Install ONTAP Select Deploy
You need to install the ONTAP Select Deploy administration utility and use the utility to create an ONTAP Select cluster.
Download the virtual machine image
You can download the ONTAP Select package from the NetApp support site.
The ONTAP Select Deploy administration utility is packaged as a virtual machine (VM) based on the Open Virtualization Format (OVF) standard. The single compressed file has the suffix ova. The VM provides the Deploy server and installation images for ONTAP Select nodes.
Access the NetApp Support Site using a web browser and sign in.
Select Downloads from the menu, then select Downloads from the drop-down menu.
On the Downloads page, under All Products A-Z, select the letter O.
Scroll down and select ONTAP Select.
Select the desired release of the package.
Review the End User License Agreement (EULA) and select Accept & Continue.
Select and download the appropriate package, responding to all prompts as needed.
Verify the ONTAP Select Deploy OVA signature
You should verify the ONTAP Select Open Virtualization Appliance (OVA) signature before installing the installation package.
Verify that your system meets the following requirements:
OpenSSL versions 1.0.2 to 3.0 for basic verification
Public internet access for Online Certificate Status Protocol (OCSP) verification
Obtain the following files from the product download page on the NetApp support site:
File Description ONTAP-Select-Deploy-Production.pubThe public key used to verify the signature.
csc-prod-chain-ONTAP-Select-Deploy.pemThe public certification authority (CA) chain of trust.
csc-prod-ONTAP-Select-Deploy.pemThe certificate used to generate the key.
ONTAPdeploy.ovaThe product installation executable for ONTAP Select.
ONTAPdeploy.ova.sigThe SHA-256 algorithm is hashed and then signed by the Remote Support Agent (RSA) using the
csc-prodkey and signature for the installer. -
Verify that the
ONTAPdeploy.ova.sigfile is using the associated certificates and validation commands. -
Verify the signature with the following command:
openssl dgst -sha256 -verify ONTAP-Select-Deploy-Production.pub -signature ONTAPdeploy.ova.sig ONTAPdeploy.ova
Deploy the virtual machine
You must install and start the ONTAP Select Deploy virtual machine using the OVF virtual machine image. As part of the installation process, you must configure the network interface to use DHCP or a static IP configuration.
You must prepare to deploy the ONTAP Select Deploy virtual machine:
Enable the OVF functionality in your browser by installing the VMware Client Integration Plugin or performing similar configuration as needed
Enabled DHCP in the VMware environment if you will dynamically assign an IP address to the Deploy virtual machine
You must have the configuration information to be used when creating the virtual machine, including the name of the virtual machine, external network, and host name. When defining a static network configuration, you need the following additional information:
IP address of the Deploy virtual machine
Netmask
IP address of the gateway (router)
IP address of the primary DNS server
IP address of the second DNS server
DNS search domains
If you use vSphere, the Deploy OVF template wizard includes a form to provide all of the Deploy configuration information, including the network configuration. However, if you choose not to use this form, you can use the console of the Deploy virtual machine to configure the network instead.
Access the vSphere client and sign in.
Navigate to the appropriate location in the hierarchy and select Deploy OVF Template.
Select the OVA file and complete the Deploy OVF Template wizard, selecting the options as appropriate for your environment.
You must define the password for the administrator account. You need to provide this password when signing in to the Deploy utility.
After the virtual machine is deployed, select the new virtual machine and power it on if it is not already powered on based on your input to the deployment wizard.
If needed, you can configure the Deploy network using the virtual machine console:
Click the Console tab to access the ESXi host setup shell and monitor the power on process.
Wait for the following prompt:
Host name :
Type the host name and press Enter.
Provide a password for the admin user:
Type the password and press Enter.
Use DHCP to set networking information? [n]:
Type n to define a static IP configuration or y to use DHCP, and press Enter.
If you choose a static configuration, provide all network configuration information as required.
Sign in to the Deploy web interface
You should sign in to the web user interface to confirm the Deploy utility is available and perform initial configuration.
Point your browser to the Deploy utility using the IP address or domain name:
https://<ip_address>/ -
Provide the administrator (admin) account name and password and sign in.
If the Welcome to ONTAP Select pop-up window is displayed, review the prerequisites and select OK to continue.
If this is the first time signing in and you did not install Deploy using the wizard available with vCenter, provide the following configuration information when prompted:
New password for the administrator account (required)
AutoSupport (optional)
vCenter server with account credentials (optional)
