Before you begin administering ONTAP Select
After creating an ONTAP Select cluster, you can support the deployment by performing various administrative tasks. There are a few general considerations to be aware of.
In general, the procedures you can perform using the Deploy web interface fall into one of three categories.
You can deploy a single-node or multi-node cluster. See Deploy an ONTAP Select cluster for more information.
The administrative procedures are organized in various categories, such as Security and Clusters.
There are several procedures specific to Deploy (such as changing the administrator's password).
Administer ONTAP Select
There are many different administrative procedures available as part of supporting ONTAP Select. In addition, there are procedures specific to the Deploy administrative utility. The most important of these procedures are presented below. In general, all use the Deploy web user interface.
You can also use the command line interface to administer ONTAP Select. |
Perform additional ONTAP configuration
After an ONTAP Select cluster is deployed, you can configure and manage the cluster just as you would a hardware-based ONTAP system. For example, you can use ONTAP System Manager or the ONTAP CLI to configure the ONTAP Select cluster.
You can connect to ONTAP Select using the following supported NetApp client software:
Active IQ Unified Manager
OnCommand Insight
OnCommand Workflow Automation
SnapCenter
Virtual Storage Console for VMware vSphere
To identify the supported versions of the client software, review the NetApp Interoperability Matrix Tool. If the client software supports ONTAP 9, then the same version is also supported with ONTAP Select.
The use of SnapCenter and the corresponding plug-ins requires server-based licenses. Storage system licensing of the SnapCenter plug-ins is not currently supported with ONTAP Select. |
Any other NetApp client software that is not included in the list is not supported by ONTAP Select.
There are several options available when configuring the cluster, including the following:
Creating the networking configuration
Laying out your aggregates
Creating the data storage VMs (SVMs)
If you decided not to install the license files with storage capacity as part of deploying the ONTAP Select cluster, you must acquire and install the license files before the grace period expires for clusters running with a purchased license.
There are data spare disks created by the Deploy administration utility on each ONTAP Select node from the usable datastore space (such as, Pool0 and Pool1). To implement high availability for your data on a multi-node cluster, you must create a mirrored aggregate using these spares.
