VMware hypervisor and hardware considerations
There are several hardware requirements and planning issues you should consider related to the VMware environment.
Hypervisor requirements
There are several requirements related to the hypervisor where ONTAP Select runs.
You should review the current release notes for your version of ONTAP Select for any additional known restrictions or limitations. |
VMware licensing
To deploy an ONTAP Select cluster, your organization must have a valid VMware vSphere license for the hypervisor hosts where ONTAP Select runs. You should use the licenses that are appropriate for your deployment.
Software compatibility
ONTAP Select can be deployed on the following hypervisors:
KVM on RedHat Enterprise Linux 8.6, 8.7, 8.8, 9.0, 9.1, and 9.2
KVM on Rocky Linux 8 and 9
VMware ESXi 7.0 GA (build 15843807 or greater) including 7.0 U1, U2, and U3C
VMware ESXi 8.0 GA (build 20513097)
VMware ESXi 8.0 U1 (build 21495797)
NetApp supports ONTAP Select on the identified versions of ESXi as long as VMware also continues to support the same versions. |
ESXi 6.5 GA and ESXi 6.7 GA are reaching end of availability status. If you have ONTAP Select clusters with these versions, you must upgrade to the supported versions as per the Interoperability Matrix Tool (IMT). |
Upgrade to VMware ESXi 6.5 U2 or later
If you currently have ONTAP Select deployed on VMware ESXi 6.5 U1, you should upgrade to ESXi 6.5 U2 or later as soon as possible. Using ESXi 6.5 U1 can expose you to a virtual machine failure due to a known VMware bug.
VMware vCenter and standalone ESXi hosts
If an ESXi hypervisor host is managed by a vCenter server, you must register the host to the Deploy administration utility using the vCenter credentials. You cannot register the host as a standalone host using the ESXi credentials.
Core hardware requirements
The physical hypervisor host where you deploy ONTAP Select must meet several hardware requirements. You can choose any platform for the hypervisor host, as long as it meets the minimum hardware requirements. The following vendors provide supported hardware platforms: Cisco, Dell, HP, Fujitsu, Lenovo, and Supermicro.
Beginning with ONTAP Select 9.9.1 only CPU models based on Intel Xeon Sandy Bridge or later are supported. |
Refer to the NetApp Interoperability Matrix Tool for more information.
Basic hardware requirements
There are several common hardware requirements that apply to all platforms regardless of the node
instance type or license offering.
The supported microprocessors include the following:
Intel Xeon processors for Server (see Intel Xeon Processors for more information)
There are several supported Ethernet configurations based on the cluster size.
Cluster size |
Minimum requirements |
Recommended requirements |
Single node cluster |
2 x 1GbE |
2 x 10GbE |
Two-node cluster or MetroCluster SDS |
4 x 1GbE or 1 x 10GbE |
2 x 10GbE |
4/6/8 node cluster |
2 x 10GbE |
4 x 10GbE or 2 x 25/40GbE |
Additional hardware requirements based on the instance type
There are several additional hardware requirements based on the node instance type.
Refer to Understand the platform license offerings for more information.
CPU cores
Six physical cores or greater, with four reserved for ONTAP Select. -
Memory
24GB or greater with 16GB reserved for ONTAP Select. -
Required platform license offering
Standard, premium, or premium XL
CPU cores
Ten physical cores or greater, with eight reserved for ONTAP Select. -
Memory
72GB or greater with 64GB reserved for ONTAP Select -
Premium or premium XL
CPU cores
Eighteen physical cores or greater, with sixteen reserved for ONTAP Select. -
Memory
136GB or greater with 128GB reserved for ONTAP Select -
Premium XL
There are additional disk requirements based on the platform license. See Storage and RAID for more information. |
