The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Security
Creating your file...
Your file is ready
There are several related tasks you can perform as part of securing an ONTAP Select deployment.
Change the Deploy administrator password
You can change the password for the Deploy virtual machine administrator account as needed using the command line interface.
Steps
Sign in to the Deploy utility CLI using the administrator account.
Change the password:
password modify
Respond to all prompts as appropriate for your environment.
