The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
JSON for script to create a cluster
Creating your file...
Your file is ready
When creating or deleting an ONTAP Select cluster using the Python code samples, you must provide a JSON file as input to the script. You can copy and modify the appropriate JSON sample based on your deployment plans.
Single-node cluster on ESXi
"hosts": [
"password": "mypassword1",
"name": "host-1234",
"type": "ESX",
"username": "admin"
"cluster": {
"dns_info": {
"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
"lab3.company-demo.com", "lab4.company-demo.com"
"dns_ips": ["10.206.80.135", "10.206.80.136"]
"ontap_image_version": "9.7",
"gateway": "10.206.80.1",
"ip": "10.206.80.115",
"name": "mycluster",
"ntp_servers": ["10.206.80.183", "10.206.80.142"],
"ontap_admin_password": "mypassword2",
"netmask": "255.255.254.0"
"nodes": [
"serial_number": "3200000nn",
"ip": "10.206.80.114",
"name": "node-1",
"networks": [
"name": "ontap-external",
"purpose": "mgmt",
"vlan": 1234
"purpose": "data",
"vlan": null
"name": "ontap-internal",
"purpose": "internal",
"vlan": null
"host_name": "host-1234",
"is_storage_efficiency_enabled": false,
"instance_type": "small",
"storage": {
"disk": [],
"pools": [
"name": "storage-pool-1",
"capacity": 4802666790125
JSON
Single-node cluster on ESXi using vCenter
"hosts": [
"name":"host-1234",
"type":"ESX",
"mgmt_server":"vcenter-1234"
"cluster": {
"dns_info": {"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
"dns_ips": ["10.206.80.135","10.206.80.136"]
"ontap_image_version":"9.7",
"gateway":"10.206.80.1",
"ip":"10.206.80.115",
"name":"mycluster",
"ntp_servers": ["10.206.80.183","10.206.80.142"],
"ontap_admin_password":"mypassword2",
"netmask":"255.255.254.0"
"vcenter": {
"password":"mypassword2",
"hostname":"vcenter-1234",
"username":"selectadmin"
"nodes": [
"ip":"10.206.80.114",
"name":"node-1",
"networks": [
"name":"ONTAP-Management",
"purpose":"mgmt",
"vlan":null
"name": "ONTAP-External",
"purpose":"data",
"vlan":null
"name": "ONTAP-Internal",
"purpose":"internal",
"vlan":null
"storage": {
"disk":[],
"pools": [
"capacity":5685190380748
JSON
Single-node cluster on KVM
"hosts": [
"name":"host-1234",
"type":"KVM",
"username":"root"
"cluster": {
"dns_info": {
"name":"CBF4ED97",
"nodes": [
"serial_number":"3200000nn",
"name": "node-1",
"networks": [
"purpose": "mgmt",
"vlan":1234
"purpose": "data",
"vlan": null
"vlan": null
"storage": {
"disk": [],
"pools": [
JSON
