ONTAP SAN Host Utilities
Configure RHEL 8.x for NVMe-oF with ONTAP storage
Contributors netapp-sarajane netapp-pcarriga
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for RHEL 8.x. For more support and feature information, see RHEL ONTAP support and features.
NVMe-oF with RHEL 8.x has the following known limitations:
  • SAN booting using the NVMe-oF protocol is not currently supported.
  • In-kernel NVMe multipath is disabled by default on NVMe-oF hosts in RHEL 8.x; you must enable it manually.
  • NVMe/TCP is available as a technology preview due to known issues.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a NVMe namespace and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Reboot the host and verify that the OS is up and running.
Step 2: Install RHEL and NVMe software and verify your configuration
To configure your host for NVMe-oF you need to install the host and NVMe software packages, enable multipathing, and verify your host NQN configuration.
Steps
  1. Install RHEL 8.x on the server. After the installation is complete, verify that you are running the required RHEL 8.x kernel:
    uname -r
    Example RHEL kernel version:
    4.18.0-553.el8_10.x86_64
  2. Install the nvme-cli package:
    rpm -qa|grep nvme-cli
    The following example shows an nvme-cli package version:
    nvme-cli-1.16-9.el8.x86_64
  3. Install the libnvme package:
    rpm -qa|grep libnvme
    The following example shows an libnvme package version:
    libnvme-1.4-3.el8.x86_64
  4. Enable in-kernel NVMe multipath:
    grubby --args=nvme_core.multipath=Y --update-kernel /boot/vmlinuz-4.18.0-553.el8_10.x86_64
  5. On the RHEL 8.x host, check the hostnqn string at /etc/nvme/hostnqn:
    cat /etc/nvme/hostnqn
    The following example shows a hostnqn version:
    nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0032-xxxx-8035-b8cxxxxc5132
  6. On the ONTAP system, verify that the hostnqn string matches the hostnqn string for the corresponding subsystem on the ONTAP storage system:
    ::> vserver nvme subsystem host show -vserver vs_fcnvme_141
    Show example
    Vserver     Subsystem          Host NQN
    vs_25_2742   rhel_101_QLe2772    nqn.2014-08.org.nvmexpress:uuid:5463xxxx-160f-xxxx-89aa-98bxxxx440ca
    Note If the hostnqn strings do not match, use the vserver modify command to update the hostnqn string on your corresponding ONTAP storage system subsystem to match the hostnqn string from /etc/nvme/hostnqn on the host.
  7. Reboot the host.
    Note
    To run both NVMe and SCSI traffic on the same host, NetApp recommends using the in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs. To prevent dm-multipath from claiming ONTAP namespace devices, exclude them by adding the enable_foreign setting to the /etc/multipath.conf file:
    cat /etc/multipath.conf
    defaults {
            enable_foreign     NONE
Step 3: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
NVMe/FC - Broadcom/Emulex
Configure NVMe/FC for a Broadcom/Emulex adapter.
Steps
  1. Verify that you are using the supported adapter model:
    1. Display the model names:
      cat /sys/class/scsi_host/host*/modelname
      You should see the following output:
      LPe32002-M2
      LPe32002-M2
    2. Display the model descriptions:
      cat /sys/class/scsi_host/host*/modeldesc
      You should see an output similar to the following example:
      Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
  2. Verify that you are using the recommended Broadcom lpfc firmware and inbox driver:
    1. Display the firmware version:
      cat /sys/class/scsi_host/host*/fwrev
      The command returns the firmware versions:
      14.2.539.21, sli-4:2:c
    2. Display the inbox driver version:
      cat /sys/module/lpfc/version
      The following example shows a driver version:
      0:14.0.0.21
    For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
  3. Verify that lpfc_enable_fc4_type is set to 3:
    cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
  4. Verify that you can view your initiator ports:
    cat /sys/class/fc_host/host*/port_name
    You should see an output similar to:
    0x10000090fae0ec88
    0x10000090fae0ec89
  5. Verify that your initiator ports are online:
    cat /sys/class/fc_host/host*/port_state
    Online
    Online
  6. Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
    cat /sys/class/scsi_host/host*/nvme_info
    Show example
    NVME Initiator Enabled
    XRI Dist lpfc0 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc0 WWPN x100000109bf044b1 WWNN x200000109bf044b1 DID x022a00 ONLINE
    NVME RPORT       WWPN x211ad039eaa7dfc8 WWNN x2119d039eaa7dfc8 DID x021302 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x211cd039eaa7dfc8 WWNN x2119d039eaa7dfc8 DID x020b02 TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 00000001ff Cmpl 00000001ff Abort 00000000
    LS XMIT: Err 00000000  CMPL: xb 00000000 Err 00000000
    Total FCP Cmpl 0000000001330ec7 Issue 0000000001330ec9 OutIO 0000000000000002
            abort 00000330 noxri 00000000 nondlp 0000000b qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 00000354 Err 00000361
    XRI Dist lpfc1 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc1 WWPN x100000109bf044b2 WWNN x200000109bf044b2 DID x021b00 ONLINE
    NVME RPORT       WWPN x211bd039eaa7dfc8 WWNN x2119d039eaa7dfc8 DID x022902 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x211dd039eaa7dfc8 WWNN x2119d039eaa7dfc8 DID x020102 TARGET DISCSRVC ONLINE
    NVME Statistics
    Total FCP Cmpl 00000000012ec220 Issue 00000000012ec222 OutIO 0000000000000002
            abort 0000033b noxri 00000000 nondlp 00000085 qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 00000368 Err 00000382
NVMe/FC - Marvell/QLogic
Configure NVMe/FC for a Marvell/QLogic adapter.
Steps
  1. Verify that you are using the supported adapter driver and firmware versions:
    cat /sys/class/fc_host/host*/symbolic_name
    The following example shows driver and firmware versions:
    QLE2742 FW: v9.10.11 DVR: v10.02.08.200-k
  2. Verify that ql2xnvmeenable is set. This enables the Marvell adapter to function as an NVMe/FC initiator:
    cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
    The expected output is 1.
NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Steps
  1. Check that the initiator port can get the discovery log page data across the supported NVMe/TCP LIFs:
    nvme discover -t tcp -w host-traddr -a traddr
    Show example
    nvme discover -t tcp -w 192.168.2.31 -a 192.168.2.25
    Discovery Log Number of Records 8, Generation counter 18
    =====Discovery Log Entry 0======
    trtype:  tcp
    adrfam:  ipv4
    subtype: unrecognized
    treq:    not specified.
    portid:  0
    trsvcid: 8009
    subnqn:  nqn.1992-08.com.netapp:sn.a1b2b785b9de11ee8e7fd039ea9e8ae9:discovery
    traddr:  192.168.1.25
    sectype: none
    =====Discovery Log Entry 1======
    trtype:  tcp
    adrfam:  ipv4
    portid:  1
    trsvcid: 8009
    traddr:  192.168.2.26
    sectype: none
  2. Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
    Show example
    nvme  discover  -t  tcp  -w 192.168.1.31  -a 192.168.1.24
    nvme  discover  -t  tcp  -w 192.168.2.31  -a 192.168.2.26
    nvme  discover  -t  tcp  -w 192.168.1.31  -a 192.168.1.25
  3. Run the nvme connect-all command across all the supported NVMe/TCP initiator-target LIFs across the nodes:
    nvme connect-all -t tcp -w host-traddr -a traddr
    Show example
    nvme connect-all -t tcp -w 192.168.2.31 -a 192.168.2.25 -l 1800
    nvme connect-all -t tcp -w 192.168.1.31 -a 192.168.1.24 -l 1800
    nvme connect-all -t tcp -w 192.168.2.31 -a 192.168.2.26 -l 1800
    nvme connect-all -t tcp -w 192.168.1.31 -a 192.168.1.25 -l 1800
Step 4: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
Note These steps don't apply to Qlogic NVMe/FC hosts.
Steps
  1. Set the lpfc_sg_seg_cnt parameter to 256:
    cat /etc/modprobe.d/lpfc.conf
    options lpfc lpfc_sg_seg_cnt=256
  2. Run the dracut -f command, and reboot the host.
  3. Verify that the value for lpfc_sg_seg_cnt is 256:
    cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Steps
  1. Verify that the in-kernel NVMe multipath is enabled:
    cat /sys/module/nvme_core/parameters/multipath
    Y
  2. Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
    1. Display the subsystems:
      cat /sys/class/nvme-subsystem/nvme-subsys*/model
    2. Display the policy:
      cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
      round-robin
      round-robin
  3. Verify that the namespaces are created and correctly discovered on the host:
    nvme list
    Show example
    Node         SN                   Model
    /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB	NetApp ONTAP Controller
    Namespace Usage    Format             FW             Rev
    1                 21.47 GB / 21.47 GB	4 KiB + 0 B   FFFFFFFF
  4. Verify that the controller state of each path is live and has the correct ANA status:
    nvme list-subsys /dev/nvme0n1
    Show NVMe/FC example
    nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.0cd9ee0dc0ec11ee8e7fd039ea9e8ae9:subsystem.nvme
     +- nvme1 fc traddr=nn-0x2005d039eaa7dfc8:pn-0x2086d039eaa7dfc8 host_traddr=nn-0x20000024ff752e6d:pn-0x21000024ff752e6d live non-optimized
     +- nvme2 fc traddr=nn-0x2005d039eaa7dfc8:pn-0x2016d039eaa7dfc8 host_traddr=nn-0x20000024ff752e6c:pn-0x21000024ff752e6c live optimized
     +- nvme3 fc traddr=nn-0x2005d039eaa7dfc8:pn-0x2081d039eaa7dfc8 host_traddr=nn-0x20000024ff752e6c:pn-0x21000024ff752e6c live non-optimized
     +- nvme4 fc traddr=nn-0x2005d039eaa7dfc8:pn-0x2087d039eaa7dfc8 host_traddr=nn-0x20000024ff752e6d:pn-0x21000024ff752e6d live optimized
    Show NVMe/TCP example
    nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.a1b2b785b9de11ee8e7fd039ea9e8ae9:subsystem.nvme_tcp_1
     +- nvme0 tcp traddr=192.168.2.26 trsvcid=4420 host_traddr=192.168.2.31 live non-optimized
     +- nvme1 tcp traddr=192.168.2.25 trsvcid=4420 host_traddr=192.168.2.31 live optimized
     +- nvme2 tcp traddr=192.168.1.25 trsvcid=4420 host_traddr=192.168.1.31 live non-optimized
     +- nvme3 tcp traddr=192.168.1.24 trsvcid=4420 host_traddr=192.168.1.31 live optimized
  5. Verify that the namespaces are created and correctly discovered on the host:
    nvme list
    Show example
    Node         SN                   Model
  6. Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
    Column
    nvme netapp ontapdevices -o column
    Show example
    Device        Vserver       Namespace Path
    /dev/nvme0n1  tcpiscsi_129  /vol/tcpnvme_1_0_0/tcpnvme_ns
    NSID       UUID                                   Size
    1          05c2c351-5d7f-41d7-9bd8-1a56c	        21.47GB
    JSON
    nvme netapp ontapdevices -o json
    Show example
      "ONTAPdevices": [
          "Device": "/dev/nvme0n1",
          "Vserver": "tcpiscsi_129",
          "Namespace Path”: /vol/tcpnvme_1_0_0/tcpnvme_ns ",
          "NSID": 1,
          "UUID": " 05c2c351-5d7f-41d7-9bd8-1a56c160c80b ",
          "Size2: "21.47GB",
          "LBA_Data_Size": 4096,
          "Namespace Size" : 5242880
Step 6: Review the known issues
These are the known issues:
NetApp Bug ID Title Description
1479047
RHEL 8.x NVMe-oF hosts create duplicate persistent discovery controllers (PDCs)
On NVMe-oF hosts, you can use the "nvme discover -p" command to create PDCs. When this command is used, only one PDC should be created per initiator-target combination. However, if you are running RHEL 8.x on an NVMe-oF host, a duplicate PDC is created each time "nvme discover -p" is executed. This leads to unnecessary usage of resources on both the host and the target.
