Manually removing the Deploy plug-in from vCenter
You can manually remove the Deploy plug-in from the vCenter server.
Before you begin
You should always begin by removing the plug-in using the VMware Managed Object Browser (MOB) and then by removing it from the vSphere directories inside the vCenter server.
There are several instances in which you must manually remove the plug-in:
The plug-in was removed using the Deploy utility native user interface, but the vCenter server could not be rebooted.
The Deploy utility was decommissioned without removing the plug-in.
Use the VMware MOB to remove the plug-in
The MOB is a VMware application that allows you to view and manage the objects on a VMware vCenter server. You can use the MOB to remove the Deploy vCenter plug-in.
Access the MOB at the vCenter server using a browser and sign in:
https://<FQDN_or_IP-address>/mob
Click content and then click ExtensionManager.
Confirm that the extension to be removed is present based on the full name:
com.netapp.selectdeploy
Click UnregisterExtension.
Type the name of the extension and click InvokeMethod.
The plug-in is removed from the list of extensions.
Remove the plug-in from the vSphere UI folder
You should examine vSphere UI directory at the vCenter server and remove the Deploy plugin if found.
You must have the password for the root account at the vCenter server. You should remove the plug-in using the vSphere MOB.
Use SSH to access the vCenter server and sign in:
ssh root@<FQDN_or_IP-address>
Type shell and press Enter to launch the Bash shell.
Navigate to the
vsphere-client-serenity
directory for the vSphere-UI service:cd /etc/vmware/vsphere-ui/vc-packages/vsphere-client-serenity
Determine if there are directories of the form
that must be removed:ls -al
Stop the HTML5 vSphere-UI web client:
service-control --stop vsphere-ui
Remove the directory containing the UI extensions:
rm -rf com.netapp.selectdeploy-1.0.0
Restart the HTML5 vSphere-UI web client:
service-control --start vsphere-ui
It can take several minutes for the Deploy plug-in to restart and become available.
Remove the plug-in from the vSphere client folder
You should examine the vSphere Client directory at the vCenter server and remove the Deploy plug-in if found. Although the Deploy plug-in does not use Flash, it is a best practice to examine this directory as part of the plug-in removal procedure.
You must have the password for the root account at the vCenter server. You should remove the plug-in using the vSphere MOB and remove the plug-in from the vSphere UI directory.
Navigate to the
directory for the vSphere-Client service:cd /etc/vmware/vsphere-client/vc-packages/vsphere-client-serenity
service-control --stop vsphere-client
Remove the directory containing the client extensions:
service-control --start vsphere-client
