ONTAP SAN Host Utilities
ONTAP support and features for RHEL hosts
Contributors netapp-pcarriga netapp-sarajane
Features supported for host configuration with NVMe over Fabrics (NVMe-oF) vary based on your version of ONTAP and RHEL.
Feature RHEL host version ONTAP version
NVMe/FC and NVMe/TCP report all optimized paths on ASA r2 systems
9.0 or later
9.16.1 or later
Secure in-band authentication is supported over NVMe/TCP between a RHEL host and an ONTAP controller
9.3 or later
9.12.1 or later
NVMe/TCP provides namespaces using the native nvme-cli package
8.2 or later
9.10.1 or later
NVMe/TCP is a fully supported enterprise feature
9.0 or later
9.10.1 or later
NVMe and SCSI traffic is supported on the same host using NVMe multipath for NVMe-oF namespaces and dm-multipath for SCSI LUNs
8.2 or later
9.4 or later
ONTAP supports the following SAN host features regardless of the ONTAP version running on your system setup.
Native NVMe multipathing is enabled by default
10.0 or later
The native udev rule in the nvme-cli package provides queue-depth load balancing for NVMe multipathing
9.6 or later
SAN booting is enabled using the NVMe/FC protocol
9.4 or later
The nvme-cli package includes auto-connect scripts removing the need for third-party scripts
8.2 or later
The native udev rule in the nvme-cli package provides round-robin load balancing for NVMe multipathing
8.2 or later
Note For details on supported configurations, see the Interoperability Matrix Tool.
What's next
If your RHEL version is …​ Learn about …​
10 series
Configuring NVMe for RHEL 10.x
9 series
Configuring NVMe for RHEL 9.x
8 series
Configuring NVMe for RHEL 8.x
