ONTAP Select
Workflow 1: Create a single-node evaluation cluster on ESXi
You can deploy a single-node ONTAP Select cluster on a VMware ESXi host managed by vCenter. The cluster is created with an evaluation license.
The cluster creation workflow differs in the following situations:
  • The ESXi host is not managed by vCenter (standalone host)
  • Multiple nodes or hosts are used within the cluster
  • Cluster is deployed in a production environment with a purchased license
  • The KVM hypervisor is used instead of VMware ESXi
    Note
    • Beginning with ONTAP Select 9.10.1, you can no longer deploy a new cluster on the KVM hypervisor.
    • Beginning with ONTAP Select 9.11.1, all manageability functionality is no longer available for existing KVM clusters and hosts, except for the take offline and delete functions.
1. Register vCenter server credential
When deploying to an ESXi host managed by a vCenter server, you must add a credential before registering the host. The Deploy administration utility can then use the credential to authenticate to vCenter.
Category HTTP verb Path
Deploy
POST
/security/credentials
Curl
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step01 'https://10.21.191.150/api/security/credentials'
JSON input (step01)
  "hostname": "vcenter.company-demo.com",
  "type": "vcenter",
  "username": "misteradmin@vsphere.local",
  "password": "mypassword"
Processing type
Asynchronous
Output
  • Credential ID in the location response header
  • Job object
2. Register a hypervisor host
You must add a hypervisor host where the virtual machine containing the ONTAP Select node will run.
Cluster
POST
/hosts
Curl
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step02 'https://10.21.191.150/api/hosts'
JSON input (step02)
  "hosts": [
      "hypervisor_type": "ESX",
      "management_server": "vcenter.company-demo.com",
      "name": "esx1.company-demo.com"
Processing type
Asynchronous
Output
  • Host ID in the location response header
  • Job object
3. Create a cluster
When you create an ONTAP Select cluster, the basic cluster configuration is registered and the node names are automatically generated by Deploy.
Cluster
POST
/clusters
Curl
The query parameter node_count should be set to 1 for a single-node cluster.
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step03 'https://10.21.191.150/api/clusters? node_count=1'
JSON input (step03)
  "name": "my_cluster"
Processing type
Synchronous
Output
  • Cluster ID in the location response header
4. Configure the cluster
There are several attributes you must provide as part of configuring the cluster.
Cluster
PATCH
/clusters/{cluster_id}
Curl
You must provide the cluster ID.
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step04 'https://10.21.191.150/api/clusters/CLUSTERID'
JSON input (step04)
  "dns_info": {
    "domains": ["lab1.company-demo.com"],
    "dns_ips": ["10.206.80.135", "10.206.80.136"]
    "ontap_image_version": "9.5",
    "gateway": "10.206.80.1",
    "ip": "10.206.80.115",
    "netmask": "255.255.255.192",
    "ntp_servers": {"10.206.80.183"}
Processing type
Synchronous
Output
None
5. Retrieve the node name
The Deploy administration utility automatically generates the node identifiers and names when a cluster is created. Before you can configure a node, you must retrieve the assigned ID.
Cluster
GET
/clusters/{cluster_id}/nodes
Curl
curl -iX GET -u admin:<password> -k 'https://10.21.191.150/api/clusters/CLUSTERID/nodes?fields=id,name'
Processing type
Synchronous
Output
  • Array records each describing a single node with the unique ID and name
6. Configure the nodes
You must provide the basic configuration for the node, which is the first of three API calls used to configure a node.
Cluster
PATH
/clusters/{cluster_id}/nodes/{node_id}
Curl
You must provide the cluster ID and node ID.
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step06 'https://10.21.191.150/api/clusters/CLUSTERID/nodes/NODEID'
JSON input (step06)
You must provide the host ID where the ONTAP Select node will run.
  "host": {
    "id": "HOSTID"
  "instance_type": "small",
  "ip": "10.206.80.101",
  "passthrough_disks": false
Processing type
Synchronous
Output
None
7. Retrieve the node networks
You must identify the data and management networks used by the node in the single-node cluster. The internal network is not used with a single-node cluster.
Cluster
GET
/clusters/{cluster_id}/nodes/{node_id}/networks
Curl
curl -iX GET -u admin:<password> -k 'https://10.21.191.150/api/ clusters/CLUSTERID/nodes/NODEID/networks?fields=id,purpose'
Processing type
Synchronous
Output
  • Array of two records each describing a single network for the node, including the unique ID and purpose
8. Configure the node networking
You must configure the data and management networks. The internal network is not used with a single-node cluster.
Note Issue the following API call two times, once for each network.
Cluster
PATCH
/clusters/{cluster_id}/nodes/{node_id}/networks/{network_id}
Curl
You must provide the cluster ID, node ID, and network ID.
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step08 'https://10.21.191.150/api/clusters/ CLUSTERID/nodes/NODEID/networks/NETWORKID'
JSON input (step08)
You need to provide the name of the network.
  "name": "sDOT_Network"
Processing type
Synchronous
Output
None
9. Configure the node storage pool
The final step in configuring a node is to attach a storage pool. You can determine the available storage pools through the vSphere web client, or optionally through the Deploy REST API.
Cluster
PATCH
Curl
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step09 'https://10.21.191.150/api/clusters/ CLUSTERID/nodes/NODEID'
JSON input (step09)
The pool capacity is 2 TB.
  "pool_array": [
      "name": "sDOT-01",
      "capacity": 2147483648000
Processing type
Synchronous
Output
None
10. Deploy the cluster
After the cluster and node have been configured, you can deploy the cluster.
Cluster
POST
/clusters/{cluster_id}/deploy
Curl
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step10 'https://10.21.191.150/api/clusters/CLUSTERID/deploy'
JSON input (step10)
You must provide the password for the ONTAP administrator account.
  "ontap_credentials": {
Processing type
Asynchronous
Output
  • Job object
