Performance: Premium HA direct-attached SSD storage
Performance information for the reference platform.
Reference platform
ONTAP Select (Premium XL) hardware (per node)
FUJITSU PRIMERGY RX2540 M4:
Intel® Xeon® Gold 6142b CPU at 2.6 GHz
32 physical cores (16 x 2 sockets), 64 logical
256 GB RAM
Drives per host: 24 960GB SSD
ESX 6.5U1
Client hardware
5 x NFSv3 IBM 3550m4 clients
Configuration information
SW RAID 1 x 9 + 2 RAID-DP (11 drives)
22+1 RAID-5 (RAID-0 in ONTAP) / RAID cache NVRAM
No storage efficiency features in use (compression, deduplication, Snapshot copies, SnapMirror, and so on)
The following table lists the throughput measured against read/write workloads on a high availability (HA) pair of ONTAP Select nodes using both software RAID and hardware RAID. Performance measurements were taken using the SIO load-generating tool.
These performance numbers are based on ONTAP Select 9.6. |
Performance results for a single node (part of a four-node medium instance) ONTAP Select cluster on a direct-attached storage (DAS) SSD, with software RAID and hardware RAID
| Description | Sequential Read 64KiB | Sequential Write 64KiB | Random Read 8KiB | Random Write 8KiB | Random WR/ RD (50/50) 8KiB |
ONTAP Select large instance with DAS (SSD) software RAID |
2171 MiBps |
559 MiBps |
954 MiBps |
394 MiBps |
564 MiBps |
ONTAP Select medium instance with DAS (SSD) software RAID |
2090 MiBps |
592 MiBps |
677 MiBps |
335 MiBps |
441 3MiBps |
ONTAP Select medium instance with DAS (SSD) hardware RAID |
2038 MiBps |
520 MiBps |
578 MiBps |
325 MiBps |
399 MiBps |
64K sequential read
Details:
SIO direct I/O enabled
2 nodes
2 x data NIC per node
1 x data aggregate per node (2TB hardware RAID), (8TB software RAID)
64 SIO procs, 1 thread per proc
32 volumes per node
1 x files per proc; files are 12000MB each
64K sequential write
Details:
2 nodes
2 x data network interface cards (NICs) per node
1 x data aggregate per node (2TB hardware RAID), (4TB software RAID)
128 SIO procs, 1 thread per proc
Volumes per node: 32 (hardware RAID), 16 (software RAID)
1 x files per proc; files are 30720MB each
8K random read
Details:
2 nodes
2 x data NICs per node
64 SIO procs, 8 threads per proc
1 x files per proc; files are 12228MB each
8K random write
Details:
2 nodes
1 x files per proc; files are 8192MB each
8K random 50% write 50% read
Details:
2 nodes
64 SIO proc208 threads per proc
