ONTAP Select
ONTAP Select installation and deployment workflow
You can use the following workflow to deploy and administer an ONTAP Select cluster.
Describes the complete workflow needed to deploy an ONTAP Select cluster.
Looking for answers?
Try Doc, our Gen AI Assistant.
