fdbcd4fa6ad861c50ba6a15e6 Process: 1193 ExecStart=/bin/sh -c echo add > /sys/class/fc/fc_udev_device/nvme_discovery (code=exited, status=0/SUCCESS) Main PID: 1193 (code=exited, status=0/SUCCESS) Mem peak: 2.2M CPU: 10ms Feb 20 22:00:11 HPE-DL365-14-176 systemd[1]: nvmefc-boot-connections.service: Deactivated successfully. Feb 20 22:00:11 HPE-DL365-14-176 systemd[1]: Finished nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot.
Step 6: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the ONTAP namespaces show up correctly on the host:
Show the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
queue-depth queue-depth
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node Generic SN Model Namespace Usage Format FW Rev ------------- ----------- -------------------- ------------------------ ---------- -------------------------- ---------------- -------- /dev/nvme2n1 /dev/ng2n1 81PqYFYq2aVAAAAAAAAB NetApp ONTAP Controller 0x1 17.88 GB / 171.80 GB 4 KiB + 0 B 9.19.1
Verify that the controller state of each path is live and has the correct ANA status:
nvme list-subsys /dev/<controller_ID>Beginning with ONTAP 9.16.1, NVMe/FC and NVMe/TCP report all optimized paths on ASA r2 systems. NVMe/FCThis following example outputs show a namespace hosted on a two-node ONTAP controller for an AFF, FAS, ASA, or ASA r2 system with NVMe/FC.
Show AFF, FAS, or ASA example output
nvme-subsys3 - NQN=nqn.1992-08.com.netapp:sn.94929fdb84eb11f0b624d039eac809ba:subsystem.sub_176 hostnqn=nqn.2014-08.org.nvmexpress:uuid:3933xxxx-3333-xxxx-4844-325xxxxa524\ +- nvme1 fc traddr=nn-0x200dd039eac79573:pn-0x2360d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10005ced8c531949 live optimized +- nvme3 fc traddr=nn-0x200dd039eac79573:pn-0x200ed039eac79573,host_traddr=nn-0x20005ced8c531948:pn-0x10005ced8c531948 live non-optimized +- nvme5 fc traddr=nn-0x200dd039eac79573:pn-0x200fd039eac79573,host_traddr=nn-0x20005ced8c531949:pn-0x10005ced8c531949 live optimized +- nvme7 fc traddr=nn-0x200dd039eac7957a:pn-0x2011d039eac79573,host_traddr=nn-0x20005ced8c531948:pn-0x10005ced8c531948 live non-optimizedShow ASA r2 example output
nvme-subsys3 - NQN=nqn.1992-08.com.netapp:sn.94929fdb84eb11f0b624d039eac809ba:subsystem.sub_176 hostnqn=nqn.2014-08.org.nvmexpress:uuid:3933xxxx-3333-xxxx-4844-325xxxxa524c \ +- nvme1 fc traddr=nn-0x200dd039eac79573:pn-0x2010d039eac79573,host_traddr=nn-0x20005ced8c531949:pn-0x10005ced8c531949 live optimized +- nvme3 fc traddr=nn-0x200dd039eac79573:pn-0x200ed039eac79573,host_traddr=nn-0x20005ced8c531948:pn-0x10005ced8c531948 live optimized +- nvme5 fc traddr=nn-0x200dd039eac79573:pn-0x200fd039eac79573,host_traddr=nn-0x20005ced8c531949:pn-0x10005ced8c531949 live optimized +- nvme7 fc traddr=nn-0x200dd039eac79573:pn-0x2011d039eac79573,host_traddr=nn-0x20005ced8c531948:pn-0x10005ced8c531948 live optimizedNVMe/TCPThis following example outputs show a namespace hosted on a two-node ONTAP controller for an AFF, FAS, ASA, or ASA r2 system with NVMe/TCP.
nvme-subsys2 - NQN=nqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:subsystem.sub_176 hostnqn=nqn.2014-08.org.nvmexpress:uuid:3933xxxx-3333-xxxx-4844-325xxxxa524c \ +- nvme2 tcp traddr=192.168.166.50,trsvcid=4420,host_traddr=192.168.166.73,src_addr=192.168.166.73 live optimized +- nvme4 tcp traddr=192.168.165.51,trsvcid=4420,host_traddr=192.168.165.73,src_addr=192.168.165.73 live optimized +- nvme6 tcp traddr=192.168.166.51,trsvcid=4420,host_traddr=192.168.166.73,src_addr=192.168.166.73 live non-optimized +- nvme8 tcp traddr=192.168.165.50,trsvcid=4420,host_traddr=192.168.165.73,src_addr=192.168.165.73 live non-optimizedShow ASA r2 example output
nvme-subsys9 - NQN=nqn.1992-08.com.netapp:sn.9927e165694211f0b4f4d039eab31e9d:subsystem.nvme10 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b7cxxxx44d33 \ +- nvme105 tcp traddr=192.168.39.10,trsvcid=4420,host_traddr=192.168.39.20,src_addr=192.168.39.20 live optimized +- nvme153 tcp traddr=192.168.39.11,trsvcid=4420,host_traddr=192.168.39.20,src_addr=192.168.39.20 live optimized +- nvme57 tcp traddr=192.168.38.11,trsvcid=4420,host_traddr=192.168.38.20,src_addr=192.168.38.20 live optimized +- nvme9 tcp traddr=192.168.38.10,trsvcid=4420,host_traddr=192.168.38.20,src_addr=192.168.38.20 live optimized -
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path ------------- --------------------- ------------------------------ /dev/nvme2n9 vs_proxmox_FC_NVMeFC /vol/vol_180_data_nvmefc4/ns NSID UUID Size ---- ------------------------------------ -------- 1 e3d3d544-de8b-4787-93af-bfec7769e909 32.21GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "Device":"/dev/nvme2n9", "Vserver":"vs_proxmox_FC_NVMeFC", "Subsystem":"sub_176", "Namespace_Path":"/vol/vol_180_data_nvmefc4/ns", "NSID":9, "UUID":"e3d3d544-de8b-4787-93af-bfec7769e909", "LBA_Size":4096, "Namespace_Size":32212254720, "UsedBytes":67899392, "Version":"9.19.1" } ]
Step 7: Review the known issues
There are no known issues.
