NVMe/FC Host Configuration for SUSE Linux Enterprise Server 15 SP1 with ONTAP
You can configure NVMe over Fibre Channel (NVMe/FC) on hosts running SUSE Linux Enterprise Server 15 SP1 and ONTAP as the target.
Beginning with ONTAP 9.6, NVMe/FC is supported for the following versions of SUSE Linux Enterprise Server:
The SUSE Linux Enterprise Server 15 SP1 host can run both NVMe/FC and FCP traffic through the same fibre channel initiator adapter ports. See the Hardware Universe for a list of supported FC adapters and controllers.
For the current list of supported configurations and versions, see the Interoperability Matrix Tool.
Native NVMe/FC auto-connect scripts are included in the nvme-cli package. You can use the native inbox lpfc driver on SUSE Linux Enterprise Server 15 SP1.
Known limitations
SAN booting using the NVMe-oF protocol is currently not supported.
Enable NVMe/FC on SUSE Linux Enterprise Server 15 SP1
Upgrade to the recommended SUSE Linux Enterprise Server 15 SP2 MU kernel
Upgrade to the recommended nvme-cli MU version.
This nvme-cli package contains the native NVMe/FC auto-connect scripts, so you do not need to install the external NVMe/FC auto-connect scripts provided by Broadcom on the SUSE Linux Enterprise Server 15 SP1 host. This package also includes the ONTAP udev rule which enables round-robin load balancing for NVMe multipath, and the NetApp plug-in for ONTAP devices.
# rpm -qa | grep nvme-cli nvme-cli-1.8.1-6.9.1.x86_64
On the SUSE Linux Enterprise Server 15 SP1 host, check the host NQN string at
/etc/nvme/hostnqnand verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array. For example:# cat /etc/nvme/hostnqn nqn.2014-08.org.nvmexpress:uuid:75953f3b-77fe-4e03-bf3c-09d5a156fbcd
*> vserver nvme subsystem host show -vserver vs_nvme_10 Vserver Subsystem Host NQN ------- --------- -------------------------------------- ----------- sles_117_nvme_ss_10_0 nqn.2014-08.org.nvmexpress:uuid:75953f3b-77fe-4e03-bf3c-09d5a156fbcd
Reboot the host.
Configure the Broadcom FC Adapter for NVMe/FC
Verify that you are using the supported adapter. For the current list of supported adapters see the Interoperability Matrix Tool.
# cat /sys/class/scsi_host/host*/modelname LPe32002-M2 LPe32002-M2
# cat /sys/class/scsi_host/host*/modeldesc Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom lpfc firmware and native inbox driver versions.
# cat /sys/class/scsi_host/host*/fwrev 12.4.243.17, sil-4.2.c 12.4.243.17, sil-4.2.c
# cat /sys/module/lpfc/version 0:12.6.0.0
Verify that lpfc_enable_fc4_type is set to 3.
# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running.
# cat /sys/class/fc_host/host*/port_name 0x10000090fae0ec61 0x10000090fae0ec62
# cat /sys/class/fc_host/host*/port_state Online Online
Verify that the NVMe/FC initiator ports are enabled, running and able to see the target LIFs.
# cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 NVME 2947 SCSI 2977 ELS 250 NVME LPORT lpfc0 WWPN x10000090fae0ec61 WWNN x20000090fae0ec61 DID x012000 ONLINE NVME RPORT WWPN x202d00a098c80f09 WWNN x202c00a098c80f09 DID x010201 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203100a098c80f09 WWNN x202c00a098c80f09 DID x010601 TARGET DISCSRVC ONLINE NVME Statistics …
Validate NVMe/FC
Verify the following NVMe/FC settings.
# cat /sys/module/nvme_core/parameters/multipath Y
# cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller
# cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the namespaces are created.
# nvme list Node SN Model Namespace Usage Format FW Rev ---------------- -------------------- ----------------------- /dev/nvme0n1 80BADBKnB/JvAAAAAAAC NetApp ONTAP Controller 1 53.69 GB / 53.69 GB 4 KiB + 0 B FFFFFFFF
Verify the status of the ANA paths.
# nvme list-subsys/dev/nvme0n1 Nvme-subsysf0 – NQN=nqn.1992-08.com.netapp:sn.341541339b9511e8a9b500a098c80f09:subsystem.sles_117_nvme_ss_10_0 \ +- nvme0 fc traddr=nn-0x202c00a098c80f09:pn-0x202d00a098c80f09 host_traddr=nn-0x20000090fae0ec61:pn-0x10000090fae0ec61 live optimized +- nvme1 fc traddr=nn-0x207300a098dfdd91:pn-0x207600a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x207300a098dfdd91:pn-0x207500a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x207300a098dfdd91:pn-0x207700a098dfdd91 host traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live inaccessible
Verify the NetApp plug-in for ONTAP devices.
# nvme netapp ontapdevices -o column Device Vserver Namespace Path NSID UUID Size ------- -------- ------------------------- ------ ----- ----- /dev/nvme0n1 vs_nvme_10 /vol/sles_117_vol_10_0/sles_117_ns_10_0 1 55baf453-f629-4a18-9364-b6aee3f50dad 53.69GB # nvme netapp ontapdevices -o json { "ONTAPdevices" : [ { Device" : "/dev/nvme0n1", "Vserver" : "vs_nvme_10", "Namespace_Path" : "/vol/sles_117_vol_10_0/sles_117_ns_10_0", "NSID" : 1, "UUID" : "55baf453-f629-4a18-9364-b6aee3f50dad", "Size" : "53.69GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 13107200 } ]
Known issues
There are no known issues.
Enable 1MB I/O Size for Broadcom NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
LPFC Verbose Logging
Set the lpfc driver for NVMe/FC.
Set the
lpfc_log_verbosedriver setting to any of the following values to log NVMe/FC events.#define LOG_NVME 0x00100000 /* NVME general events. */ #define LOG_NVME_DISC 0x00200000 /* NVME Discovery/Connect events. */ #define LOG_NVME_ABTS 0x00400000 /* NVME ABTS events. */ #define LOG_NVME_IOERR 0x00800000 /* NVME IO Error events. */
After setting the values, run the
dracut-fcommand and reboot the host. -
Verify the settings.
# cat /etc/modprobe.d/lpfc.conf options lpfc lpfc_log_verbose=0xf00083 # cat /sys/module/lpfc/parameters/lpfc_log_verbose 15728771
