NVMe-oF host configuration for SUSE Linux Enterprise Server 15 SP5 with ONTAP
NVMe over Fabrics (NVMe-oF), including NVMe over Fibre Channel (NVMe/FC) and other transports, is supported for SUSE Linux Enterprise Server 15 SP5 with Asymmetric Namespace Access (ANA). In NVMe-oF environments, ANA is the equivalent of ALUA multipathing in iSCSI and FCP environments and is implemented with in-kernel NVMe multipath.
The following support is available for the NVMe-oF host configuration for SUSE Linux Enterprise Server 15 SP5 with ONTAP:
Both NVMe and SCSI traffic can be run on the same host. Therefore, for SCSI LUNs, you can configure dm-multipath for SCSI mpath devices, whereas you might use NVMe multipath to configure NVMe-oF namespace devices on the host.
Support for NVMe over TCP (NVMe/TCP) in addition to NVMe/FC. The NetApp plug-in in the native
nvme-clipackage displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Features
Support for NVMe secure, in-band authentication
Support for persistent discovery controllers (PDCs) using a unique discovery NQN
Known limitations
SAN booting using the NVMe-oF protocol is currently not supported.
There's no
sanlunsupport for NVMe-oF. Therefore, the host utility support isn't available for NVMe-oF on an SUSE Linux Enterprise Server 15 SP5 host. You can use the NetApp plug-in included in the native nvme-cli package for all NVMe-oF transports.
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex FC or Marvell/Qlogic FC adapters.
Verify that you are using the recommended adapter model:
cat /sys/class/scsi_host/host*/modelname
Example output:
LPe32002 M2 LPe32002-M2
Verify the adapter model description:
cat /sys/class/scsi_host/host*/modeldesc
Example output:
Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Emulex host bus adapter (HBA) firmware versions:
cat /sys/class/scsi_host/host*/fwrev
Example output:
14.0.639.20, sli-4:2:c 14.0.639.20, sli-4:2:c
Verify that you are using the recommended LPFC driver version:
cat /sys/module/lpfc/version
Example output:
0:14.2.0.13
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_name
Example output:
0x100000109b579d5e 0x100000109b579d5f
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_state
Example output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_info
Example output:
In the following example, one initiator port is enabled and connected with two target LIFs.
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b579d5e WWNN x200000109b579d5e DID x011c00 ONLINE NVME RPORT WWPN x208400a098dfdd91 WWNN x208100a098dfdd91 DID x011503 TARGET DISCSRVC ONLINE NVME RPORT WWPN x208500a098dfdd91 WWNN x208100a098dfdd91 DID x010003 TARGET DISCSRVC *ONLINE NVME Statistics LS: Xmt 0000000e49 Cmpl 0000000e49 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000003ceb594f Issue 000000003ce65dbe OutIO fffffffffffb046f abort 00000bd2 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000014f4 Err 00012abd NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b579d5f WWNN x200000109b579d5f DID x011b00 ONLINE NVME RPORT WWPN x208300a098dfdd91 WWNN x208100a098dfdd91 DID x010c03 TARGET DISCSRVC ONLINE NVME RPORT WWPN x208200a098dfdd91 WWNN x208100a098dfdd91 DID x012a03 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000e50 Cmpl 0000000e50 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000003c9859ca Issue 000000003c93515e OutIO fffffffffffaf794 abort 00000b73 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 0000159d Err 000135c3
Reboot the host.
The native inbox qla2xxx driver included in the SUSE Linux Enterprise Server 15 SP5 kernel has the latest fixes. These fixes are essential for ONTAP support.
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_name
Example output:
QLE2742 FW:v9.12.01 DVR: v10.02.08.300-k QLE2742 FW:v9.12.01 DVR: v10.02.08.300-k
Verify that the
ql2xnvmeenableparameter is set to 1:cat /sys/module/qla2xxx/parameters/ql2xnvmeenable 1
Enable 1MB I/O size (Optional)
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Enable NVMe services
There are two NVMe/FC boot services included in the nvme-cli package, however, only nvmefc-boot-connections.service is enabled to start during system boot; nvmf-autoconnect.service is not enabled. Therefore, you need to manually enable nvmf-autoconnect.service to start during system boot.
Enable
nvmf-autoconnect.service:# systemctl enable nvmf-autoconnect.service Created symlink /etc/systemd/system/default.target.wants/nvmf- autoconnect.service → /usr/lib/systemd/system/nvmf-autoconnect.service.
Reboot the host.
Verify that
nvmf-autoconnect.serviceandnvmefc-boot-connections.serviceare running after the system boot:Example output:
# systemctl status nvmf-autoconnect.service nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; vendor preset: disabled) Active: inactive (dead) since Thu 2023-05-25 14:55:00 IST; 11min ago Process: 2108 ExecStartPre=/sbin/modprobe nvme-fabrics (code=exited, status=0/SUCCESS) Process: 2114 ExecStart=/usr/sbin/nvme connect-all (code=exited, status=0/SUCCESS) Main PID: 2114 (code=exited, status=0/SUCCESS) systemd[1]: Starting Connect NVMe-oF subsystems automatically during boot... nvme[2114]: traddr=nn-0x201700a098fd4ca6:pn-0x201800a098fd4ca6 is already connected systemd[1]: nvmf-autoconnect.service: Deactivated successfully. systemd[1]: Finished Connect NVMe-oF subsystems automatically during boot. # systemctl status nvmefc-boot-connections.service nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot- connections.service; enabled; vendor preset: enabled) Active: inactive (dead) since Thu 2023-05-25 14:55:00 IST; 11min ago Main PID: 1647 (code=exited, status=0/SUCCESS) systemd[1]: Starting Auto-connect to subsystems on FC-NVME devices found during boot... systemd[1]: nvmefc-boot-connections.service: Succeeded. systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Configure NVMe/TCP
You can use the following procedure to configure NVMe/TCP.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w <host-traddr> -a <traddr>
Example output:
# nvme discover -t tcp -w 192.168.1.4 -a 192.168.1.31 Discovery Log Number of Records 8, Generation counter 18 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:discovery traddr: 192.168.2.117 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:discovery traddr: 192.168.1.117 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:discovery traddr: 192.168.2.116 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:discovery traddr: 192.168.1.116 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:subsystem.subsys_CLIEN T116 traddr: 192.168.2.117 eflags: not specified sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:subsystem.subsys_CLIEN T116 traddr: 192.168.1.117 eflags: not specified sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 2 trsvcid: 4420 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:subsystem.subsys_CLIEN T116 traddr: 192.168.2.116 eflags: not specified sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:subsystem.subsys_CLIEN T116 traddr: 192.168.1.116 eflags: not specified sectype: none
Verify that all other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
Example output:
# nvme discover -t tcp -w 192.168.1.4 -a 192.168.1.32 # nvme discover -t tcp -w 192.168.2.5 -a 192.168.2.36 # nvme discover -t tcp -w 192.168.2.5 -a 192.168.2.37
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddr -l <ctrl_loss_timeout_in_seconds>
Example output:
# nvme connect-all -t tcp -w 192.168.1.4 -a 192.168.1.31 -l -1 # nvme connect-all -t tcp -w 192.168.1.4 -a 192.168.1.32 -l -1 # nvme connect-all -t tcp -w 192.168.2.5 -a 192.168.1.36 -l -1 # nvme connect-all -t tcp -w 192.168.2.5 -a 192.168.1.37 -l -1
NetApp recommends setting the ctrl-loss-tmooption to-1so that the NVMe/TCP initiator attempts to reconnect indefinitely in the event of a path loss.
Validate NVMe-oF
You can use the following procedure to validate NVMe-oF.
Verify that in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipath Y
Verify that the host has the correct controller model for the ONTAP NVMe namespaces:
cat /sys/class/nvme-subsystem/nvme-subsys*/model
Example output:
NetApp ONTAP Controller NetApp ONTAP Controller
Verify the NVMe I/O policy for the respective ONTAP NVMe I/O controller:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
Example output:
round-robin round-robin
Verify that the ONTAP namespaces are visible to the host:
nvme list -v
Example output:
Subsystem Subsystem-NQN Controllers ---------------- ------------------------------------------------------------------------------------ ----------------------- nvme-subsys0 nqn.1992- 08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_dhcha p nvme0, nvme1, nvme2, nvme3 Device SN MN FR TxPort Asdress Subsystem Namespaces -------- -------------------- ---------------------------------------- -------- --------------------------------------------- nvme0 81LGgBUqsI3EAAAAAAAE NetApp ONTAP Controller FFFFFFFF tcp traddr=192.168.2.214,trsvcid=4420,host_traddr=192.168.2.14 nvme-subsys0 nvme0n1 nvme1 81LGgBUqsI3EAAAAAAAE NetApp ONTAP Controller FFFFFFFF tcp traddr=192.168.2.215,trsvcid=4420,host_traddr=192.168.2.14 nvme-subsys0 nvme0n1 nvme2 81LGgBUqsI3EAAAAAAAE NetApp ONTAP Controller FFFFFFFF tcp traddr=192.168.1.214,trsvcid=4420,host_traddr=192.168.1.14 nvme-subsys0 nvme0n1 nvme3 81LGgBUqsI3EAAAAAAAE NetApp ONTAP Controller FFFFFFFF tcp traddr=192.168.1.215,trsvcid=4420,host_traddr=192.168.1.14 nvme-subsys0 nvme0n1 Device Generic NSID Usage Format Controllers ------------ ------------ ---------- ------------------------------------------------------------- /dev/nvme0n1 /dev/ng0n1 0x1 1.07 GB / 1.07 GB 4 KiB + 0 B nvme0, nvme1, nvme2, nvme3
Verify that the controller state of each path is live and has the correct ANA status:
nvme list-subsys /dev/<subsystem_name>
NVMe/FCExample output
# nvme list-subsys /dev/nvme1n1 nvme-subsys1 - NQN=nqn.1992-08.com.netapp:sn.04ba0732530911ea8e8300a098dfdd91:subsystem.nvme_145_1 \ +- nvme2 fc traddr=nn-0x208100a098dfdd91:pn- 0x208200a098dfdd91,host_traddr=nn-0x200000109b579d5f:pn-0x100000109b579d5f live optimized +- nvme3 fc traddr=nn-0x208100a098dfdd91:pn- 0x208500a098dfdd91,host_traddr=nn-0x200000109b579d5e:pn-0x100000109b579d5e live optimized +- nvme4 fc traddr=nn-0x208100a098dfdd91:pn- 0x208400a098dfdd91,host_traddr=nn-0x200000109b579d5e:pn-0x100000109b579d5e live non-optimized +- nvme6 fc traddr=nn-0x208100a098dfdd91:pn- 0x208300a098dfdd91,host_traddr=nn-0x200000109b579d5f:pn-0x100000109b579d5f live non-optimized
NVMe/TCPExample output
# nvme list-subsys nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_dhchap hostnqn=nqn.2014-08.org.nvmexpress:uuid:e58eca24-faff-11ea-8fee-3a68dd3b5c5f iopolicy=round-robin +- nvme0 tcp traddr=192.168.2.214,trsvcid=4420,host_traddr=192.168.2.14 live +- nvme1 tcp traddr=192.168.2.215,trsvcid=4420,host_traddr=192.168.2.14 live +- nvme2 tcp traddr=192.168.1.214,trsvcid=4420,host_traddr=192.168.1.14 live +- nvme3 tcp traddr=192.168.1.215,trsvcid=4420,host_traddr=192.168.1.14 live
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnExample output:
Device Vserver Namespace Path NSID UUID Size ---------------- ------------------------- ----------------------------------------------------------------------------------------------- /dev/nvme0n1 vs_CLIENT114 /vol/CLIENT114_vol_0_10/CLIENT114_ns10 1 c6586535-da8a-40fa-8c20-759ea0d69d33 1.07GB
JSONnvme netapp ontapdevices -o jsonExample output:
{ "ONTAPdevices":[ { "Device":"/dev/nvme0n1", "Vserver":"vs_CLIENT114", "Namespace_Path":"/vol/CLIENT114_vol_0_10/CLIENT114_ns10", "NSID":1, "UUID":"c6586535-da8a-40fa-8c20-759ea0d69d33", "Size":"1.07GB", "LBA_Data_Size":4096, "Namespace_Size":262144 } ] }
Create a persistent discovery controller
Beginning with ONTAP 9.11.1, you can create a persistent discovery controller (PDC) for your SUSE Linux Enterprise Server 15 SP5 host. A PDC is required to automatically detect an NVMe subsystem add or remove scenario and changes to the discovery log page data.
Verify that the discovery log page data is available and can be retrieved through the initiator port and target LIF combination:
nvme discover -t <trtype> -w <host-traddr> -a <traddr>
Show example output:
Discovery Log Number of Records 16, Generation counter 14 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:discovery traddr: 192.168.1.214 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:discovery traddr: 192.168.1.215 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:discovery traddr: 192.168.2.215 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:discovery traddr: 192.168.2.214 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_none traddr: 192.168.1.214 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_none traddr: 192.168.1.215 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_none traddr: 192.168.2.215 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_none traddr: 192.168.2.214 eflags: none sectype: none =====Discovery Log Entry 8====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.subsys_CLIENT114 traddr: 192.168.1.214 eflags: none sectype: none =====Discovery Log Entry 9====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.subsys_CLIENT114 traddr: 192.168.1.215 eflags: none sectype: none =====Discovery Log Entry 10====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.subsys_CLIENT114 traddr: 192.168.2.215 eflags: none sectype: none =====Discovery Log Entry 11====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.subsys_CLIENT114 traddr: 192.168.2.214 eflags: none sectype: none =====Discovery Log Entry 12====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_dhchap traddr: 192.168.1.214 eflags: none sectype: none =====Discovery Log Entry 13====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_dhchap traddr: 192.168.1.215 eflags: none sectype: none =====Discovery Log Entry 14====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_dhchap traddr: 192.168.2.215 eflags: none sectype: none =====Discovery Log Entry 15====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.0501daf15dda11eeab68d039eaa7a232:subsystem.unidir_dhchap traddr: 192.168.2.214 eflags: none sectype: none
Create a PDC for the discovery subsystem:
nvme discover -t <trtype> -w <host-traddr> -a <traddr> -p
Example output:
nvme discover -t tcp -w 192.168.1.16 -a 192.168.1.116 -p
From the ONTAP controller, verify that the PDC has been created:
vserver nvme show-discovery-controller -instance -vserver vserver_name
Example output:
vserver nvme show-discovery-controller -instance -vserver vs_nvme175 Vserver Name: vs_CLIENT116 Controller ID: 00C0h Discovery Subsystem NQN: nqn.1992- 08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:discovery Logical Interface UUID: d23cbb0a-c0a6-11ec-9731-d039ea165abc Logical Interface: CLIENT116_lif_4a_1 Node: A400-14-124 Host NQN: nqn.2014-08.org.nvmexpress:uuid:12372496-59c4-4d1b-be09- 74362c0c1afc Transport Protocol: nvme-tcp Initiator Transport Address: 192.168.1.16 Host Identifier: 59de25be738348f08a79df4bce9573f3 Admin Queue Depth: 32 Header Digest Enabled: false Data Digest Enabled: false Vserver UUID: 48391d66-c0a6-11ec-aaa5-d039ea165514
Set up secure in-band authentication
Beginning with ONTAP 9.12.1, secure in-band authentication is supported over NVMe/TCP and NVMe/FC between your SUSE Linux Enterprise Server 15 SP5 host and your ONTAP controller.
To set up secure authentication, each host or controller must be associated with a DH-HMAC-CHAP key, which is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
You can set up secure in-band authentication using the CLI or a config JSON file. If you need to specify different dhchap keys for different subsystems, you must use a config JSON file.
Obtain the host NQN:
cat /etc/nvme/hostnqn
Generate the dhchap key for the SUSE Linux Enterprise Server 15 SP5 host:
nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn • -s secret key in hexadecimal characters to be used to initialize the host key • -l length of the resulting key in bytes • -m HMAC function to use for key transformation 0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512 • -n host NQN to use for key transformationIn the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
# nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:d3ca725a- ac8d-4d88-b46a-174ac235139b DHHC-1:03:J2UJQfj9f0pLnpF/ASDJRTyILKJRr5CougGpGdQSysPrLu6RW1fGl5VSjbeDF1n1DEh3nVBe19nQ/LxreSBeH/bx/pU=:
On the ONTAP controller, add the host and specify both dhchap keys:
vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit} -
A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret>
Validate the
nvme connect authenticationcommand by verifying the host and controller dhchap keys:-
Verify the host dhchap keys:
$cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secret
Example output for unidirectional configuration:
# cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret DHHC-1:03:je1nQCmjJLUKD62mpYbzlpuw0OIws86NB96uNO/t3jbvhp7fjyR9bIRjOHg8wQtye1JCFSMkBQH3pTKGdYR1OV9gx00=: DHHC-1:03:je1nQCmjJLUKD62mpYbzlpuw0OIws86NB96uNO/t3jbvhp7fjyR9bIRjOHg8wQtye1JCFSMkBQH3pTKGdYR1OV9gx00=: DHHC-1:03:je1nQCmjJLUKD62mpYbzlpuw0OIws86NB96uNO/t3jbvhp7fjyR9bIRjOHg8wQtye1JCFSMkBQH3pTKGdYR1OV9gx00=: DHHC-1:03:je1nQCmjJLUKD62mpYbzlpuw0OIws86NB96uNO/t3jbvhp7fjyR9bIRjOHg8wQtye1JCFSMkBQH3pTKGdYR1OV9gx00=:
Verify the controller dhchap keys:
$cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secret
Example output for bidirectional configuration:
# cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret DHHC-1:03:WorVEV83eYO53kV4Iel5OpphbX5LAphO3F8fgH3913tlrkSGDBJTt3crXeTUB8fCwGbPsEyz6CXxdQJi6kbn4IzmkFU=: DHHC-1:03:WorVEV83eYO53kV4Iel5OpphbX5LAphO3F8fgH3913tlrkSGDBJTt3crXeTUB8fCwGbPsEyz6CXxdQJi6kbn4IzmkFU=: DHHC-1:03:WorVEV83eYO53kV4Iel5OpphbX5LAphO3F8fgH3913tlrkSGDBJTt3crXeTUB8fCwGbPsEyz6CXxdQJi6kbn4IzmkFU=: DHHC-1:03:WorVEV83eYO53kV4Iel5OpphbX5LAphO3F8fgH3913tlrkSGDBJTt3crXeTUB8fCwGbPsEyz6CXxdQJi6kbn4IzmkFU=:
You can use the /etc/nvme/config.json file with the nvme connect-all command when multiple NVMe subsystems are available on the ONTAP controller configuration.
You can generate the JSON file using -o option. Refer to the NVMe connect-all man pages for more syntax options.
Configure the JSON file:
# cat /etc/nvme/config.json [ { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:12372496-59c4-4d1b-be09-74362c0c1afc", "hostid":"3ae10b42-21af-48ce-a40b-cfb5bad81839", "dhchap_key":"DHHC-1:03:Cu3ZZfIz1WMlqZFnCMqpAgn/T6EVOcIFHez215U+Pow8jTgBF2UbNk3DK4wfk2EptWpna1rpwG5CndpOgxpRxh9m41w=:" }, { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:12372496-59c4-4d1b-be09-74362c0c1afc", "subsystems":[ { "nqn":"nqn.1992-08.com.netapp:sn.48391d66c0a611ecaaa5d039ea165514:subsystem.subsys_CLIENT116", "ports":[ { "transport":"tcp", "traddr":"192.168.1.117", "host_traddr":"192.168.1.16", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:01:0h58bcT/uu0rCpGsDYU6ZHZvRuVqsYKuBRS0Nu0VPx5HEwaZ:" }, { "transport":"tcp", "traddr":"192.168.1.116", "host_traddr":"192.168.1.16", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:01:0h58bcT/uu0rCpGsDYU6ZHZvRuVqsYKuBRS0Nu0VPx5HEwaZ:" }, { "transport":"tcp", "traddr":"192.168.2.117", "host_traddr":"192.168.2.16", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:01:0h58bcT/uu0rCpGsDYU6ZHZvRuVqsYKuBRS0Nu0VPx5HEwaZ:" }, { "transport":"tcp", "traddr":"192.168.2.116", "host_traddr":"192.168.2.16", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:01:0h58bcT/uu0rCpGsDYU6ZHZvRuVqsYKuBRS0Nu0VPx5HEwaZ:" } ] } ] } ] [NOTE] In the preceding example, `dhchap_key` corresponds to `dhchap_secret` and `dhchap_ctrl_key` corresponds to `dhchap_ctrl_secret`. -
Connect to the ONTAP controller using the config JSON file:
nvme connect-all -J /etc/nvme/config.json
Example output:
traddr=192.168.2.116 is already connected traddr=192.168.1.116 is already connected traddr=192.168.2.117 is already connected traddr=192.168.1.117 is already connected traddr=192.168.2.117 is already connected traddr=192.168.1.117 is already connected traddr=192.168.2.116 is already connected traddr=192.168.1.116 is already connected traddr=192.168.2.116 is already connected traddr=192.168.1.116 is already connected traddr=192.168.2.117 is already connected traddr=192.168.1.117 is already connected
Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem:
# cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secret
Example output:
DHHC-1:01:NunEWY7AZlXqxITGheByarwZdQvU4ebZg9HOjIr6nOHEkxJg:
# cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secret
Example output:
DHHC- 1:03:2YJinsxa2v3+m8qqCiTnmgBZoH6mIT6G/6f0aGO8viVZB4VLNLH4z8CvK7pV YxN6S5fOAtaU3DNi12rieRMfdbg3704=:
Known issues
There are no known issues for the SUSE Linux Enterprise Server 15 SP5 with ONTAP release.
