ONTAP SAN Host Utilities
Configure SUSE Linux Enterprise Server 15 SPx for NVMe-oF with ONTAP storage
Contributors netapp-pcarriga netapp-sarajane
The SUSE Linux Enterprise Server 15 SPx host supports the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for SUSE Linux Enterprise Server 15 SPx. For more support and feature information, see ONTAP support and features.
NVMe-oF with SUSE Linux Enterprise Server 15 SPx has the following known limitations:
  • The nvme disconnect-all command disconnects both root and data filesystems and might lead to system instability. Do not issue this on systems booting from SAN over NVMe-TCP or NVMe-FC namespaces.
  • NetApp sanlun host utility support isn't available for NVMe-oF. Instead, you can rely on the NetApp plug-in included in the native nvme-cli package for all NVMe-oF transports.
  • For SUSE Linux Enterprise Server 15 SP6 and earlier, SAN booting using the NVMe-oF protocol is not supported.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a NVMe namespace and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Reboot the host and verify that the OS is up and running.
Step 2: Install SUSE Linux Enterprise Server and NVMe software and verify your configuration
To configure your host for NVMe-oF you need to install the host and NVMe software packages, enable multipathing, and verify your host NQN configuration.
Steps
  1. Install SUSE Linux Enterprise Server 15 SPx on the server. After the installation is complete, verify that you are running the specified SUSE Linux Enterprise Server 15 SPx kernel:
    uname -r
    Example SUSE Linux Enterprise Server kernel version:
    6.4.0-150700.53.34-default
  2. Install the nvme-cli package:
    rpm -qa|grep nvme-cli
    The following example shows an nvme-cli package version:
    nvme-cli-2.11+22.gd31b1a01-150700.3.3.2.x86_64
  3. Install the libnvme package:
    rpm -qa|grep libnvme
    The following example shows an libnvme package version:
    libnvme1-1.11+4.ge68a91ae-150700.4.3.2.x86_64
  4. On the host, check the hostnqn string at /etc/nvme/hostnqn:
    cat /etc/nvme/hostnqn
    The following example shows a hostnqn version:
    nqn.2014-08.org.nvmexpress:uuid:f651xxxx-3133-xxxx-bbff-7edxxxxf123f
  5. On the ONTAP system, verify that the hostnqn string matches the hostnqn string for the corresponding subsystem on the ONTAP array:
    ::> vserver nvme subsystem host show -vserver vs_coexistence_LPE36002
    Show example
    Vserver Subsystem Priority  Host NQN
            nvme
                      regular   nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0056-xxxx-8048-b9cxxxx25633
            nvme_1
            nvme_2
            nvme_3
    4 entries were displayed.
    Note If the hostnqn strings do not match, use the vserver modify command to update the hostnqn string on your corresponding ONTAP array subsystem to match the hostnqn string from /etc/nvme/hostnqn on the host.
Step 3: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
NVMe/FC - Broadcom/Emulex
Configure NVMe/FC for a Broadcom/Emulex FC adapter.
Steps
  1. Verify that you are using the supported adapter model:
    1. Display the model names:
      cat /sys/class/scsi_host/host*/modelname
      You should see the following output:
      LPe36002-M64
      LPe36002-M64
    2. Display the model descriptions:
      cat /sys/class/scsi_host/host*/modeldesc
      Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
  2. Verify that you are using the recommended Broadcom lpfc firmware and inbox driver:
    1. Display the firmware version:
      cat /sys/class/scsi_host/host*/fwrev
      The following example shows firmware versions:
      14.4.393.25, sli-4:2:c
    2. Display the inbox driver version:
      cat /sys/module/lpfc/version
      The following example shows a driver version:
      0:14.4.0.8
    For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
  3. Verify that the expected output of lpfc_enable_fc4_type is set to 3:
    cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
  4. Verify that you can view your initiator ports:
    cat /sys/class/fc_host/host*/port_name
    You should see an output similar to:
    0x10000090fae0ec88
    0x10000090fae0ec89
  5. Verify that your initiator ports are online:
    cat /sys/class/fc_host/host*/port_state
    Online
    Online
  6. Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
    cat /sys/class/scsi_host/host*/nvme_info
    Show example output
    NVME Initiator Enabled
    XRI Dist lpfc0 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc0 WWPN x10000090fae0ec88 WWNN x20000090fae0ec88 DID x0a1300 ONLINE
    NVME RPORT       WWPN x23b1d039ea359e4a WWNN x23aed039ea359e4a DID x0a1c01 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x22bbd039ea359e4a WWNN x22b8d039ea359e4a DID x0a1c0b TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2362d039ea359e4a WWNN x234ed039ea359e4a DID x0a1c10 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x23afd039ea359e4a WWNN x23aed039ea359e4a DID x0a1a02 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x22b9d039ea359e4a WWNN x22b8d039ea359e4a DID x0a1a0b TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2360d039ea359e4a WWNN x234ed039ea359e4a DID x0a1a11 TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 0000004ea0 Cmpl 0000004ea0 Abort 00000000
    LS XMIT: Err 00000000  CMPL: xb 00000000 Err 00000000
    Total FCP Cmpl 0000000000102c35 Issue 0000000000102c2d OutIO fffffffffffffff8
            abort 00000175 noxri 00000000 nondlp 0000021d qdepth 00000000 wqerr 00000007 err 00000000
    FCP CMPL: xb 00000175 Err 0000058b
    XRI Dist lpfc1 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc1 WWPN x10000090fae0ec89 WWNN x20000090fae0ec89 DID x0a1200 ONLINE
    NVME RPORT       WWPN x23b2d039ea359e4a WWNN x23aed039ea359e4a DID x0a1d01 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x22bcd039ea359e4a WWNN x22b8d039ea359e4a DID x0a1d0b TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2363d039ea359e4a WWNN x234ed039ea359e4a DID x0a1d10 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x23b0d039ea359e4a WWNN x23aed039ea359e4a DID x0a1b02 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x22bad039ea359e4a WWNN x22b8d039ea359e4a DID x0a1b0b TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2361d039ea359e4a WWNN x234ed039ea359e4a DID x0a1b11 TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 0000004e31 Cmpl 0000004e31 Abort 00000000
    Total FCP Cmpl 00000000001017f2 Issue 00000000001017ef OutIO fffffffffffffffd
            abort 0000018a noxri 00000000 nondlp 0000012e qdepth 00000000 wqerr 00000004 err 00000000
    FCP CMPL: xb 0000018a Err 000005ca
NVMe/FC - Marvell/QLogic
Configure NVMe/FC for a Marvell/QLogic adapter.
Steps
  1. Verify that you are running the supported adapter driver and firmware versions:
    cat /sys/class/fc_host/host*/symbolic_name
    The follow example shows driver and firmware versions:
    QLE2742 FW:v9.14.00 DVR:v10.02.09.400-k-debug
  2. Verify that ql2xnvmeenable is set. This enables the Marvell adapter to function as an NVMe/FC initiator:
    cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
    The expected output is 1.
NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Steps
  1. Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
    nvme discover -t tcp -w <host-traddr> -a <traddr>
    Show example output
    nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.70
    Discovery Log Number of Records 8, Generation counter 42
    =====Discovery Log Entry 0======
    trtype:  tcp
    adrfam:  ipv4
    subtype: current discovery subsystem
    treq:    not specified
    portid:  4
    trsvcid: 8009
    subnqn:  nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:discovery
    traddr:  192.168.211.71
    eflags:  explicit discovery connections, duplicate discovery information
    sectype: none
    =====Discovery Log Entry 1======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  3
    trsvcid: 8009
    traddr:  192.168.111.71
    sectype: none
    =====Discovery Log Entry 2======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  2
    trsvcid: 8009
    traddr:  192.168.211.70
    sectype: none
    =====Discovery Log Entry 3======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  1
    trsvcid: 8009
    traddr:  192.168.111.70
    sectype: none
    =====Discovery Log Entry 4======
    trtype:  tcp
    adrfam:  ipv4
    subtype: nvme subsystem
    treq:    not specified
    portid:  4
    trsvcid: 4420
    subnqn:  nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.sample_tcp_sub
    eflags:  none
    sectype: none
    =====Discovery Log Entry 5======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  3
    trsvcid: 4420
    eflags:  none
    sectype: none
    =====Discovery Log Entry 6======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  2
    trsvcid: 4420
    eflags:  none
    sectype: none
    =====Discovery Log Entry 7======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  1
    trsvcid: 4420
    eflags:  none
    sectype: none
    localhost:~ #
  2. Verify that all other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
    Show example
    nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.66
    nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.67
    nvme discover -t tcp -w 192.168.211.80 -a 192.168.211.66
    nvme discover -t tcp -w 192.168.211.80 -a 192.168.211.67
  3. Run the nvme connect-all command across all the supported NVMe/TCP initiator-target LIFs across the nodes:
    nvme connect-all -t tcp -w <host-traddr> -a <traddr>
    Show example
    nvme	connect-all	-t	tcp	-w	192.168.111.80	-a	192.168.111.66
    nvme	connect-all	-t	tcp	-w	192.168.111.80	-a	192.168.111.67
    nvme	connect-all	-t	tcp	-w	192.168.211.80	-a	192.168.211.66
    nvme	connect-all	-t	tcp	-w	192.168.211.80	-a	192.168.211.67
Note
Beginning with SUSE Linux Enterprise Server 15 SP6, the setting for the NVMe/TCP ctrl_loss_tmo timeout is automatically set to "off". As a result:
  • There are no limits on the number of retries (indefinite retry).
  • You don't need to manually configure a specific ctrl_loss_tmo timeout duration when using the nvme connect or nvme connect-all commands (option -l ).
  • The NVMe/TCP controllers don't experience timeouts in the event of a path failure and remain connected indefinitely.
Step 4: Optionally, modify the iopolicy in the udev rules
Beginning with SUSE Linux Enterprise Server 15 SP6, the default iopolicy for NVMe-oF is set to round-robin. If you want to change the iopolicy to queue-depth, modify the udev rules file as follows:
Steps
  1. Open the udev rules file in a text editor with root privileges:
    /usr/lib/udev/rules.d/71-nvmf-netapp.rules
    vi /usr/lib/udev/rules.d/71-nvmf-netapp.rules
  2. Find the line that sets iopolicy for the NetApp ONTAP Controller, as shown in the following example rule:
    ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="round-robin"
  3. Modify the rule so that round-robin becomes queue-depth:
    ACTION=="add", SUBSYSTEM=="nvme-subsystem", ATTR{subsystype}=="nvm", ATTR{model}=="NetApp ONTAP Controller", ATTR{iopolicy}="queue-depth"
  4. Reload the udev rules and apply the changes:
    udevadm control --reload
    udevadm trigger --subsystem-match=nvme-subsystem
  5. Verify the current iopolicy for your subsystem:
    cat /sys/class/nvme-subsystem/<subsystem>/iopolicy
    queue-depth.
Note The new iopolicy applies automatically to matching NetApp ONTAP Controller devices. You don't need to reboot.
Step 5: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
Note These steps don't apply to Qlogic NVMe/FC hosts.
Steps
  1. Set the lpfc_sg_seg_cnt parameter to 256:
    cat /etc/modprobe.d/lpfc.conf
    You should see an output similar to the following example:
    options lpfc lpfc_sg_seg_cnt=256
  2. Run the dracut -f command, and reboot the host.
  3. Verify that the value for lpfc_sg_seg_cnt is 256:
    cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 6: Verify NVMe boot services
The nvmefc-boot-connections.service and nvmf-autoconnect.service boot services included in the NVMe/FC nvme-cli package are automatically enabled when the system boots.
After booting completes, verify that the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services are enabled.
Steps
  1. Verify that nvmf-autoconnect.service is enabled:
    systemctl status nvmf-autoconnect.service
    Show example output
    nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot
      Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: enabled)
      Active: inactive (dead) since Fri 2025-07-04 23:56:38 IST; 4 days ago
      Main PID: 12208 (code=exited, status=0/SUCCESS)
        CPU: 62ms
    Jul 04 23:56:26 localhost systemd[1]: Starting Connect NVMe-oF subsystems automatically during boot...
    Jul 04 23:56:38 localhost systemd[1]: nvmf-autoconnect.service: Deactivated successfully.
    Jul 04 23:56:38 localhost systemd[1]: Finished Connect NVMe-oF subsystems automatically during boot.
  2. Verify that nvmefc-boot-connections.service is enabled:
    systemctl status nvmefc-boot-connections.service
    Show example output
    nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot
        Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot-connections.service; enabled; preset: enabled)
        Active: inactive (dead) since Mon 2025-07-07 19:52:30 IST; 1 day 4h ago
      Main PID: 2945 (code=exited, status=0/SUCCESS)
          CPU: 14ms
    Jul 07 19:52:30 HP-DL360-14-168 systemd[1]: Starting Auto-connect to subsystems on FC-NVME devices found during boot...
    Jul 07 19:52:30 HP-DL360-14-168 systemd[1]: nvmefc-boot-connections.service: Deactivated successfully.
    Jul 07 19:52:30 HP-DL360-14-168 systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Step 7: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Steps
  1. Verify that the in-kernel NVMe multipath is enabled:
    cat /sys/module/nvme_core/parameters/multipath
    Y
  2. Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to queue-depth) for the respective ONTAP namespaces correctly reflect on the host:
    1. Display the subsystems:
      cat /sys/class/nvme-subsystem/nvme-subsys*/model
    2. Display the policy:
      cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
      queue-depth
      queue-depth
  3. Verify that the namespaces are created and correctly discovered on the host:
    nvme list
    Show example
    Node         SN                   Model
    /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB	NetApp ONTAP Controller
    Namespace Usage    Format             FW             Rev
    1                 21.47 GB / 21.47 GB	4 KiB + 0 B   FFFFFFFF
  4. Verify that the controller state of each path is live and has the correct ANA status:
    NVMe/FC
    nvme list-subsys /dev/nvme4n5
    Show example output
    nvme-subsys114 - NQN=nqn.1992-08.com.netapp:sn.9e30b9760a4911f08c87d039eab67a95:subsystem.sles_161_27
                     hostnqn=nqn.2014-08.org.nvmexpress:uuid:f651xxxx-3133-xxxx-bbff-7edxxxxf123f
    iopolicy=round-robin\
    +- nvme114 fc traddr=nn-0x234ed039ea359e4a:pn-0x2360d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live optimized
    +- nvme115 fc traddr=nn-0x234ed039ea359e4a:pn-0x2362d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live non-optimized
    +- nvme116 fc traddr=nn-0x234ed039ea359e4a:pn-0x2361d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live optimized
    +- nvme117 fc traddr=nn-0x234ed039ea359e4a:pn-0x2363d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live non-optimized
    NVMe/TCP
    nvme list-subsys /dev/nvme9n1
    Show example output
    nvme-subsys9 - NQN=nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.with_inband_with_json hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b2cxxxx44d33
    +- nvme10 tcp traddr=192.168.111.71,trsvcid=4420,src_addr=192.168.111.80 live non-optimized
     +- nvme11 tcp traddr=192.168.211.70,trsvcid=4420,src_addr=192.168.211.80 live optimized
     +- nvme12 tcp traddr=192.168.111.70,trsvcid=4420,src_addr=192.168.111.80 live optimized
     +- nvme9 tcp traddr=192.168.211.71,trsvcid=4420,src_addr=192.168.211.80 live non-optimized
  5. Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
    Column
    nvme netapp ontapdevices -o column
    Show example
    Device           Vserver                   Namespace Path                                     NSID UUID                                   Size
    /dev/nvme0n1     vs_161                    /vol/fc_nvme_vol1/fc_nvme_ns1                      1    32fd92c7-0797-428e-a577-fdb3f14d0dc3   5.37GB
    JSON
    nvme netapp ontapdevices -o json
    Show example
          "Device":"/dev/nvme98n2",
          "Vserver":"vs_161",
          "Namespace_Path":"/vol/fc_nvme_vol71/fc_nvme_ns71",
          "NSID":2,
          "UUID":"39d634c4-a75e-4fbd-ab00-3f9355a26e43",
          "LBA_Size":4096,
          "Namespace_Size":5368709120,
          "UsedBytes":430649344,
Step 8: Create a persistent discovery controller
You can create a persistent discovery controller (PDC) for a SUSE Linux Enterprise Server 15 SPx host. A PDC is required to automatically detect an NVMe subsystem add or remove operation and changes to the discovery log page data.
Steps
  1. Verify that the discovery log page data is available and can be retrieved through the initiator port and target LIF combination:
    nvme discover -t <trtype> -w <host-traddr> -a <traddr>
    Show example output
    Discovery Log Number of Records 8, Generation counter 18
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  4
    trsvcid: 8009
    subnqn:  nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery
    traddr:  192.168.111.66
    sectype: none
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  2
    trsvcid: 8009
    traddr:  192.168.211.66
    sectype: none
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  3
    trsvcid: 8009
    traddr:  192.168.111.67
    sectype: none
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  1
    trsvcid: 8009
    traddr:  192.168.211.67
    sectype: none
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  4
    trsvcid: 4420
    subnqn:  nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.pdc
    eflags:  none
    sectype: none
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  2
    trsvcid: 4420
    eflags:  none
    sectype: none
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  3
    trsvcid: 4420
    eflags:  none
    sectype: none
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  1
    trsvcid: 4420
    eflags:  none
    sectype: none
  2. Create a PDC for the discovery subsystem:
    nvme discover -t <trtype> -w <host-traddr> -a <traddr> -p
    nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.66 -p
  3. From the ONTAP controller, verify that the PDC has been created:
    vserver nvme show-discovery-controller -instance -vserver <vserver_name>
    Show example output
    vserver nvme show-discovery-controller -instance -vserver vs_pdc
               Vserver Name: vs_pdc
                   Controller ID: 0101h
         Discovery Subsystem NQN: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery
               Logical Interface: lif2
                            Node: A400-12-181
                        Host NQN: nqn.2014-08.org.nvmexpress:uuid:9796xxxx-0d34-xxxx-b6b2-3a6xxxxbab57
              Transport Protocol: nvme-tcp
     Initiator Transport Address: 192.168.111.80
    Transport Service Identifier: 8009
                 Host Identifier: 9796xxxx0d34xxxxb6b23a6xxxxbab57
               Admin Queue Depth: 32
           Header Digest Enabled: false
             Data Digest Enabled: false
       Keep-Alive Timeout (msec): 30000
Step 9: Set up secure in-band authentication
Secure in-band authentication is supported over NVMe/TCP between a SUSE Linux Enterprise Server 15 SPx host and an ONTAP controller.
Each host or controller must be associated with a DH-HMAC-CHAP key to set up secure authentication. A DH-HMAC-CHAP key is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
Steps
Set up secure in-band authentication using the CLI or a config JSON file. If you need to specify different dhchap keys for different subsystems, you must use a config JSON file.
CLI
Set up secure in-band authentication using the CLI.
  1. Obtain the host NQN:
  2. Generate the dhchap key for the host.
    The following output describes the gen-dhchap-key command paramters:
    nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn
    •	-s secret key in hexadecimal characters to be used to initialize the host key
    •	-l length of the resulting key in bytes
    •	-m HMAC function to use for key transformation
    0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512
    •	-n host NQN to use for key transformation
    In the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
    nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:e6daxxxx-216d-xxxx-b7bb-7edxxxx482c3
    DHHC-1:03:1CFivw9ccz58gAcOUJrM7Vs98hd2ZHSr+iw+Amg6xZPl5D2Yk+HDTZiUAg1iGgxTYqnxukqvYedA55Bw3wtz6sJNpR4=:
  3. On the ONTAP controller, add the host and specify both dhchap keys:
    vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit}
  4. A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
    nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret>
  5. Validate the nvme connect authentication command by verifying the host and controller dhchap keys:
    1. Verify the host dhchap keys:
      cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secret
      Show example output for a unidirectional configuration
      cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret
      DHHC-1:01:iM63E6cX7G5SOKKOju8gmzM53qywsy+C/YwtzxhIt9ZRz+ky:
    2. Verify the controller dhchap keys:
      cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secret
      Show example output for a bidirectional configuration
      cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret
JSON
When multiple NVMe subsystems are available on the ONTAP controller configuration, you can use the /etc/nvme/config.json file with the nvme connect-all command.
Use the -o option to generate the JSON file. Refer to the NVMe connect-all man pages for more syntax options.
  1. Configure the JSON file:
    Show example output
    cat /etc/nvme/config.json
        "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b2cxxxx44d33",
        "hostid":"4c4cxxxx-0035-xxxx-804b-b2cxxxx44d33",
        "dhchap_key":"DHHC-1:01:i4i789R11sMuHLCY27RVI8XloC\/GzjRwyhxip5hmIELsHrBq:",
        "subsystems":[
            "nqn":"nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.sample_tcp_sub",
            "ports":[
                "transport":"tcp",
                "traddr":"192.168.111.70",
                "host_traddr":"192.168.111.80",
                "trsvcid":"4420"
                "dhchap_ctrl_key":"DHHC-1:03:jqgYcJSKp73+XqAf2X6twr9ngBpr2n0MGWbmZIZq4PieKZCoilKGef8lAvhYS0PNK7T+04YD5CRPjh+m3qjJU++yR8s=:"
                        "transport":"tcp",
                        "traddr":"192.168.111.71",
                        "trsvcid":"4420",
                        "transport":"tcp",
                        "traddr":"192.168.211.70",
                        "host_traddr":"192.168.211.80",
                        "trsvcid":"4420",
                        "transport":"tcp",
                        "traddr":"192.168.211.71",
                        "trsvcid":"4420",
    Note In the following example, dhchap_key corresponds to dhchap_secret and dhchap_ctrl_key corresponds to dhchap_ctrl_secret.
  2. Connect to the ONTAP controller using the config JSON file:
    nvme connect-all -J /etc/nvme/config.json
    Show example output
    traddr=192.168.211.70 is already connected
    traddr=192.168.111.71 is already connected
    traddr=192.168.211.71 is already connected
    traddr=192.168.111.70 is already connected
  3. Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem:
      cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secret
      The following example shows a dhchap key:
      DHHC-1:01:i4i789R11sMuHLCY27RVI8XloC/GzjRwyhxip5hmIELsHrBq:
      cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secret
Step 10: Configure Transport Layer Security
Transport Layer Security (TLS) provides secure end-to-end encryption for NVMe connections between NVMe-oF hosts and an ONTAP array. You can configure TLS 1.3 using the CLI and a configured pre-shared key (PSK).
Note Perform the following steps on the SUSE Linux Enterprise Server host, except where it specifies that you perform a step on the ONTAP controller.
Steps
  1. Check that you have the following ktls-utils, openssl, and libopenssl packages installed on the host:
    1. Verify the ktls-utils:
      rpm -qa | grep ktls
      You should see the following output displayed:
      ktls-utils-0.10+33.g311d943-150700.1.5.x86_64
    2. Verify the SSL packages:
      rpm -qa | grep ssl
      Show example output
      libopenssl3-3.2.3-150700.3.20.x86_64
      openssl-3-3.2.3-150700.3.20.x86_64
      libopenssl1_1-1.1.1w-150700.9.37.x86_64
  2. Verify that you have the correct setup for /etc/tlshd.conf:
    cat /etc/tlshd.conf
    Show example output
    [debug]
    loglevel=0
    tls=0
    nl=0
    [authenticate]
    keyrings=.nvme
    [authenticate.client]
    #x509.truststore= <pathname>
    #x509.certificate= <pathname>
    #x509.private_key= <pathname>
    [authenticate.server]
  3. Enable tlshd to start at system boot:
    systemctl enable tlshd
  4. Verify that the tlshd daemon is running:
    systemctl status tlshd
    Show example output
    tlshd.service - Handshake service for kernel TLS consumers
       Loaded: loaded (/usr/lib/systemd/system/tlshd.service; enabled; preset: disabled)
       Active: active (running) since Wed 2024-08-21 15:46:53 IST; 4h 57min ago
         Docs: man:tlshd(8)
    Main PID: 961 (tlshd)
       Tasks: 1
         CPU: 46ms
       CGroup: /system.slice/tlshd.service
           └─961 /usr/sbin/tlshd
    Aug 21 15:46:54 RX2530-M4-17-153 tlshd[961]: Built from ktls-utils 0.11-dev on Mar 21 2024 12:00:00
  5. Generate the TLS PSK by using the nvme gen-tls-key:
    1. Verify the host:
    2. Verify the key:
      nvme gen-tls-key --hmac=1 --identity=1 --subsysnqn= nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1
      NVMeTLSkey-1:01:C50ExxxxuOp8xxxxE9EuWjbxxxxhmfoHx4XTqTJUmydf0gIj:
  6. On the ONTAP controller, add the TLS PSK to the ONTAP subsystem:
    Show example output
    nvme subsystem host add -vserver vs_iscsi_tcp -subsystem nvme1 -host-nqn nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b2cxxxx44d33 -tls-configured-psk NVMeTLSkey-1:01:C50ExxxxuOp8xxxxE9EuWjbxxxxhmfoHx4XTqTJUmydf0gIj:
  7. Insert the TLS PSK into the host kernel keyring:
    nvme check-tls-key --identity=1 --subsysnqn=nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 --keydata=NVMeTLSkey-1:01:C50ExxxxuOp8xxxxE9EuWjbxxxxhmfoHx4XTqTJUmydf0gIj: --insert
    You should see the following TLS key:
    Inserted TLS key 22152a7e
    Note The PSK shows as NVMe1R01 because it uses identity v1 from the TLS handshake algorithm. Identity v1 is the only version that ONTAP supports.
  8. Verify that the TLS PSK is inserted correctly:
    cat /proc/keys | grep NVMe
    Show example output
    069f56bb I--Q---     5 perm 3b010000     0     0 psk       NVMe1R01 nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b2cxxxx44d33 nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 oYVLelmiOwnvDjXKBmrnIgGVpFIBDJtc4hmQXE/36Sw=: 32
  9. Connect to the ONTAP subsystem using the inserted TLS PSK:
    1. Verify the TLS PSK:
      nvme connect -t tcp -w 192.168.111.80 -a 192.168.111.66  -n nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 --tls_key=0x069f56bb –tls
      connecting to device: nvme0
    2. Verify the list-subsys:
      nvme list-subsys
      Show example output
      nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1
       +- nvme0 tcp traddr=192.168.111.66,trsvcid=4420,host_traddr=192.168.111.80,src_addr=192.168.111.80 live
    3. Export the TLS PSK from the kernel keyring. This ensures that the key persists during a host reboot:
      # nvme tls --export --keyfile /etc/nvme/tls-keys
  10. Add the target, and verify the TLS connection to the specified ONTAP subsystem:
    nvme subsystem controller show -vserver sles15_tls -subsystem sles15 -instance
    Show example output
    (vserver nvme subsystem controller show)
                              Vserver Name: vs_iscsi_tcp
                              Subsystem: nvme1
                          Controller ID: 0040h
                      Logical Interface: tcpnvme_lif1_1
                                   Node: A400-12-181
                               Host NQN: nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b2cxxxx44d33
                        Host Identifier: 4c4cxxxx0035xxxx804bb2cxxxx44d33
                   Number of I/O Queues: 2
                       I/O Queue Depths: 128, 128
                  Max I/O Size in Bytes: 1048576
              Keep-Alive Timeout (msec): 5000
                         Subsystem UUID: 8bbfb403-1602-11f0-ac2b-d039eab67a95
           Authentication Hash Function: sha-256
    Authentication Diffie-Hellman Group: 3072-bit
                    Authentication Mode: unidirectional
           Transport Service Identifier: 4420
                           TLS Key Type: configured
                       TLS PSK Identity: NVMe1R01 nqn.2014-08.org.nvmexpress:uuid:4c4cxxxx-0035-xxxx-804b-b2c0xxxx4d33 nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 oYVLelmiOwnvDjXKBmrnIgGVpFIBDJtc4hmQXE/36Sw=
                             TLS Cipher: TLS-AES-128-GCM-SHA256
Step 11: Review the known issues
There are no known issues.
