ONTAP Select
Upgrade the ONTAP Select nodes
Contributors netapp-pcarriga
After deploying an ONTAP Select cluster, you can upgrade the ONTAP image at each node in the cluster as needed.
Caution You cannot use the Deploy administration utility to perform upgrades of existing ONTAP Select nodes. The Deploy utility can only be used to create new ONTAP Select clusters.
General procedure
At a high level, you should use the following steps to upgrade an existing ONTAP Select node.
  1. Navigate to downloads page at the NetApp Support Site.
  2. Click ONTAP Select Node Upgrade.
  3. Select and download the appropriate upgrade image responding to all prompts as needed.
    Review the Release Notes for additional information and any required procedures before upgrading an ONTAP Select node.
  4. Upgrade the ONTAP Select node using the standard ONTAP upgrade procedures with the ONTAP Select upgrade file. For information on supported upgrade paths, see the Supported ONTAP upgrade paths.
Revert an ONTAP Select node
You cannot revert an ONTAP Select node to a version prior to the one on which it was originally installed. For example:
ONTAP Select 9.7 is initially installed
You can upgrade the node to version 9.8 and then revert back to version 9.7 if needed.
ONTAP Select 9.8 is initially installed
You cannot revert to version 9.7 because this version is prior to the version that was originally installed.
Use the VMXNET3 network driver
VMXNET3 is the default network driver included with new cluster deployments on VMware ESXi. If you upgrade an existing ONTAP Select node running ONTAP Select 9.4 or earlier, the network driver is not automatically upgraded. You must manually upgrade to VMXNET3. You should contact NetApp support for assistance with the upgrade.
Related information
ONTAP upgrade overview
